Koji repo sync metadata problem
Hey,
when I initiated mrepo -n (dry run) this morning to see how mrepo
works on our koji in order to test if we are able to add Fedora 27 for
Pulp, I learned that this "dry run" is actually a real run and mrepo
initiated full resync of our content without metadata regeneration.
This rendered our external repositories unusable as all metadata were
deleted. All builds will fail today with missing dependencies.
The plan: we need to let mrepo finish "dry run" downloading of Fedora
27 and then we need to reexecute it with proper flags:
cat /usr/local/bin/koji-sync-external-repos
#!/bin/bash
mrepo -qugf
koji list-targets --quiet | awk '{print $2}' | sort -u | xargs -I '{}'
koji regen-repo --nowait '{}'
Note the -u -g -f flags for mrepo, this will cause all metadata to be
regenerated. Once this command is done, koji will see missing
dependencies to appear.
The dry run of mrepo is running in screen and it is about to finish
hopefully soon. I will defer this to Eric in case it won't finish by
EMEA EOB.
Sorry for inconvenience, but dry run should be dry run, right.
··· -- Later, Lukas @lzap Zapletal
Looks like everything is back up and working as expected. For packagers,
keep in mind that this updated some of our external repositories to their
latest versions if you see any oddities. This also means that Fedora 27 is
available as an external repository for Pulp and Katello clients.
··· On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal wrote:
Hey,
Pulp, I learned that this “dry run” is actually a real run and mrepo
The plan: we need to let mrepo finish “dry run” downloading of Fedora
#!/bin/bash
mrepo -qugf
koji list-targets --quiet | awk ‘{print $2}’ | sort -u | xargs -I ‘{}’
koji regen-repo --nowait ‘{}’
hopefully soon. I will defer this to Eric in case it won’t finish by
EMEA EOB.
Later,
“foreman-dev” group.
Eric D. Helms
Red Hat Engineering
I still get errors when building:
http://koji.katello.org/koji/taskinfo?taskID=52363
http://koji.katello.org/kojifiles/work/tasks/2363/52363/root.log
DEBUG util.py:439: Error downloading packages:
DEBUG util.py:439: 1:nodejs-6.10.3-1.el7.x86_64: failed to retrieve nodejs-6.10.3-1.el7.x86_64.rpm from build
DEBUG util.py:439: error was [Errno 2] Local file does not exist: /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/nodejs-6.10.3-1.el7.x86_64.rpm
DEBUG util.py:439: http-parser-2.7.1-3.el7.x86_64: failed to retrieve http-parser-2.7.1-3.el7.x86_64.rpm from build
DEBUG util.py:439: error was [Errno 2] Local file does not exist: /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/http-parser-2.7.1-3.el7.x86_64.rpm
DEBUG util.py:439: 1:npm-3.10.10-1.6.10.3.1.el7.x86_64: failed to retrieve npm-3.10.10-1.6.10.3.1.el7.x86_64.rpm from build
DEBUG util.py:439: error was [Errno 2] Local file does not exist: /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/npm-3.10.10-1.6.10.3.1.el7.x86_64.rpm
··· On Wed, Nov 15, 2017 at 11:44:24AM -0500, Eric D Helms wrote: >Looks like everything is back up and working as expected. For packagers, >keep in mind that this updated some of our external repositories to their >latest versions if you see any oddities. This also means that Fedora 27 is >available as an external repository for Pulp and Katello clients. > >On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal wrote: > >> Hey, >> >> when I initiated mrepo -n (dry run) this morning to see how mrepo >> works on our koji in order to test if we are able to add Fedora 27 for >> Pulp, I learned that this "dry run" is actually a real run and mrepo >> initiated full resync of our content without metadata regeneration. >> >> This rendered our external repositories unusable as all metadata were >> deleted. All builds will fail today with missing dependencies. >> >> The plan: we need to let mrepo finish "dry run" downloading of Fedora >> 27 and then we need to reexecute it with proper flags: >> >> cat /usr/local/bin/koji-sync-external-repos >> #!/bin/bash >> mrepo -qugf >> koji list-targets --quiet | awk '{print $2}' | sort -u | xargs -I '{}' >> koji regen-repo --nowait '{}' >> >> Note the -u -g -f flags for mrepo, this will cause all metadata to be >> regenerated. Once this command is done, koji will see missing >> dependencies to appear. >> >> The dry run of mrepo is running in screen and it is about to finish >> hopefully soon. I will defer this to Eric in case it won't finish by >> EMEA EOB. >> >> Sorry for inconvenience, but dry run should be dry run, right. >> >> -- >> Later, >> Lukas @lzap Zapletal >> >> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. >> > > > >-- >Eric D. Helms >Red Hat Engineering > >-- >You received this message because you are subscribed to the Google Groups "foreman-dev" group. >To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com. >For more options, visit https://groups.google.com/d/optout.
Thanks Eric, have you also performed the second command from the cron
job (regen-repo)?
We used to run this on a weekly basis on the old koji, but this was
disabled on the new one.
··· On Wed, Nov 15, 2017 at 5:44 PM, Eric D Helms wrote: > Looks like everything is back up and working as expected. For packagers, > keep in mind that this updated some of our external repositories to their > latest versions if you see any oddities. This also means that Fedora 27 is > available as an external repository for Pulp and Katello clients. > > On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal wrote: >> >> Hey, >> >> when I initiated mrepo -n (dry run) this morning to see how mrepo >> works on our koji in order to test if we are able to add Fedora 27 for >> Pulp, I learned that this "dry run" is actually a real run and mrepo >> initiated full resync of our content without metadata regeneration. >> >> This rendered our external repositories unusable as all metadata were >> deleted. All builds will fail today with missing dependencies. >> >> The plan: we need to let mrepo finish "dry run" downloading of Fedora >> 27 and then we need to reexecute it with proper flags: >> >> cat /usr/local/bin/koji-sync-external-repos >> #!/bin/bash >> mrepo -qugf >> koji list-targets --quiet | awk '{print $2}' | sort -u | xargs -I '{}' >> koji regen-repo --nowait '{}' >> >> Note the -u -g -f flags for mrepo, this will cause all metadata to be >> regenerated. Once this command is done, koji will see missing >> dependencies to appear. >> >> The dry run of mrepo is running in screen and it is about to finish >> hopefully soon. I will defer this to Eric in case it won't finish by >> EMEA EOB. >> >> Sorry for inconvenience, but dry run should be dry run, right. >> >> -- >> Later, >> Lukas @lzap Zapletal >> >> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. > > > > > -- > Eric D. Helms > Red Hat Engineering > > -- > You received this message because you are subscribed to the Google Groups > "foreman-dev" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to foreman-dev+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
Later,
I do not have access here, can someone take a look? Are repodata
present for EPEL7?
LZ
··· On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden wrote: > I still get errors when building: > > http://koji.katello.org/koji/taskinfo?taskID=52363 > http://koji.katello.org/kojifiles/work/tasks/2363/52363/root.log > > DEBUG util.py:439: Error downloading packages: > DEBUG util.py:439: 1:nodejs-6.10.3-1.el7.x86_64: failed to retrieve > nodejs-6.10.3-1.el7.x86_64.rpm from build > DEBUG util.py:439: error was [Errno 2] Local file does not exist: > /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/nodejs-6.10.3-1.el7.x86_64.rpm > DEBUG util.py:439: http-parser-2.7.1-3.el7.x86_64: failed to retrieve > http-parser-2.7.1-3.el7.x86_64.rpm from build > DEBUG util.py:439: error was [Errno 2] Local file does not exist: > /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/http-parser-2.7.1-3.el7.x86_64.rpm > DEBUG util.py:439: 1:npm-3.10.10-1.6.10.3.1.el7.x86_64: failed to > retrieve npm-3.10.10-1.6.10.3.1.el7.x86_64.rpm from build > DEBUG util.py:439: error was [Errno 2] Local file does not exist: > /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/npm-3.10.10-1.6.10.3.1.el7.x86_64.rpm > > > On Wed, Nov 15, 2017 at 11:44:24AM -0500, Eric D Helms wrote: >> >> Looks like everything is back up and working as expected. For packagers, >> keep in mind that this updated some of our external repositories to their >> latest versions if you see any oddities. This also means that Fedora 27 is >> available as an external repository for Pulp and Katello clients. >> >> On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal wrote: >> >>> Hey, >>> >>> when I initiated mrepo -n (dry run) this morning to see how mrepo >>> works on our koji in order to test if we are able to add Fedora 27 for >>> Pulp, I learned that this "dry run" is actually a real run and mrepo >>> initiated full resync of our content without metadata regeneration. >>> >>> This rendered our external repositories unusable as all metadata were >>> deleted. All builds will fail today with missing dependencies. >>> >>> The plan: we need to let mrepo finish "dry run" downloading of Fedora >>> 27 and then we need to reexecute it with proper flags: >>> >>> cat /usr/local/bin/koji-sync-external-repos >>> #!/bin/bash >>> mrepo -qugf >>> koji list-targets --quiet | awk '{print $2}' | sort -u | xargs -I '{}' >>> koji regen-repo --nowait '{}' >>> >>> Note the -u -g -f flags for mrepo, this will cause all metadata to be >>> regenerated. Once this command is done, koji will see missing >>> dependencies to appear. >>> >>> The dry run of mrepo is running in screen and it is about to finish >>> hopefully soon. I will defer this to Eric in case it won't finish by >>> EMEA EOB. >>> >>> Sorry for inconvenience, but dry run should be dry run, right. >>> >>> -- >>> Later, >>> Lukas @lzap Zapletal >>> >>> -- >>> You received this message because you are subscribed to the Google Groups >>> "foreman-dev" group. >>> To unsubscribe from this group and stop receiving emails from it, send an >>> email to foreman-dev+unsubscribe@googlegroups.com. >>> For more options, visit https://groups.google.com/d/optout. >>> >> >> >> >> -- >> Eric D. Helms >> Red Hat Engineering >> >> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. > > > -- > You received this message because you are subscribed to the Google Groups > "foreman-dev" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to foreman-dev+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
Later,
> present for EPEL7?
If I have the correct path, it does not appear so:
[root@koji repodata]# pwd
/mnt/koji/external-repos/epel7-x86_64/epel/repodata
[root@koji repodata]# ls
··· On Wed, 2017-11-15 at 19:56 +0100, Lukas Zapletal wrote:
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden > ewoud@kohlvanwijngaarden.nl wrote:
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal lzap@redhat.com wrote:
Hey,
#!/bin/bash
mrepo -qugf
EMEA EOB.
Later,
Eric D. Helms
Red Hat Engineering
Later,
> > present for EPEL7?
I might not have, this path DOES have repodata:
/mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/repodata
··· On Wed, 2017-11-15 at 14:00 -0500, Patrick Creech wrote: > On Wed, 2017-11-15 at 19:56 +0100, Lukas Zapletal wrote:
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden > > ewoud@kohlvanwijngaarden.nl wrote:
Hey,
#!/bin/bash
mrepo -qugf
EMEA EOB.
Later,
Eric D. Helms
Red Hat Engineering
Later,
I had forgotten to run the repo-regen on Koji. That is finishing up now. I
will run another test after and report back.
present for EPEL7?
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden > > > ewoud@kohlvanwijngaarden.nl wrote:
retrieve
retrieve
packagers,
to their
Fedora 27 is
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal lzap@redhat.com > wrote:
Hey,
27 for
mrepo
regeneration.
were
Fedora
#!/bin/bash
mrepo -qugf
-I ‘{}’
to be
finish
finish by
EMEA EOB.
Later,
Google Groups
it, send an
Eric D. Helms
Red Hat Engineering
Groups
send an
Groups
send an
Later,
Eric D. Helms
Red Hat Engineering
This now appears to be working again. One out standing question that
affects nodejs- packaging builds.
As part of the RHEL 7.4 release, http-parser was removed from EPEL. With
this latest round of Koji external repositories update we now have a newer
EPEL with this package removed. We did not update our CentOS external
repository that would include this package. Not updating the base OS has
been our policy for a while now it would seem. We have two options:
  1. Sync and update CentOS
  2. Add http-parser to the overrides tag for foreman-nightly
present for EPEL7?
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden >> > > ewoud@kohlvanwijngaarden.nl wrote:
retrieve
retrieve
to
packagers,
to their
Fedora 27 is
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal lzap@redhat.com >> wrote:
Hey,
mrepo
27 for
mrepo
regeneration.
metadata were
Fedora
#!/bin/bash
mrepo -qugf
-I ‘{}’
to be
finish
finish by
EMEA EOB.
Later,
Google Groups
it, send an
Eric D. Helms
Red Hat Engineering
Google Groups
send an
Groups
send an
Later,
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
I think we should sync & update. CentOS has no concept of supported
minor releases and we should be testing with a supported release.
··· On Wed, Nov 15, 2017 at 03:57:40PM -0500, Eric D Helms wrote: >This now appears to be working again. One out standing question that >affects nodejs- packaging builds. > >As part of the RHEL 7.4 release, http-parser was removed from EPEL. With >this latest round of Koji external repositories update we now have a newer >EPEL with this package removed. We did not update our CentOS external >repository that would include this package. Not updating the base OS has >been our policy for a while now it would seem. We have two options: > > 1) Sync and update CentOS > 2) Add http-parser to the overrides tag for foreman-nightly > >On Wed, Nov 15, 2017 at 2:11 PM, Eric D Helms wrote: > >> I had forgotten to run the repo-regen on Koji. That is finishing up now. I >> will run another test after and report back. >> >> On Wed, Nov 15, 2017 at 2:08 PM, Patrick Creech >> wrote: >> >>> On Wed, 2017-11-15 at 14:00 -0500, Patrick Creech wrote: >>> > On Wed, 2017-11-15 at 19:56 +0100, Lukas Zapletal wrote: >>> > > I do not have access here, can someone take a look? Are repodata >>> > > present for EPEL7? >>> > >>> > If I have the correct path, it does not appear so: >>> > >>> > [root@koji repodata]# pwd >>> > /mnt/koji/external-repos/epel7-x86_64/epel/repodata >>> > [root@koji repodata]# ls >>> > [root@koji repodata]# >>> > >>> >>> I might not have, this path DOES have repodata: >>> >>> /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/repodata >>> >>> > > LZ >>> > > >>> > > On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden >>> > > wrote: >>> > > > I still get errors when building: >>> > > > >>> > > > http://koji.katello.org/koji/taskinfo?taskID=52363 >>> > > > http://koji.katello.org/kojifiles/work/tasks/2363/52363/root.log >>> > > > >>> > > > DEBUG util.py:439: Error downloading packages: >>> > > > DEBUG util.py:439: 1:nodejs-6.10.3-1.el7.x86_64: failed to >>> retrieve >>> > > > nodejs-6.10.3-1.el7.x86_64.rpm from build >>> > > > DEBUG util.py:439: error was [Errno 2] Local file does not exist: >>> > > > /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/nodejs-6 >>> .10.3-1.el7.x86_64.rpm >>> > > > DEBUG util.py:439: http-parser-2.7.1-3.el7.x86_64: failed to >>> retrieve >>> > > > http-parser-2.7.1-3.el7.x86_64.rpm from build >>> > > > DEBUG util.py:439: error was [Errno 2] Local file does not exist: >>> > > > /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/http-par >>> ser-2.7.1-3.el7.x86_64.rpm >>> > > > DEBUG util.py:439: 1:npm-3.10.10-1.6.10.3.1.el7.x86_64: failed >>> to >>> > > > retrieve npm-3.10.10-1.6.10.3.1.el7.x86_64.rpm from build >>> > > > DEBUG util.py:439: error was [Errno 2] Local file does not exist: >>> > > > /mnt/koji/external-repos/www/epel7-x86_64/RPMS.epel/npm-3.10 >>> .10-1.6.10.3.1.el7.x86_64.rpm >>> > > > >>> > > > >>> > > > On Wed, Nov 15, 2017 at 11:44:24AM -0500, Eric D Helms wrote: >>> > > > > >>> > > > > Looks like everything is back up and working as expected. For >>> packagers, >>> > > > > keep in mind that this updated some of our external repositories >>> to their >>> > > > > latest versions if you see any oddities. This also means that >>> Fedora 27 is >>> > > > > available as an external repository for Pulp and Katello clients. >>> > > > > >>> > > > > On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal >>> wrote: >>> > > > > >>> > > > > > Hey, >>> > > > > > >>> > > > > > when I initiated mrepo -n (dry run) this morning to see how >>> mrepo >>> > > > > > works on our koji in order to test if we are able to add Fedora >>> 27 for >>> > > > > > Pulp, I learned that this "dry run" is actually a real run and >>> mrepo >>> > > > > > initiated full resync of our content without metadata >>> regeneration. >>> > > > > > >>> > > > > > This rendered our external repositories unusable as all >>> metadata were >>> > > > > > deleted. All builds will fail today with missing dependencies. >>> > > > > > >>> > > > > > The plan: we need to let mrepo finish "dry run" downloading of >>> Fedora >>> > > > > > 27 and then we need to reexecute it with proper flags: >>> > > > > > >>> > > > > > cat /usr/local/bin/koji-sync-external-repos >>> > > > > > #!/bin/bash >>> > > > > > mrepo -qugf >>> > > > > > koji list-targets --quiet | awk '{print $2}' | sort -u | xargs >>> -I '{}' >>> > > > > > koji regen-repo --nowait '{}' >>> > > > > > >>> > > > > > Note the -u -g -f flags for mrepo, this will cause all metadata >>> to be >>> > > > > > regenerated. Once this command is done, koji will see missing >>> > > > > > dependencies to appear. >>> > > > > > >>> > > > > > The dry run of mrepo is running in screen and it is about to >>> finish >>> > > > > > hopefully soon. I will defer this to Eric in case it won't >>> finish by >>> > > > > > EMEA EOB. >>> > > > > > >>> > > > > > Sorry for inconvenience, but dry run should be dry run, right. >>> > > > > > >>> > > > > > -- >>> > > > > > Later, >>> > > > > > Lukas @lzap Zapletal >>> > > > > > >>> > > > > > -- >>> > > > > > You received this message because you are subscribed to the >>> Google Groups >>> > > > > > "foreman-dev" group. >>> > > > > > To unsubscribe from this group and stop receiving emails from >>> it, send an >>> > > > > > email to foreman-dev+unsubscribe@googlegroups.com. >>> > > > > > For more options, visit https://groups.google.com/d/optout. >>> > > > > > >>> > > > > >>> > > > > >>> > > > > >>> > > > > -- >>> > > > > Eric D. Helms >>> > > > > Red Hat Engineering >>> > > > > >>> > > > > -- >>> > > > > You received this message because you are subscribed to the >>> Google Groups >>> > > > > "foreman-dev" group. >>> > > > > To unsubscribe from this group and stop receiving emails from it, >>> send an >>> > > > > email to foreman-dev+unsubscribe@googlegroups.com. >>> > > > > For more options, visit https://groups.google.com/d/optout. >>> > > > >>> > > > >>> > > > -- >>> > > > You received this message because you are subscribed to the Google >>> Groups >>> > > > "foreman-dev" group. >>> > > > To unsubscribe from this group and stop receiving emails from it, >>> send an >>> > > > email to foreman-dev+unsubscribe@googlegroups.com. >>> > > > For more options, visit https://groups.google.com/d/optout. >>> > > >>> > > >>> > > >>> > > -- >>> > > Later, >>> > > Lukas @lzap Zapletal >>> >>> -- >>> You received this message because you are subscribed to the Google Groups >>> "foreman-dev" group. >>> To unsubscribe from this group and stop receiving emails from it, send an >>> email to foreman-dev+unsubscribe@googlegroups.com. >>> For more options, visit https://groups.google.com/d/optout. >>> >> >> >> >> -- >> Eric D. Helms >> Red Hat Engineering >> > > > >-- >Eric D. Helms >Red Hat Engineering > >-- >You received this message because you are subscribed to the Google Groups "foreman-dev" group. >To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com. >For more options, visit https://groups.google.com/d/optout.
Thanks Eric, I added this section about the process for the future:
http://projects.theforeman.org/projects/foreman/wiki/KojiSetup#Adding-external-repository
··· On Wed, Nov 15, 2017 at 9:57 PM, Eric D Helms <ericdhelms@gmail.com> wrote:
This now appears to be working again. One out standing question that affects
On Wed, Nov 15, 2017 at 2:08 PM, Patrick Creech <pcreech@redhat.com> >> wrote:
present for EPEL7?
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden >>> > > <ewoud@kohlvanwijngaarden.nl> wrote:
retrieve
retrieve
to
packagers,
to their
Fedora 27 is
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal <lzap@redhat.com> >>> > > > > wrote:
Hey,
mrepo
27 for
mrepo
regeneration.
metadata were
Fedora
#!/bin/bash
mrepo -qugf
-I '{}'
to be
finish
finish by
EMEA EOB.
Later,
Google Groups
it, send an
Eric D. Helms
Red Hat Engineering
Google Groups
send an
Groups
send an
Later,
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Later,
I would be against syncing regularly but I don't do much packaging so it's up to you. The problem I see is "random" breakage. You come to work on Monday after sync and if you don't realize the package was deleted from EPEL, you can burn hour or something to figure it out sometimes. This was pretty clear case but as you know there are situations (SCL) when it is not that clear.
If we ever deploy new koji, I'd vote to avoid getting OS updates completely, just base channels and explicit updates when we need it. We need reproducible builds, with autosync we are not getting it.
One note, if we sync CentOS or RHEL base to particular version, chances are that SELinux won't load on older releases. So basically we must be ready to do minimum requirements change here.
Thanks for solving the problem.
LZ
··· On Wed, Nov 15, 2017 at 10:05 PM, Ewoud Kohl van Wijngaarden <ewoud@kohlvanwijngaarden.nl> wrote:
I think we should sync & update. CentOS has no concept of supported minor
On Wed, Nov 15, 2017 at 2:11 PM, Eric D Helms <ericdhelms@gmail.com> >> wrote:
I
On Wed, Nov 15, 2017 at 2:08 PM, Patrick Creech <pcreech@redhat.com> >>> wrote:
present for EPEL7?
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden >>>> > > <ewoud@kohlvanwijngaarden.nl> wrote:
retrieve
retrieve
to
packagers,
to their
Fedora 27 is
clients.
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal >>>> > > > > <lzap@redhat.com> >>>> wrote:
Hey,
mrepo
Fedora
27 for
mrepo
regeneration.
metadata were
Fedora
#!/bin/bash
mrepo -qugf
-I '{}'
metadata
to be
finish
finish by
EMEA EOB.
Later,
Google Groups
it, send an
Eric D. Helms
Red Hat Engineering
Google Groups
it,
send an
Groups
send an
Later,
Groups
an
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Later,
Those sound like good arguments, but if we don't test on older releases then we don't know for sure they work either. IMHO it's acceptable to explicitly only support EL 7.4 and up. We don't have the resources to support older versions especially since CentOS doesn't support that either. If users want verified working versions on EL < 7.4 then they should either help us properly support it or buy support from a vendor that does want to promise it works.
LZ
On Wed, Nov 15, 2017 at 10:05 PM, Ewoud Kohl van Wijngaarden ><ewoud@kohlvanwijngaarden.nl> wrote:
On Wed, Nov 15, 2017 at 2:11 PM, Eric D Helms <ericdhelms@gmail.com> >>> wrote:
I
On Wed, Nov 15, 2017 at 2:08 PM, Patrick Creech <pcreech@redhat.com> >>>> wrote:
present for EPEL7?
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden >>>>> > > <ewoud@kohlvanwijngaarden.nl> wrote:
retrieve
retrieve
to
packagers,
to their
Fedora 27 is
clients.
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal >>>>> > > > > <lzap@redhat.com> >>>>> wrote:
Hey,
mrepo
Fedora
27 for
mrepo
regeneration.
metadata were
Fedora
#!/bin/bash
mrepo -qugf
-I '{}'
metadata
to be
finish
finish by
EMEA EOB.
Later,
Google Groups
it, send an
Eric D. Helms
Red Hat Engineering
Google Groups
it,
send an
Groups
send an
Later,
Groups
an
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Later,
I started an mrepo run after adding CentOS in a screen session. The run appears to be running a lot longer than previous and it's not clear to me what exactly it's doing at present or whats safe to do. Lukas could you check on it in your morning and see if you spot anything odd about why it seems to have stalled or slowed down?
··· On Thu, Nov 16, 2017 at 6:01 AM, Ewoud Kohl van Wijngaarden < ewoud@kohlvanwijngaarden.nl> wrote:
promise it works.
LZ
On Wed, Nov 15, 2017 at 10:05 PM, Ewoud Kohl van Wijngaarden >> <ewoud@kohlvanwijngaarden.nl> wrote:
newer
On Wed, Nov 15, 2017 at 2:11 PM, Eric D Helms <ericdhelms@gmail.com> >>>> wrote:
I
On Wed, Nov 15, 2017 at 2:08 PM, Patrick Creech <pcreech@redhat.com> >>>>> wrote:
present for EPEL7?
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden >>>>>> > > <ewoud@kohlvanwijngaarden.nl> wrote:
root.log
retrieve
exist:
retrieve
exist:
failed
to
exist:
packagers,
repositories
to their
Fedora 27 is
clients.
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal >>>>>> > > > > <lzap@redhat.com> >>>>>> wrote:
Hey,
mrepo
Fedora
27 for
and
mrepo
regeneration.
metadata were
dependencies.
of
Fedora
#!/bin/bash
mrepo -qugf
xargs
-I '{}'
metadata
to be
missing
finish
finish by
EMEA EOB.
right.
Later,
Google Groups
from
it, send an
Eric D. Helms
Red Hat Engineering
Google Groups
it,
send an
Google
Groups
it,
send an
Later,
Groups
an
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Groups
an
Later,
Eric D. Helms
Red Hat Engineering
The update seems to have completed, with the new CentOS repository added to Koji and repositories regenerated. For the moment, the
foreman-nightly*-rhel7-build tags have been updated to remove rhel as an external repository and have been replaced with CentOS (7.4). If you notice any oddities building, please let us know so we can work through them.
Eric
··· On Thu, Nov 16, 2017 at 7:14 PM, Eric D Helms <ericdhelms@gmail.com> wrote:
On Thu, Nov 16, 2017 at 6:01 AM, Ewoud Kohl van Wijngaarden < > ewoud@kohlvanwijngaarden.nl> wrote:
promise it works.
LZ
On Wed, Nov 15, 2017 at 10:05 PM, Ewoud Kohl van Wijngaarden >>> <ewoud@kohlvanwijngaarden.nl> wrote:
minor
With
newer
has
On Wed, Nov 15, 2017 at 2:11 PM, Eric D Helms <ericdhelms@gmail.com> >>>>> wrote:
now.
I
On Wed, Nov 15, 2017 at 2:08 PM, Patrick Creech <pcreech@redhat.com> >>>>>> wrote:
present for EPEL7?
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden >>>>>>> > > <ewoud@kohlvanwijngaarden.nl> wrote:
.log
retrieve
exist:
to
retrieve
exist:
failed
to
exist:
packagers,
repositories
to their
Fedora 27 is
clients.
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal >>>>>>> > > > > <lzap@redhat.com> >>>>>>> wrote:
Hey,
mrepo
Fedora
27 for
and
mrepo
regeneration.
metadata were
dependencies.
downloading of
Fedora
#!/bin/bash
mrepo -qugf
xargs
-I '{}'
metadata
to be
missing
to
finish
finish by
EMEA EOB.
right.
Later,
Google Groups
from
it, send an
Eric D. Helms
Red Hat Engineering
Google Groups
it,
send an
Google
Groups
it,
send an
Later,
Groups
send
an
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Groups
an
Groups
an
Later,
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Sorry we had public holiday here.
We use mirrorselect with mrepo, sometimes it can pick slower mirror. Would be safer to pick particular mirrors if we plan to sync regularly, ideally something within AWS datacenters if there's any.
LZ
··· On Fri, Nov 17, 2017 at 4:53 PM, Eric D Helms <ericdhelms@gmail.com> wrote:
Eric
On Thu, Nov 16, 2017 at 6:01 AM, Ewoud Kohl van Wijngaarden >> <ewoud@kohlvanwijngaarden.nl> wrote:
promise it works.
LZ
On Wed, Nov 15, 2017 at 10:05 PM, Ewoud Kohl van Wijngaarden >>>> <ewoud@kohlvanwijngaarden.nl> wrote:
minor
With
newer
has
On Wed, Nov 15, 2017 at 2:11 PM, Eric D Helms <ericdhelms@gmail.com> >>>>>> wrote:
now.
I
On Wed, Nov 15, 2017 at 2:08 PM, Patrick Creech <pcreech@redhat.com> >>>>>>> wrote:
present for EPEL7?
LZ
On Wed, Nov 15, 2017 at 6:15 PM, Ewoud Kohl van Wijngaarden >>>>>>>> > > <ewoud@kohlvanwijngaarden.nl> wrote:
retrieve
exist:
to
retrieve
exist:
failed
to
exist:
For
packagers,
repositories
to their
that
Fedora 27 is
clients.
On Wed, Nov 15, 2017 at 9:32 AM, Lukas Zapletal >>>>>>>> > > > > <lzap@redhat.com> >>>>>>>> wrote:
Hey,
how
mrepo
Fedora
27 for
and
mrepo
regeneration.
metadata were
dependencies.
downloading of
Fedora
#!/bin/bash
mrepo -qugf
xargs
-I '{}'
metadata
to be
missing
to
finish
finish by
EMEA EOB.
right.
Later,
the
Google Groups
from
it, send an
Eric D. Helms
Red Hat Engineering
Google Groups
from
it,
send an
Google
Groups
it,
send an
Later,
Groups
send
an
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Groups
an
Groups
an
Later,
Eric D. Helms
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Later,
