LDAP Authentication does not work!
Windows AD users able to login
n/a
Notes & Configuration:
-CentOS 7.5:
LDAP is configured at OS level
LDAP login as OS level works
-Foreman:
/etc/foreman/settings.yml or /etc/foreman-proxy/settings.yml
:ldap: true is configured
UI - Test Connection [ ok ]
Server Type: AD
- BaseDN [ ok ]
- Group baseDN [ ok ]
- LDAP filter [ ok ]
- Attrbutes mappings [ ok ]
- Add a user, Authorized by LDAP-Windows
logs - doesn't register an error
services - restarted
I have read the manual and configured as required.
I have research for some other solution or configuration.
Nothing makes Foreman LDAP to work with Windows AD
No Host Firewall, No Network firewall
No malware detector or antivirus
Missing ruby gems?
