Since version 1.15, and now with version 1.19.1, when deploying a new libvirt virtual host, or sometimes doing not much at all, we try to use the Console button, and get an error “ActiveRecord::RecordNotFound”
Then usually the “Console” button on a Virtual machine’s dashboard page goes missing and we get an “Unknown Power State”.
To not get ActiveRecord::RecordNotFound issues every single time I use Foreman.
| foreman_discovery | MaaS Discovery Plugin engine for Foreman | alongoldboim, Alon Goldboim, amirfefer, Amit Karsale, Amos Benari, Avi Sharvit, Bryan Kearney, bshuster, Daniel Lobato, Daniel Lobato Garcia, Daniel Lobato García, Danny Smit, David Davis, Dominic Cleal, Eric D. Helms, Ewoud Kohl van Wijngaarden, Frank Wall, Greg Sutcliffe, ChairmanTubeAmp, Ido Kanner, imriz, Imri Zvik, Joseph Mitchell Magen, June Zhang, kgaikwad, Lars Berntzon, ldjebran, Lukas Zapletal, Lukáš Zapletal, Marek Hulan, Marek Hulán, Martin Bačovský, Matt Jarvis, Michael Moll, Nick, odovzhenko, Ohad Levy, Ondrej Prazak, Ori Rabin, orrabin, Partha Aji, Petr Chalupa, Phirince Philip, Rahul Bajaj, Robert Antoni Buj Gelonch, Scubafloyd, Sean O’Keeffe, Sebastian Gräßl, Shimon Shtein, Shlomi Zadok, Stephen Benjamin, Swapnil Abnave, Thomas Gelf, Timo Goebel, Tomas Strych, Tom Caspy, Tomer Brisker, and Yann Cézard | 13.0.1 |
| foreman_hooks | Plugin engine for Foreman that enables running custom hook scripts on Foreman events | Dominic Cleal | 0.3.14 |
| foreman_snapshot_management | Foreman-plugin to manage snapshots in a vSphere environment. | ATIX AG | 1.5.0 |
| foreman_templates | Engine to synchronise provisioning templates from GitHub | Greg Sutcliffe | 6.0.3 |
| foreman_vmwareannotations | This plug-in copies the host comment to VMWare annotations in The Foreman. | Timo Goebel | 0.0.1 |
2018-11-16T18:21:24 [W|app|fbd98] Failed retrieving libvirt vm by uuid 105f710f-eacf-4a6e-93bf-d6e6d560351a
Libvirt::RetrieveError: Call to virDomainLookupByUUID failed: internal error: client socket is closed
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-libvirt-0.4.1/lib/fog/libvirt/requests/compute/list_domains.rb:9:in `lookup_domain_by_uuid'
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-libvirt-0.4.1/lib/fog/libvirt/requests/compute/list_domains.rb:9:in `list_domains'
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-libvirt-0.4.1/lib/fog/libvirt/models/compute/servers.rb:15:in `get'
/usr/share/foreman/app/models/compute_resource.rb:181:in `find_vm_by_uuid'
/usr/share/foreman/app/models/compute_resources/foreman/model/libvirt.rb:40:in `find_vm_by_uuid'
/usr/share/foreman/app/controllers/hosts_controller.rb:304:in `vm'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/abstract_controller/base.rb:186:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:108:in `block in run_callbacks'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.7.1/lib/audited/sweeper.rb:14:in `around'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:135:in `run_callbacks'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/abstract_controller/callbacks.rb:19:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/rescue.rb:20:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/notifications.rb:166:in `block in instrument'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/notifications.rb:166:in `instrument'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/abstract_controller/base.rb:124:in `process'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionview-5.1.6/lib/action_view/rendering.rb:30:in `process'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal.rb:189:in `dispatch'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal.rb:253:in `dispatch'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:33:in `each'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:33:in `serve'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:844:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.9/lib/apipie/static_dispatcher.rb:65:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.9/lib/apipie/extractor/recorder.rb:136:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.9/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/etag.rb:25:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/conditional_get.rb:25:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/head.rb:12:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:232:in `context'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:226:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:97:in `run_callbacks'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/rack/logger.rb:36:in `call_app'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/rack/logger.rb:26:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/method_override.rb:22:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/runtime.rb:22:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/cache/strategy/local_cache_middleware.rb:27:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/executor.rb:12:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/static.rb:125:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/sendfile.rb:111:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-5.0.5/lib/secure_headers/middleware.rb:13:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/engine.rb:522:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/railtie.rb:185:in `public_send'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/railtie.rb:185:in `method_missing'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/urlmap.rb:68:in `block in call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `each'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `call'
/usr/share/ruby/vendor_ruby/phusion_passenger/rack/thread_handler_extension.rb:97:in `process_request'
/usr/share/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:149:in `accept_and_process_next_request'
/usr/share/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:110:in `main_loop'
/usr/share/ruby/vendor_ruby/phusion_passenger/request_handler.rb:415:in `block (3 levels) in start_threads'
/usr/share/ruby/vendor_ruby/phusion_passenger/utils.rb:113:in `block in create_thread_and_abort_on_exception'
2018-11-16T18:21:24 [W|app|fbd98] Failed to fetch vm information
ActiveRecord::RecordNotFound: ActiveRecord::RecordNotFound
/usr/share/foreman/app/models/compute_resources/foreman/model/libvirt.rb:43:in `rescue in find_vm_by_uuid'
/usr/share/foreman/app/models/compute_resources/foreman/model/libvirt.rb:39:in `find_vm_by_uuid'
2018-11-16T18:21:24 [I|app|fbd98] Rendered common/_ajax_error.html.erb (0.6ms)
2018-11-16T18:21:24 [I|app|fbd98] Completed 500 Internal Server Error in 170ms (Views: 1.2ms | ActiveRecord: 154.6ms)
FWIW, every time this happens, which is multiple times a day, I have to restart foreman entirely with foreman-rake db:migrate, this is ridiculous.
