I want to have link_to method in :
:column_view:
:uptime:
:title: Uptime
:after: 6
:content: facts_hash['uptime']
:view: :hosts_properties
is that possible ? I use this plugin: foreman_column_view
thanks in advance
:column_view:
:uptime:
:title: Uptime
:after: 6
thanks in advance
Taking a look at the code in that plugin, it seems it always runs a method on the host:
Therefore (based on my basic reading at least) it looks like arbitrary content in the table cell (such as link_to
) won’t be possible using this plugin, unfortunately.
thank you for your answer @jeremylenz,
that’s so pity that we can not use it.
So I cannot use html either right ?
Only by writing your own plugin and using deface - How to Create a Plugin - Foreman
You could in theory use some browser extension, like SeaMonkey / Greasemonkey to convert the value to the link, but that would do it only for you broswer, if more people use this Foreman instance, it’s not a great idea.
