Link to redmine issues using prprocessor
I find myself copying/pasting issue numbers from GitHub PRs to a redmine
url way too much every day. It takes a bit of time, and it's annoying as
well as easy to fix.
I've submitted this PR to comment on a newly submitted PR with links to the
associated issues in redmine:
https://github.com/theforeman/prprocessor/pull/59 I'd like to hear your
thoughts if you have something to say about it.
  • Andrew
··· -- Andrew Kofink akofink@redhat.com IRC: akofink Associate Software Engineer Red Hat Satellite
+1 from me :slight_smile:
John Mitsch
Red Hat Engineering
(860)-967-7285
irc: jomitsch
url way too much every day. It takes a bit of time, and it’s annoying as
I’ve submitted this PR to comment on a newly submitted PR with links to
the associated issues in redmine: https://github.com/
theforeman/prprocessor/pull/59 I’d like to hear your thoughts if you have
  • Andrew
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
"foreman-dev" group.
I like it although I include the links to the issues in my actual commit
message so it will be doubled up in my case.
John Mitsch
Red Hat Engineering
(860)-967-7285 <(860)%20967-7285>
irc: jomitsch
the associated issues in redmine: https://github.com/th
  • Andrew
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
Walden, you have a script that adds it, or do you do it manually for every
issue? If the latter, then wouldn't this save you some time? :wink:
John Mitsch
Red Hat Engineering
irc: jomitsch
  • Andrew
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
Groups “foreman-dev” group.
an email to foreman-dev+unsubscribe@googlegroups.com.
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
I do it manually although I probably should just write a commit hook to do
it.
I put it in the message itself because I think it's useful to have there in
case anyone is browsing the git log or in case we ever move away from
github.
Walden
issue? If the latter, then wouldn’t this save you some time? :wink:
John Mitsch
Red Hat Engineering
irc: jomitsch
redmine url way too much every day. It takes a bit of time, and it’s
annoying as well as easy to fix.
  • Andrew
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
Walden Raines <wraines@redhat.com> writes:
> it.
> github.
Interesting idea. Before it gets in (+ idea for other places outside of
prprocessor scope), I'm using Tomas's grease monkey script and has been
very helpful in past :slight_smile:
– Ivan
··· > > Walden > > On Thu, Apr 6, 2017 at 5:33 PM, Andrew Kofink wrote: > >> Walden, you have a script that adds it, or do you do it manually for every >> issue? If the latter, then wouldn't this save you some time? ;) >> >> On Thu, Apr 6, 2017 at 5:24 PM, Walden Raines wrote: >> >>> I like it although I include the links to the issues in my actual commit >>> message so it will be doubled up in my case. >>> >>> >>> >>> On Thu, Apr 6, 2017 at 4:18 PM, John Mitsch wrote: >>> >>>> +1 from me :) >>>> >>>> John Mitsch >>>> Red Hat Engineering >>>> (860)-967-7285 <(860)%20967-7285> >>>> irc: jomitsch >>>> >>>> On Thu, Apr 6, 2017 at 3:05 PM, Andrew Kofink >>>> wrote: >>>> >>>>> I find myself copying/pasting issue numbers from GitHub PRs to a >>>>> redmine url way too much every day. It takes a bit of time, and it's >>>>> annoying as well as easy to fix. >>>>> >>>>> I've submitted this PR to comment on a newly submitted PR with links to >>>>> the associated issues in redmine: https://github.com/th >>>>> eforeman/prprocessor/pull/59 I'd like to hear your thoughts if you >>>>> have something to say about it. >>>>> >>>>> - Andrew >>>>> >>>>> -- >>>>> Andrew Kofink >>>>> akofink@redhat.com >>>>> IRC: akofink >>>>> Associate Software Engineer >>>>> Red Hat Satellite >>>>> >>>>> -- >>>>> You received this message because you are subscribed to the Google >>>>> Groups "foreman-dev" group. >>>>> To unsubscribe from this group and stop receiving emails from it, send >>>>> an email to foreman-dev+unsubscribe@googlegroups.com. >>>>> For more options, visit https://groups.google.com/d/optout. >>>>> >>>> >>>> -- >>>> You received this message because you are subscribed to the Google >>>> Groups "foreman-dev" group. >>>> To unsubscribe from this group and stop receiving emails from it, send >>>> an email to foreman-dev+unsubscribe@googlegroups.com. >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> >>> -- >>> You received this message because you are subscribed to the Google Groups >>> "foreman-dev" group. >>> To unsubscribe from this group and stop receiving emails from it, send an >>> email to foreman-dev+unsubscribe@googlegroups.com. >>> For more options, visit https://groups.google.com/d/optout. >>> >> >> >> >> -- >> Andrew Kofink >> akofink@redhat.com >> IRC: akofink >> Associate Software Engineer >> Red Hat Satellite >> >> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. >> > > -- > You received this message because you are subscribed to the Google Groups "foreman-dev" group. > To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
Ivan Necas <inecas@redhat.com> writes:
>> it.
>> github.
Forgot to put a link:
– Ivan
··· > > -- Ivan > >> >> Walden >> >> On Thu, Apr 6, 2017 at 5:33 PM, Andrew Kofink wrote: >> >>> Walden, you have a script that adds it, or do you do it manually for every >>> issue? If the latter, then wouldn't this save you some time? ;) >>> >>> On Thu, Apr 6, 2017 at 5:24 PM, Walden Raines wrote: >>> >>>> I like it although I include the links to the issues in my actual commit >>>> message so it will be doubled up in my case. >>>> >>>> >>>> >>>> On Thu, Apr 6, 2017 at 4:18 PM, John Mitsch wrote: >>>> >>>>> +1 from me :) >>>>> >>>>> John Mitsch >>>>> Red Hat Engineering >>>>> (860)-967-7285 <(860)%20967-7285> >>>>> irc: jomitsch >>>>> >>>>> On Thu, Apr 6, 2017 at 3:05 PM, Andrew Kofink >>>>> wrote: >>>>> >>>>>> I find myself copying/pasting issue numbers from GitHub PRs to a >>>>>> redmine url way too much every day. It takes a bit of time, and it's >>>>>> annoying as well as easy to fix. >>>>>> >>>>>> I've submitted this PR to comment on a newly submitted PR with links to >>>>>> the associated issues in redmine: https://github.com/th >>>>>> eforeman/prprocessor/pull/59 I'd like to hear your thoughts if you >>>>>> have something to say about it. >>>>>> >>>>>> - Andrew >>>>>> >>>>>> -- >>>>>> Andrew Kofink >>>>>> akofink@redhat.com >>>>>> IRC: akofink >>>>>> Associate Software Engineer >>>>>> Red Hat Satellite >>>>>> >>>>>> -- >>>>>> You received this message because you are subscribed to the Google >>>>>> Groups "foreman-dev" group. >>>>>> To unsubscribe from this group and stop receiving emails from it, send >>>>>> an email to foreman-dev+unsubscribe@googlegroups.com. >>>>>> For more options, visit https://groups.google.com/d/optout. >>>>>> >>>>> >>>>> -- >>>>> You received this message because you are subscribed to the Google >>>>> Groups "foreman-dev" group. >>>>> To unsubscribe from this group and stop receiving emails from it, send >>>>> an email to foreman-dev+unsubscribe@googlegroups.com. >>>>> For more options, visit https://groups.google.com/d/optout. >>>>> >>>> >>>> -- >>>> You received this message because you are subscribed to the Google Groups >>>> "foreman-dev" group. >>>> To unsubscribe from this group and stop receiving emails from it, send an >>>> email to foreman-dev+unsubscribe@googlegroups.com. >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> >>> >>> >>> -- >>> Andrew Kofink >>> akofink@redhat.com >>> IRC: akofink >>> Associate Software Engineer >>> Red Hat Satellite >>> >>> -- >>> You received this message because you are subscribed to the Google Groups >>> "foreman-dev" group. >>> To unsubscribe from this group and stop receiving emails from it, send an >>> email to foreman-dev+unsubscribe@googlegroups.com. >>> For more options, visit https://groups.google.com/d/optout. >>> >> >> -- >> You received this message because you are subscribed to the Google Groups "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout.
The greasmonkey script works great! Really helpful, thanks for sharing. For
those who are wondering (like I was), it requires the greasemonkey browser
plugin:
https://addons.mozilla.org/en-US/firefox/addon/greasemonkey/ or
ttps://
That being said, I don't think we should have developers relying on a
script to have links to issues on a PR, I think we should have a way of
making that link available to everyone like Andrew suggested.
-John
John Mitsch
Red Hat Engineering
(860)-967-7285
irc: jomitsch
··· On Fri, Apr 7, 2017 at 4:17 AM, Ivan Necas wrote:
Ivan Necas inecas@redhat.com writes:
Walden Raines wraines@redhat.com writes:
do
it.
I put it in the message itself because I think it’s useful to have
there in
github.
prprocessor scope), I’m using Tomas’s grease monkey script and has been
https://gist.github.com/tstrachota/012d1518a08d5a9d441f
– Ivan
– Ivan
Walden
every
commit
John Mitsch
Red Hat Engineering
irc: jomitsch
On Thu, Apr 6, 2017 at 3:05 PM, Andrew Kofink akofink@redhat.com > >>>>> wrote:
links to
  • Andrew
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
send
send
Groups
send an
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
Groups
an
I agree, it would be useful for everyone. +1 if it won't generate extra mail
notification, +0.5 if it will :slight_smile:
··· On pátek 7. dubna 2017 14:35:41 CEST John Mitsch wrote: > The greasmonkey script works great! Really helpful, thanks for sharing. For > those who are wondering (like I was), it requires the greasemonkey browser > plugin: > > https://addons.mozilla.org/en-US/firefox/addon/greasemonkey/ or > > ttps:// > chrome.google.com/webstore/detail/tampermonkey/dhdgffkkebhmkfjojejmpbldmpobf > kfo?hl=en > > > That being said, I don't think we should have developers relying on a > script to have links to issues on a PR, I think we should have a way of > making that link available to everyone like Andrew suggested.
Marek
-John
John Mitsch
Red Hat Engineering
(860)-967-7285
irc: jomitsch
do
it.
there in
github.
– Ivan
– Ivan
Walden
On Thu, Apr 6, 2017 at 5:33 PM, Andrew Kofink akofink@redhat.com > > > > wrote:
every
On Thu, Apr 6, 2017 at 5:24 PM, Walden Raines wraines@redhat.com > > > > wrote:
commit
On Thu, Apr 6, 2017 at 4:18 PM, John Mitsch jomitsch@redhat.com > > > > wrote:
John Mitsch
Red Hat Engineering
irc: jomitsch
On Thu, Apr 6, 2017 at 3:05 PM, Andrew Kofink akofink@redhat.com > > >>>>> > > >>>>> wrote:
it’s
links to
  • Andrew
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
send
send
Groups
send an
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
Groups
an
While we're talking about modifying PrProcessor, some of the automatic
and requested task options in the MIQ bot are pretty cool - maybe we
should steal^W copy those in? :P. I can definitely see uses for
add/remove labels, at least.
https://github.com/ManageIQ/miq_bot?#automatic-tasks
Greg
··· -- IRC / Twitter: @gwmngilfen Diaspora: gwmngilfen@joindiaspora.com
I have made the change to amend the body of the pull request with the links
to the issues, which shouldn't send a new notification/email. This will be
a per-repo configuration. If you'd like for a repository to be included in
the change, please let me know via email, or comment on the pull request
<https://github.com/theforeman/prprocessor/pull/59>. I already added
katello/katello, katello/hammer-cli-csv, and katello/hammer-cli-katello.
  • Andrew
··· On Mon, Apr 10, 2017 at 7:23 AM, Greg Sutcliffe wrote:
While we’re talking about modifying PrProcessor, some of the automatic
Greg
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
Greg,
If you would like to start a discussion for inclusion of MIQ bot, please
start a new thread. :slight_smile:
Greg
Andrew Kofink
akofink@redhat.com
IRC: akofink
Red Hat Satellite
Will do :slight_smile:
+1 to amending the original text and see how that feels in practice.
··· On Mon, Apr 10, 2017 at 10:38:11AM -0400, Andrew Kofink wrote: > I have made the change to amend the body of the pull request with the links > to the issues, which shouldn't send a new notification/email. This will be > a per-repo configuration. If you'd like for a repository to be included in > the change, please let me know via email, or comment on the pull request > . I already added > katello/katello, katello/hammer-cli-csv, and katello/hammer-cli-katello. > > - Andrew > > On Mon, Apr 10, 2017 at 7:23 AM, Greg Sutcliffe > wrote: > > > While we're talking about modifying PrProcessor, some of the automatic > > and requested task options in the MIQ bot are pretty cool - maybe we > > should steal^W copy those in? :P. I can definitely see uses for > > add/remove labels, at least. > > > > https://github.com/ManageIQ/miq_bot?#automatic-tasks
