Luna nightly pipeline failed:
https://ci.theforeman.org/job/luna-nightly-rpm-pipeline/146/
foreman-luna-upgrade-nightly-test (failed)
foreman-luna-nightly-test (passed)
bats are failing on upgrade:
31 | install package locally | |
# (from function `tIsRedHatCompatible’ in file os_helper.bash, line 4, | ||
# from function `tPackageInstall’ in file os_helper.bash, line 89, | ||
# in test file fb-content-katello.bats, line 199) | ||
# `tPackageInstall walrus-0.71 && tPackageExists walrus-0.71’ failed | ||
# Loaded plugins: enabled_repos_upload, fastestmirror, package_upload, product-id, | ||
# : search-disabled-repos, subscription-manager | ||
# 1 local certificate has been deleted. | ||
# Loading mirror speeds from cached hostfile | ||
# * base: mirror4.ci.centos.org | ||
# * centos-sclo-rh: mirror4.ci.centos.org | ||
# * epel: mirror.ci.centos.org | ||
# * extras: mirror4.ci.centos.org | ||
# * updates: mirror4.ci.centos.org | ||
# No package walrus-0.71 available. | ||
# Error: Nothing to do | ||
# Uploading Enabled Repositories Report | ||
# Loaded plugins: fastestmirror, product-id, subscription-manager | ||
32 | check available errata | |
# (in test file fb-content-katello.bats, line 207) | ||
# `hammer host errata list --host $HOSTNAME | grep ‘RHEA-2012:0055’’ failed | |
35 | install package remotely (katello-agent) | |
# (from function `tPackageExists’ in file os_helper.bash, line 80, | ||
# in test file fb-content-katello.bats, line 225) | ||
# `tPackageExists gorilla’ failed | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.0/1, 0%, elapsed: 00:00:00 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.1/s, elapsed: 00:00:02, ETA: 00:00:11 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:09, ETA: 00:00:23 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:12, ETA: 00:00:35 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:14, ETA: 00:00:47 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:16, ETA: 00:00:59 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:18, ETA: 00:01:11 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:20 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:23 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:25 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:27 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:29 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:32 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:34 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:36 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:38 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:41 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:43 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:45 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:47 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:49 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:52 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:54 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:56 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:00:58 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:00 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:03 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:05 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:07 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:09 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:12 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:14 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:16 | ||
# Task be56f753-149e-4920-835f-2db8173b203a running: 0.16666666666666666/1, 16%, 0.0/s, elapsed: 00:01:18 | ||
# Task be56f753-149e-4920-835f-2db8173b203a warning: 1.0/1, 100%, 0.0/s, elapsed: 00:01:21 | ||
# Error: :gorilla--.: No package(s) available to install | ||
# :gorilla--.: No package(s) available to install | ||
36 | install errata remotely (katello-agent) | |
# in test file fb-content-katello.bats, line 231) | ||
# `tPackageExists walrus-5.21’ failed | ||
# Could not apply errata: | ||
# Couldn’t find errata ids ‘RHEA-2012:0055’ |
4 | content is available from proxy | |
# (in test file fb-proxy.bats, line 31) | ||
# `URL2=“http://${PROXY_HOSTNAME}/pulp/repos/${ORGANIZATION_LABEL}/Library/${CONTENT_VIEW_LABEL}/custom/${PRODUCT_LABEL}/${YUM_REPOSITORY_LABEL}/Packages/w/walrus-0.71-1.noarch.rpm”’ failed | ||
# % Total % Received % Xferd Average Speed Time Time Time Current | ||
# Dload Upload Total Spent Left Speed | ||
# curl: (22) The requested URL returned error: 404 Not Found | ||
