The subscriptions from RHEL have been refreshed from the beginning of 2022 and after re-adding the subscriptions to Foreman i have problem by refreshing the manifest.
Errors:
Error message: the server returns an error
HTTP status code: 404
Response headers: {“date”=>“Mon, 10 Jan 2022 09:57:42 GMT”, “server”=>“gunicorn”, “content-type”=>“application/json”,
“vary”=>“Accept,Cookie”, “allow”=>“GET, PUT, PATCH, DELETE, HEAD, OPTIONS”, “x-frame-options”=>“SAMEORIGIN”, “content-length”=>“23”,
“correlation-id”=>“e7e56936-8d12-46d0-976e-944c59297eba”, “access-control-expose-headers”=>“Correlation-ID”, “via”=>“1.1 foreman.com01.comcorp.lan”, “connection”=>“close”}
Response body: {“detail”:“Not found.”}
Thanks for posting your issue here.
Could you please provide the details with steps to re-produce your issue?
How did you refresh your subscriptions from HREL?
How did you re-add the subscriptions to Foreman?
Thanks.
the old subscriptions have expired 31.12.2021, we bought new subscriptions and therefore i went to red hat customer portal–>Subscription Allocations–>Our Foreman server and added the subscriptions.
Then i have refreshed the Manifest on Foreman and after that i am getting that warning.
I have deleted the repository with ID 1885 and Manifest refresh went through without any warning or error. Now i have the problem that i do not see the redhat repositories on the hosts?
The RHEL subscription is added and the hosts are getting all other repos only the RHEL not. I already did:
yum clean all
rm -fr /var/cache/yum/*
subscription-manager refresh
Thanks…it is working now but first i had to delete all my content views with RHEL repos → disable the repo → enable repo → sync product → create content view.
