Hi group,
I have found a problem trying to match the OS in the filters, ive tried
many things and i dont know what its happening, those are my examples:
os=CentOS
os="CentOS 6.7"
os="CentOS6.7"
Where is foreman getting this param from?¿ i thought it is from os facter
but it isnt:
[root@centos-test ~]# facter | grep CentOS
lsbdistdescription => CentOS release 6.7 (Final)
lsbdistid => CentOS
operatingsystem => CentOS
os => {"name"=>"CentOS", "lsb"=>{"distid"=>"CentOS",
"minordistrelease"=>"7", "distcodename"=>"Final", "majdistrelease"=>"6",
"distrelease"=>"6.7",
"release"=>":base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch",
"distdescription"=>"CentOS release 6.7 (Final)"},
"release"=>{"full"=>"6.7", "major"=>"6", "minor"=>"7"}, "family"=>"RedHat"}
Any suggestions?¿
Thanks
in which filters do you try to match it? There should be auto-completion that
usually helps, e.g. for filter on Host resource "os = CentOS" should work. The
name of OS is usually updated by the value from facter but there's a custom
logic in Foreman which combines multiple values from facter and does some
conversions.
Hope this helps
Marek
On Thursday 17 of March 2016 02:58:15 Fran Rodríguez wrote:
Hi group,
os=CentOS
os=“CentOS 6.7”
os=“CentOS6.7”
but it isnt:
lsbdistid => CentOS
os => {“name”=>“CentOS”, “lsb”=>{“distid”=>“CentOS”,
“minordistrelease”=>“7”, “distcodename”=>“Final”, “majdistrelease”=>“6”,
“distrelease”=>“6.7”,
“release”=>“:base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch”,
“distdescription”=>“CentOS release 6.7 (Final)”},
“release”=>{“full”=>“6.7”, “major”=>“6”, “minor”=>“7”}, “family”=>“RedHat”}
Any suggestions?¿
Thanks
Hi Marek,
Thanks for the answer, im trying to use it here, in the smart class
parameter(see attachment). It seems that the os facter doesnt come from
foreman yaml.
Cheers
On Thursday, 17 March 2016 11:17:18 UTC+1, Marek Hulán wrote:
> Hello,
> that
> work. The
> custom
> conversions.
> Hope this helps
> Marek
> > Hi group,
> > os=CentOS
> > os="CentOS 6.7"
> > os="CentOS6.7"
> facter
> > but it isnt:
> > lsbdistid => CentOS
> "family"=>"RedHat"}
> > Any suggestions?¿
> > Thanks
The matcher uses the os's full name which in your case looks like "CentOS
6.7".
In the screenshot you used: "os=CentOS".
Can you try: os="CentOS 6.7" (put the double quotes after the os=) ?
Ori
On Thu, Mar 17, 2016 at 1:43 PM, Fran Rodríguez wrote:
Hi Marek,
foreman yaml.
Cheers
that
usually helps, e.g. for filter on Host resource “os = CentOS” should
work. The
name of OS is usually updated by the value from facter but there’s a
custom
conversions.
Hope this helps
Marek
Hi group,
os=CentOS
os=“CentOS 6.7”
os=“CentOS6.7”
facter
but it isnt:
lsbdistid => CentOS
“family”=>“RedHat”}
Any suggestions?¿
Thanks
“Foreman users” group.
Hi Ori,
Thanks for the answer but i already did, there is one of my test in the
screenshot.
Cheers
On Thursday, 17 March 2016 13:26:39 UTC+1, Ori Rabin wrote:
> Hi,
> 6.7".
> Thanks,
> Ori
> On Thu, Mar 17, 2016 at 1:43 PM, Fran Rodríguez > wrote:
>> Hi Marek,
>> foreman yaml.
>> Cheers
>>> Hello,
>>> that
>>> work. The
>>> custom
>>> some
>>> conversions.
>>> Hope this helps
>>> Marek
>>> > Hi group,
>>> tried
>>> > os=CentOS
>>> > os="CentOS 6.7"
>>> > os="CentOS6.7"
>>> facter
>>> > but it isnt:
>>> > lsbdistid => CentOS
>>> "family"=>"RedHat"}
>>> > Any suggestions?¿
>>> > Thanks
>> "Foreman users" group.
>> Visit this group at https://groups.google.com/group/foreman-users.
I cant find the solution, how can i setup the os?¿ i think this is because
the value doesnt came from yaml.
Cheers.
On Thursday, 17 March 2016 19:36:14 UTC+1, Fran Rodríguez wrote:
> Hi Ori,
> screenshot.
> Cheers
>> Hi,
>> 6.7".
>> Thanks,
>> Ori
>> On Thu, Mar 17, 2016 at 1:43 PM, Fran Rodríguez >> wrote:
>>> Hi Marek,
>>> foreman yaml.
>>> Cheers
>>>> Hello,
>>>> work. The
>>>> custom
>>>> some
>>>> conversions.
>>>> Hope this helps
>>>> Marek
>>>> > Hi group,
>>>> tried
>>>> examples:
>>>> > os=CentOS
>>>> > os="CentOS 6.7"
>>>> > os="CentOS6.7"
>>>> facter
>>>> > but it isnt:
>>>> > lsbdistid => CentOS
>>>> "family"=>"RedHat"}
>>>> > Any suggestions?¿
>>>> > Thanks
>>> Groups "Foreman users" group.
>>> an email to foreman-user...@googlegroups.com.
>>> To post to this group, send email to forema...@googlegroups.com.
What i want to do it is this:
http://www.theforeman.org/manuals/1.8/index.html#4.2.6SmartMatchers
But i dont know why the os doesnt match, is there any way to debug this?¿
Now im using what the foreman doc says.
Cheers.
> Cheers.
>> Hi Ori,
>> screenshot.
>> Cheers
>>> Hi,
>>> "CentOS 6.7".
>>> Thanks,
>>> Ori
>>> On Thu, Mar 17, 2016 at 1:43 PM, Fran Rodríguez >>> wrote:
>>>> Hi Marek,
>>>> foreman yaml.
>>>> Cheers
>>>>> Hello,
>>>>> work. The
>>>>> custom
>>>>> some
>>>>> conversions.
>>>>> Hope this helps
>>>>> Marek
>>>>> > Hi group,
>>>>> tried
>>>>> examples:
>>>>> > os=CentOS
>>>>> > os="CentOS 6.7"
>>>>> > os="CentOS6.7"
>>>>> facter
>>>>> > but it isnt:
>>>>> > lsbdistid => CentOS
>>>>> "family"=>"RedHat"}
>>>>> > Any suggestions?¿
>>>>> > Thanks
Hi group,
I think i found a bug with this, the fact which forman has it is shown like
this:
facts.os =
"familyRedHatlsbminordistrelease7distcodenameFinalmajdistrelease6distrelease6.7release:base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarchdistdescriptionCentOS
release 6.7 (Final)distidCentOSreleaseminor7major6full6.7nameCentOS"
Any one know about this?
Cheers.
> Cheers.
>> because the value doesnt came from yaml.
>> Cheers.
>>> Hi Ori,
>>> screenshot.
>>> Cheers
>>>> Hi,
>>>> "CentOS 6.7".
>>>> Thanks,
>>>> Ori
>>>> On Thu, Mar 17, 2016 at 1:43 PM, Fran Rodríguez >>>> wrote:
>>>>> Hi Marek,
>>>>> foreman yaml.
>>>>> Cheers
>>>>>> Hello,
>>>>>> work. The
>>>>>> custom
>>>>>> some
>>>>>> conversions.
>>>>>> Hope this helps
>>>>>> Marek
>>>>>> > Hi group,
>>>>>> tried
>>>>>> examples:
>>>>>> > os=CentOS
>>>>>> > os="CentOS 6.7"
>>>>>> > os="CentOS6.7"
>>>>>> facter
>>>>>> > but it isnt:
>>>>>> > lsbdistid => CentOS
>>>>>> "family"=>"RedHat"}
>>>>>> > Any suggestions?¿
>>>>>> > Thanks
For the matchers, I'll repeat Ori's point - you have a bad match there.
Compare:
Your screenshot: "os=Centos"
Ori suggestion: os="CentOS 6.7"
These things are not the same - the matcher text is different, and the
quotes are in the wrong place. Can you confirm you've tried her suggestion?
For the facts, that looks like a representation of structured facts mashed
into a string. What version of Facter are you using, and where did you see
that string?
Hi Greg,
Im using the Ori's suggestion from beginning althought i tried other
options and its also the foreman's doc said. The version of the facter
[root@centos-test ~]# facter -v
2.4.6
and where im seeing that in the fact values of the host. Here one example
from one of my Debian host:
facts.os = "{"name"=>"Debian", "family"=>"Debian",
"release"=>{"major"=>"7", "minor"=>"6", "full"=>"7.6"},
"lsb"=>{"distcodename"=>"wheezy", "distid"=>"Debian",
"distdescription"=>"Debian GNU/Linux 7.6 (wheezy)", "distrelease"=>"7.6",
"majdistrelease"=>"7", "minordistrelease"=>"6"}}"
Cheers.
> Compare:
> that string?
The "os" matcher will not work against a fact called "os" because
internally, Foreman has an attribute called "os". This takes precedence
over the fact name. (Besides the problem that matchers won't work
properly with structured facts.)
It will only work against Foreman's description of the OS, which should
be the same string shown on the hosts or operating systems list.
On 18/03/16 13:28, Fran Rodríguez wrote:
> Hi Greg,
> 2.4.6
> example from one of my Debian host:
> "distrelease"=>"7.6", "majdistrelease"=>"7", "minordistrelease"=>"6"}}"
Dominic Cleal
dominic@cleal.org
Hi Dominic,
Thanks for the answer, then i dont understand what its happening because my
OS description is the same that in the matcher os = "CentOS 6.7", you can
see it on the attach.
Chees.
> > Hi Greg,
> > 2.4.6
> Dominic Cleal
> dom...@cleal.org
Hi group,
Thats still not working so i think it is a bug but i dont know how to debug
the problem.
Any suggestions?¿
Cheers.
On Friday, 18 March 2016 17:16:49 UTC+1, Fran Rodríguez wrote:
> Hi Dominic,
> my OS description is the same that in the matcher os = "CentOS 6.7", you
> can see it on the attach.
> Chees.
>> > Hi Greg,
>> > 2.4.6
>> Dominic Cleal
>> dom...@cleal.org
you can use: foreman-rake console
search for your os and check what is it's title, that would be what you
need to use in the matcher.
So probably run: Operatingsystem.where(:name => 'CentOS', :major => '6',
:minor => '7').first.title.
Also - you only have one matcher for this parameter right? on the os?
and what do you see in the host's yaml? the default value of the parameter?
Ori
On Tue, Mar 22, 2016 at 12:37 PM, Fran Rodríguez wrote:
Hi group,
debug the problem.
Any suggestions?¿
Cheers.
Hi Dominic,
my OS description is the same that in the matcher os = “CentOS 6.7”, you
Chees.
Hi Greg,
Im using the Ori’s suggestion from beginning althought i tried other
options and its also the foreman’s doc said. The version of the facter
2.4.6
facts.os = “{“name”=>“Debian”, “family”=>“Debian”,
“release”=>{“major”=>“7”, “minor”=>“6”, “full”=>“7.6”},
“lsb”=>{“distcodename”=>“wheezy”, “distid”=>“Debian”,
“distdescription”=>“Debian GNU/Linux 7.6 (wheezy)”,
“distrelease”=>“7.6”, “majdistrelease”=>“7”,
“minordistrelease”=>“6”}}”
The “os” matcher will not work against a fact called “os” because
internally, Foreman has an attribute called “os”. This takes precedence
over the fact name. (Besides the problem that matchers won’t work
It will only work against Foreman’s description of the OS, which should
Dominic Cleal
dom...@cleal.org
