Hi all, after going through an update to 1.19, the web login GUI seems to be presenting HTML that is out of sync with the assets on the system.
The [host]/users/login page has (for example):
<img src="/assets/login_logo-e0e51f6be894b40495960e63a76ccf95a61af08e282256e5aea1f3e0b05733ba.png" alt=“Login logo” />
whereas if I look at the RPM, it should be:
[root@centos httpd]# rpm -ql foreman|grep -i login_logo
/var/lib/foreman/public/assets/login_logo-bec03fb39f93256400cf13caba53f4da87f669d229e4c14e2b73de4d1805541b.png
I couldn’t see how the users/login page is (dynamically?) generated from the ruby source of /usr/share/foreman/app/views/users/login.html.erb
Is there something that I can do to regenerate / rebuild the asset reference in the ruby layer of things so that it refers to the correct assets that are in the foreman rpm?
I’m CentOS 7.5, foreman 1.19. I just went through a bunch of upgrades (incrementally) from 1.12 to 1.19 so I suspect something is a bit out of sync here, but I’m hoping it might be just some cache that I need to rebuild. Foreman is running just fine otherwise, web interface is all good and responsive, just something is generating the pages with the wrong asset references.
Anybody have any ideas?
