After the latest merge of code (from myself) to the prprocessor, labels are
not being applied to the katello/katello project. I am guessing there is an
error somewhere being thrown that prevents completion to that point. Can
someone with access to the prprocessor logs please check them to see if
there are errors being thrown?
NoMethodError - undefined method []' for nil:NilClass: /var/lib/openshift/53be8f9c5973caa7ad000a13/app-root/runtime/repo/redmine/issue.rb:26:in
release'
/var/lib/openshift/53be8f9c5973caa7ad000a13/app-root/runtime/repo/app.rb:44:in `block (2 levels) in <top (required)>'
I've pushed a possible fix to handle a missing release field (2cb3b8a),
hopefully that'll do the trick.
On 12/07/16 22:25, Eric D Helms wrote: > After the latest merge of code (from myself) to the prprocessor, labels > are not being applied to the katello/katello project. I am guessing > there is an error somewhere being thrown that prevents completion to > that point. Can someone with access to the prprocessor logs please check > them to see if there are errors being thrown?–
Dominic Cleal
dominic@cleal.org
Much appreciated – the labels appear to be back to normal.
Eric
On Wed, Jul 13, 2016 at 2:57 AM, Dominic Cleal wrote:On 12/07/16 22:25, Eric D Helms wrote:
them to see if there are errors being thrown?NoMethodError - undefined method `’ for nil:NilClass:
`release’/var/lib/openshift/53be8f9c5973caa7ad000a13/app-root/runtime/repo/app.rb:44:in
`block (2 levels) in <top (required)>’I’ve pushed a possible fix to handle a missing release field (2cb3b8a),
hopefully that’ll do the trick.–
Dominic Cleal
dominic@cleal.org–
“foreman-dev” group.
Eric D. Helms
Red Hat Engineering
Ph.D. Student - North Carolina State University
