I have some content hosts that I would prefer not be part of a content view.
How do I
“register” a host with foreman without adding it to a content view?
move a content-host to become a mere host?
At the moment, I have a set of ansible scripts that I run to localize after I clone a centos 7 virtual machine template. First it installs the katello-ca-consumer-latest.noarch.rpm file. Second it calls subscription manager to register with an activation key.
I would like both versions to be still able to use my foreman repositories, so the repo files will still need to reflect the foreman server. I have noticed this is only generated when I register with subscription manager with a key tied to a content view.
I am running
foreman 2.5.1
katello 4.1.0
At first this is for Centos 7, but I plan to expand this into other versions such as ubuntu and rocky.
Just to expand a bit-- With Katello installed, all hosts are also content hosts. There isn’t really a way to remove a host from the content hosts view and keep it in the all hosts view. We’re working on a new host detail page for a future version of Foreman & Katello that will combine the All Hosts and Content Hosts page, and hopefully make this a bit less confusing.
To do this, register the host using an activation key that does not have a content view attached. (e.g. set the environment to “Library” and content view to “Default Organization View.”) Alternatively, you can register the host without an activation key, and instead run subscription-manager register with your Foreman username and password.
Also keep in mind, activation keys are not retroactive – they only affect hosts at time of registration. Changes to activation keys after the fact will not affect the host unless you re-register. If you’d like to change a host’s content view, etc. without reregistering, this is totally possible using the web UI from the Content Host details page.
