Yes and no. You could probably use smart-proxy to configure DNS and DHCP
on remote machines (does not work for puppetmaster).
However, I don't think it will suit your needs. As smart-proxy can only
do authentication, but not authorization. So if you're allowed to talk
to smart-proxy, it will do whatever you want.
So yes, you can use smart-proxy that way and no, you probably don't want
to do it in a multi-tenant enviroment.
Regards,
Andreas
Am 28.01.2013 21:55, schrieb ryan wallner:
> *(VM)* <--> *(Foreman Smart-proxy)* <-->*(DHCP, DNS , Puppet) *<-- these
> services are running on multiple instances
> Can I use smart-proxy in this way?
Solvention Ltd. & Co. KG
St.-Sebastianus-Str. 5
51147 K�ln
Tel: +49 2203 989967-0
Fax: +49 2203 989967-9
http://www.solvention.de
mailto:info@solvention.de
Thanks andreas,
I may be looking for something other than the administrative tasks, while
this is a part of what I am after and will most likely deploy in this
fashion, the real service I may be after is that of what Dominic
Mentioned, something that can "handle the dhcp traffic itself"
Thanks for your response.
Ryan Wallner
Ryan.wallner@emc.com
EMC OCTO | NGDC
> Regards,
> Andreas
> 51147 K�ln
> mailto:in...@solvention.de
As a starting point, look at dhcrelay or the DHCP helper/delay functions
of most routers.
Dominic Cleal
Red Hat Engineering
On 29/01/13 19:06, ryan wallner wrote:
Thanks andreas,
while this is a part of what I am after and will most likely deploy in
this fashion, the real service I may be after is that of what Dominic
Mentioned, something that can “handle the dhcp traffic itself”
Ryan Wallner
EMC OCTO | NGDC
these
DHCP
want
Regards,
Andreas
51147 K�ln
mailto:in...@solvention.de <javascript:>
Groups “foreman-dev” group.
an email to foreman-dev+unsubscribe@googlegroups.com.
Just posted again right before you mentioned this.
> of most routers.
> Dominic Cleal
> Red Hat Engineering
> > Thanks andreas,
> > Ryan Wallner
> > Ryan.w...@emc.com
> > EMC OCTO | NGDC
> > these
> > DHCP
> only
> talk
> > want
> > Regards,
> > Andreas
> > 51147 K�ln
> > You received this message because you are subscribed to the Google
> > Groups "foreman-dev" group.
> > an email to foreman-dev...@googlegroups.com .
