Hello all
When i try to register one host via the ansible fact to foreman, i got multiple recording for only one host
Is it possible to have only one recording for each host ?
Thank you !
Hello all
Thank you !
Can you specify what versions are you on?
And what steps did you do to register this host to foreman?
Thanks for you attention, i am running via ansible this playbook to register my hosts to foreman :
ansible-playbook foreman.yml -b -K
hosts: qualifpart2
become: true
gather_facts: yestasks:
- name: Distribution
debug: msg=“{{ ansible_distribution }}”
ansible --version
ansible 2.9.23
Version 3.9.1
About the module of foreman →
| foreman-tasks | The goal of this plugin is to unify the way of showing task statuses across the Foreman instance. It defines Task model for keeping the information about the tasks and Lock for assigning the tasks to resources. The locking allows dealing with preventing multiple colliding tasks to be run on the same resource. It also optionally provides Dynflow infrastructure for using it for managing the tasks. | Ivan Nečas | 9.0.4 |
| foreman_ansible | Ansible integration with Foreman | Daniel Lobato Garcia | 13.0.3 |
| foreman_puppet | Allow assigning Puppet environments and classes to the Foreman Hosts. | Ondřej Ezr and Shira Maximov | 6.2.0 |
| foreman_remote_execution | A plugin bringing remote execution to the Foreman, completing the config management functionality with remote management functionality. | Foreman Remote Execution team | 12.0.5 |
I remember a similar problem in the past where the report created a host with only the hostname and foreman added the domain part, so every time the host got reported it was created as a new one as it did not match the previous ones.
But here it looks like it’s the same domain, correct @peutre?
yes that’s the same domain for each server
