Hi, I´m new to Foreman and Puppet, I´ve deployed Foreman and upgraded it to
15, it´s working right for NTP class (as shown on tutorials).
I´m trying to configure cron on clients, but I don´t know how to do it,
which Smart Parameters should I modify and where to add the job to deploy
to clients. I´ve looked on the web but nothing found. I´m using
rmueller/cron from forge puppet. Would anyone help me please?
Hi
It might be best if you post your class to debug…
On Friday, June 23, 2017 at 9:35:50 AM UTC+1, Hernan Vera wrote: > > Hi, I´m new to Foreman and Puppet, I´ve deployed Foreman and upgraded it > to 15, it´s working right for NTP class (as shown on tutorials). > I´m trying to configure cron on clients, but I don´t know how to do it, > which Smart Parameters should I modify and where to add the job to deploy > to clients. I´ve looked on the web but nothing found. I´m using > rmueller/cron from forge puppet. Would anyone help me please? > > > > > > > > > > > >You need to use the cron::job class. Looks like you're using the cron
class. The documentation for this seems pretty clear?
