I wanted to try the new version of katello-capsule:
Installed Repos:
yum -y localinstall http://fedorapeople.org/groups/katello/releases/yum/3.2/katello/el7/x86_64/katello-repos-latest.rpm
yum -y localinstall http://yum.theforeman.org/releases/1.13/el7/x86_64/foreman-release.rpm
rpm -Uvh https://yum.puppetlabs.com/puppetlabs-release-pc1-el-7.noarch.rpm (to provide puppet 4 from during installation)
yum -y localinstall http://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
yum -y install foreman-release-scl
yum install -y katello-capsule
foreman-installer --scenario capsule --help
/usr/share/gems/gems/kafo-0.9.8/lib/kafo/puppet_module.rb:69:in `parse': No Puppet module parser is installed and no cache of the file /usr/share/katello-installer-base/modules/certs/manifests/init.pp is available. Please check debug logs and install optional dependencies for the parser. (Kafo::ParserError)
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/configuration.rb:89:in
block in modules' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/configuration.rb:89:in
map'
modules' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/configuration.rb:189:in
params'
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/configuration.rb:199:in
preset_defaults_from_puppet' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:270:in
set_parameters'
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:99:in
initialize' from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in
new'
from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in run' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:154:in
run'
from /usr/sbin/foreman-installer:8:in `<main>'
rpm -qa | grep -i parser
rubygem-kafo_parsers-0.1.2-1.el7.noarch
yum-metadata-parser-1.1.4-10.el7.x86_64
Architektur : noarch
Version : 0.1.2
Ausgabe : 1.el7
Greets,
Denis
I am having the same issue. did you find a fix?
> Installed Repos:
> `block in modules'
> `map'
> `modules'
> `params'
> `preset_defaults_from_puppet'
> `set_parameters'
> `initialize'
> from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in `new'
> from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in `run'
> `run'
> from /usr/sbin/foreman-installer:8:in `'
> Version : 0.1.2
> Ausgabe : 1.el7
> Greets,
> Denis
Have you tried:
puppet resource package yard provider=puppet_gem
I am working on this now. I don't have an ETA yet but I hope to have a
fix soon.
Installed Repos:
/usr/share/gems/gems/kafo-0.9.8/lib/kafo/puppet_module.rb:69:in `parse’: No Puppet module parser is installed and no cache of the file /usr/share/katello-installer-base/modules/certs/manifests/init.pp is available. Please check debug logs and install optional dependencies for the parser. (Kafo::ParserError)
map’
params’
set_parameters’
new’
run’
from /usr/sbin/foreman-installer:8:in `’
Version : 0.1.2
Ausgabe : 1.el7
Greets,
Denis
I meant to say:
puppet resource package puppet-strings provider=puppet_gem
On Tuesday, 8 November 2016 15:37:13 UTC, Rob Sanders wrote:
> Have you tried:
After applying your solution:
/usr/share/gems/gems/rdoc-4.0.0/lib/rdoc/markup/parser.rb:430:in initialize': no implicit conversion of Hash into String (TypeError) from /usr/share/gems/gems/rdoc-4.0.0/lib/rdoc/markup/parser.rb:430:in
new'
setup_scanner' from /usr/share/gems/gems/rdoc-4.0.0/lib/rdoc/markup/parser.rb:450:in
tokenize'
from /usr/share/gems/gems/rdoc-4.0.0/lib/rdoc/markup/parser.rb:60:in parse' from /usr/share/gems/gems/rdoc-4.0.0/lib/rdoc/markup.rb:751:in
parse'
from /usr/share/gems/gems/kafo_parsers-0.1.2/lib/kafo_parsers/doc_parser
.rb:19:in initialize' from /usr/share/gems/gems/kafo_parsers-0.1.2/lib/kafo_parsers/puppet_strings_module_parser.rb:100:in
new'
from
docs' from /usr/share/gems/gems/kafo_parsers-0.1.2/lib/kafo_parsers/ puppet_strings_module_parser.rb:13:in
parse'
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/puppet_module.rb:71:in parse' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/configuration.rb:89:in
block in modules'
map' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/configuration.rb:89:in
modules'
params' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/configuration.rb:199:in
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:270:in set_parameters' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:99:in
initialize'
from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in new' from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in
run'
run' from /usr/sbin/foreman-installer:8:in
<main>'
Am Dienstag, 8. November 2016 16:40:52 UTC+1 schrieb Rob Sanders:
> I meant to say:
> https://github.com/puppetlabs/puppet-strings
>> Have you tried:
This was fixed and will be available in the 3.2 final GA release, which
will be released next week.
Here is the bug for reference: Bug #17124: No Puppet module parser is installed - Katello - Foreman
Thanks for bringing it to our attention.
John Mitsch
Red Hat Engineering
(860)-967-7285
irc: jomitsch
On Fri, Nov 11, 2016 at 7:17 AM, 'Denis Müller' via Foreman users < foreman-users@googlegroups.com> wrote:
new’
tokenize’
parse’
doc_parser.rb:19:in initialize' from /usr/share/gems/gems/kafo_parsers-0.1.2/lib/kafo_ parsers/puppet_strings_module_parser.rb:100:in
new’
parsers/puppet_strings_module_parser.rb:100:in docs' from /usr/share/gems/gems/kafo_parsers-0.1.2/lib/kafo_parsers/ puppet_strings_module_parser.rb:13:in
parse’
block in modules’
modules’
preset_defaults_from_puppet’
initialize’
run
I meant to say:
Have you tried:
"Foreman users" group.
Hello John
With 3.2 still the bug. There are work around?
RH 7.3
Katello 3.2 upgrade (3.1)
Puppet 4.8
Thanks
> Here is the bug for reference: http://projects.theforeman.org/issues/17124
> John Mitsch
> Red Hat Engineering
> (860)-967-7285
> irc: jomitsch
> On Fri, Nov 11, 2016 at 7:17 AM, 'Denis Müller' via Foreman users < > forema...@googlegroups.com > wrote:
>> /usr/share/gems/gems/rdoc-4.0.0/lib/rdoc/markup/parser.rb:430:in `initialize':
>> `new'
>> `setup_scanner'
>> `tokenize'
>> from /usr/share/gems/gems/rdoc-4.0.0/lib/rdoc/markup/parser.rb:60:in `
>> parse'
>> from /usr/share/gems/gems/rdoc-4.0.0/lib/rdoc/markup.rb:751:in `parse'
>> doc_parser.rb:19:in `initialize'
>> from
>> `new'
>> from
>> `docs'
>> puppet_strings_module_parser.rb:13:in `parse'
>> from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/puppet_module.rb:71:in `
>> parse'
>> `block in modules'
>> `map'
>> from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/configuration.rb:89:in `
>> modules'
>> `params'
>> from
>> /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:270:in `
>> set_parameters'
>> `initialize'
>> `new'
>> run'
>> from
>> /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:154:in `run'
>>> I meant to say:
>>>> Have you tried:
>> Visit this group at https://groups.google.com/group/foreman-users.
for me the workaround from BZ#1381081 Comment 3 works and is still
needed for katello 3.2.0.
https://bugzilla.redhat.com/show_bug.cgi?id=1381081#c3
Best regards
Patrick
On 17.11.2016 08:22, Ismael Puerto wrote:
> Hello John
> RH 7.3
> Puppet 4.8
> Thanks
Lobster SCM GmbH, Hindenburgstraße 15, D-82343 Pöcking HRB 178831,
Amtsgericht München Geschäftsführer: Dr. Martin Fischer, Rolf Henrich
this is being tracked as Bug #17376: unable to install katello with puppet 4 - Katello - Foreman, I
am working on it now.
>> Hello John
>> RH 7.3
>> Puppet 4.8
>> Thanks
> Hi,
Tried the fix, but getting another error, see capsule.log
/usr/share/katello-installer-base/hooks/post/11-create_sslconf.rb:6:in initialize': No such file or directory - /etc/httpd/conf.d/ssl.conf (Errno::ENOENT) from /usr/share/katello-installer-base/hooks/post/11-create_sslconf.rb:6:in
from
block (4 levels) in load' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/hooking.rb:34:in
instance_eval'
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/hooking.rb:34:in block (4 levels) in load' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/hook_context.rb:13:in
instance_exec'
execute' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/hooking.rb:51:in
block in
execute'
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/hooking.rb:49:in each' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/hooking.rb:49:in
execute'
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:454:in block in run_installation' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/exit_handler.rb:27:in
call'
exit' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:160:in
exit'
from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:453:in
run_installation' from /usr/share/gems/gems/kafo-0.9.8/lib/kafo/kafo_configure.rb:147:in
execute'
from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:68:in run' from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in
run'
<main>'
