sarang
March 15, 2023, 7:53am
1
I have created product from console.
Not able to add Local repo to product. getting error ‘SSL_read:tlsv1 alert unknown ca’
I will attach screenshot of settings.
Repository should get added.
sarang
March 15, 2023, 4:29pm
3
The original issue with error ‘SSL_read:tlsv1 alert unknown ca’ is resolved.
Changed option ‘SSLVerifyClient’ in file ‘/etc/httpd/conf.d/05-foreman-ssl.conf’
Original: SSLVerifyClient optional
After change: SSLVerifyClient optional_no_ca
Still not able to add repository.
New error: “Authentication credentials were not provided.”
Production.log: (Let me know if you need entire production log
5a73ae2e | /usr/share/gems/gems/puma-5.6.5/lib/puma/request.rb:76:in handle_request' 5a73ae2e | /usr/share/gems/gems/puma-5.6.5/lib/puma/server.rb:443:in process_client’
5a73ae2e | /usr/share/gems/gems/puma-5.6.5/lib/puma/thread_pool.rb:147:in block in spawn_thread' 5a73ae2e | [ concurrent-ruby ] 2023-03-15T08:58:26 [I|bac|5a73ae2e] Task {label: Actions::Katello::Repository::CreateRoot, id: d4ee3439-3b50-449d-9e61-cb6298bcc5b0, execution_plan_id: 398b093c-d77c-4421-aae8-ad0b45979c3b} state changed: stopped result: error 2023-03-15T08:58:26 [E|app|5a73ae2e] Katello::Errors::Pulp3Error: Authentication credentials were not provided. 5a73ae2e | /usr/share/gems/gems/katello-4.7.2/app/services/katello/pulp3/service_common.rb:62:in rescue in reformat_api_exception’
5a73ae2e | /usr/share/gems/gems/katello-4.7.2/app/services/katello/pulp3/service_common.rb:57:in reformat_api_exception' 5a73ae2e | /usr/share/gems/gems/katello-4.7.2/app/services/katello/pulp3/service_common.rb:11:in create_remote’
5a73ae2e | /usr/share/gems/gems/katello-4.7.2/app/services/katello/pulp3/repository.rb:71:in `create_remote’
sarang
March 16, 2023, 10:01am
4
Important details that I missed:
rubygem-foreman_column_view-0.4.0-6.fm3_3.el8.noarch
foreman-vmware-3.4.1-1.el8.noarch
foreman-selinux-3.4.1-1.el8.noarch
rubygem-hammer_cli_foreman_remote_execution-0.2.2-1.fm3_0.el8.noarch
foreman-debug-3.4.1-1.el8.noarch
foreman-dynflow-sidekiq-3.4.1-1.el8.noarch
rubygem-foreman_maintain-1.2.1-1.el8.noarch
rubygem-foreman_discovery-21.0.4-1.fm3_4.el8.noarch
foreman-installer-katello-3.4.1-1.el8.noarch
foreman-proxy-3.4.1-1.el8.noarch
rubygem-hammer_cli_foreman-3.4.0-1.el8.noarch
foreman-installer-3.4.1-1.el8.noarch
rubygem-hammer_cli_foreman_tasks-0.0.17-1.fm3_2.el8.noarch
foreman-3.4.1-1.el8.noarch
rubygem-foreman_remote_execution-8.0.0-2.fm3_4.el8.noarch
foreman-ec2-3.4.1-1.el8.noarch
foreman-release-3.4.1-1.el8.noarch
foreman-service-3.4.1-1.el8.noarch
rubygem-foreman-tasks-7.0.0-1.fm3_4.el8.noarch
rubygem-foreman_default_hostgroup-6.0.0-2.fm3_3.el8.noarch
foreman-cli-3.4.1-1.el8.noarch
rubygem-foreman_memcache-0.1.1-5.fm3_3.el8.noarch
foreman-postgresql-3.4.1-1.el8.noarch
Red hat 8.6
Foreman 3.5 with Katello 4.7
sarang
March 17, 2023, 11:27am
5
I tried to create another repository using Hammer command line. It fails with same error.
Steps followed:
Created product ‘CentOS 7 Linux x86_64’
Created key ‘RPM-GPG-KEY-CentOS-7’ in content → “content credentials”.
Steill getting same error. Authentication credentials were not provided
[root@sjprdsatapp01 foreman-installer]# hammer content-credentials list --organization-id 1
ID | NAME | CONTENT TYPE
4 | RPM-GPG-KEY-CentOS-7 | gpg_key
3 | RPM-GPG-KEY-CentOS-SIG-Storage | gpg_key
[root@sjprdsatapp01 foreman-installer]# hammer -v repository create --organization cadence --product "CentOS 7 Linux x86_64" --name "CentOS 7 OS x86_64" --label "CentOS_7_Linux_x86_64" --content-type "yum" --download-policy "on_demand" --gpg-key-id 4 --url "http://172.13.13.16/images/centos-7-x86_64/7.9.2009/os/" --mirror-on-sync "no"
Could not create the repository:
**Authentication credentials were not provided.**
sarang
March 17, 2023, 12:34pm
7
Checking more information.
Files pointed by pulpcore_postgresql_ssl_cert and pulpcore_postgresql_ssl_key do not exist on system. Is this causing the issue?
# cat /etc/foreman-installer/scenarios.d/katello-answers.yaml | grep -i pulp
pulpcore_mirror: false
pulpcore_manage_postgresql: false
pulpcore_postgresql_host: sjprdsatdb01.cadence.com
pulpcore_postgresql_port: 5432
pulpcore_allowed_content_checksums:
pulpcore_postgresql_user: pulp
pulpcore_postgresql_password: cadence123
pulpcore_postgresql_db_name: pulpcore
pulpcore_postgresql_ssl: false
pulpcore_postgresql_ssl_require: true
pulpcore_postgresql_ssl_cert: "/etc/pki/katello/certs/pulpcore-database.crt" <----
pulpcore_postgresql_ssl_key: "/etc/pki/katello/private/pulpcore-database.key" <----
pulpcore_postgresql_ssl_root_ca: "/etc/pki/tls/certs/ca-bundle.crt"
pulpcore_postgresql_ssl_root_ca: "/etc/pki/katello/certs/katello-server-ca.crt"
pulpcore_worker_count: 8
pulpcore_django_secret_key:
pulpcore_content_service_worker_timeout: 90
pulpcore_api_service_worker_timeout: 90
pulpcore_cache_enabled: true
pulpcore_cache_expires_ttl:
pulpcore_additional_import_paths: []
pulpcore_additional_export_paths: []
pulpcore_telemetry: false
Please provide an update on this? This looks like a bug.
Let me know if more information is required.
sarang
March 20, 2023, 5:23am
8
Need someone to help with this.
Still getting the same error Authentication credentials were not provided
Not sure which logs to check apart from ‘production.log’ for this error.
The yum repository is local and does not have any credentials.
