Problem: Performed steps to upgrade from Katello version 3.18 to version 4.0. the upgrade appears to be successful and I am able to synchronize repositories. The issue is that in the “About” tab I have the following errors:
pulp FAIL 404 Not Found
pulp_auth FAIL Skipped pulp_auth check after failed pulp check
If I execute hammer ping the response appears normal.
[root@ bin]# hammer ping
database:
Status: ok
Server Response: Duration: 0ms
candlepin:
Status: ok
Server Response: Duration: 31ms
candlepin_events:
Status: ok
message: 0 Processed, 0 Failed
candlepin_auth:
Status: ok
Server Response: Duration: 29ms
katello_events:
Status: ok
pulp3:
Status: ok
Server Response: Duration: 50ms
foreman_tasks:
Status: ok
Server Response: Duration: 3ms
The GUI would show all status as OK.
or
if the if the error is related to the legacy pulp services, they should be removed from the monitoring.
Foreman-tasks - 4.01
Foreman-remote-execution - 4.3.0
Katello - 4.0.3
CentOS Linux release 7.9.2009 (Core)
I have not included any logs at this time as I would like to know what logs you would prefer.
The upgrade steps were as follows:
Update the OS to the latest version.
Download and install “tfm-rubygem-qpid_proton” to have a version that matches “qpid-proton-c” on my system
wget https://yum.theforeman.org/katello/4.0/katello/el7/x86_64/tfm-rubygem-qpid_proton-0.34.0-2.el7.x86_64.rpm
yum install tfm-rubygem-qpid_proton-0.34.0-2.el7.x86_64.rpm -
Disable the epel repository to remove conflicts with “qpid-proton-c” update
yum clean all
yum update -x tfm-rubygem-qpid_proton
foreman-installer (note the first time I execute this the process fails. I need to reboot and run again)
reboot
foreman-installer (This time it is successful)
Begin checking the system with “About” and “hammer ping”
I have performed this several times and the outcome is always the same.
Please let me know what to check to ensure the system is working properly.
Thanks
