lumarel
September 3, 2022, 9:48pm
#1
Hi everybody, doing another feedback thread before the release,
thank you for the new features, especially the CV compare, didn’t know that I need that until I used it now, but not wanting to miss it again
/foreman_statistics/statistics
just gives an error, not sure if this is an upgrade error though (also [1])
Noticed that the Ansible Collections
view is available twice, once directly in the Content
hover panel and another time in Other Content Types
The new great hardware panel in the new Host UI shows me an insane amount of disks for EL 8 and 9 machines running on ESXi and baremetal (checked with Rocky Linux machines) (it’s another value for every machine) (the agent version was still from 3.3)
The hardware panel shows not all data for Ubuntu machines
If I delete the currently selected ACS source the view on the right will stay after the source is gone on the left
Other stuff I might have already mentioned in earlier versions:
In the packages view, if the upgradable filter is selected it shows items with 0 Upgradable
systems, right now it looks like this is explicitly the case with the RHEL 8 Zabbix repo
If you go to Infrastructure → Smart Proxies → <Foreman-system>
→ Puppet, it will show the Distribution Chart in a broken way (after reloading the page with i.e. F5 if will show it correctly)
Thanks for the great product, and these valuable improvements once again!
Foreman 3.4.0-rc2
Katello 4.6.0.rc2
Tasks 7.0.0
Ansible 8.0.1
Bootdisk 19.0.5
Puppet 4.0.1
Remote Execution 7.1.1
Snapshot Management 2.0.1
Statistics 2.0.1
Templates 9.3.0
VMware Provider 3.4.0
Rocky Linux 8.6
[1]:
==> /var/log/httpd/foreman-ssl_access_ssl.log <==
10.0.0.10 - - [03/Sep/2022:23:20:27 +0200] "GET /foreman_statistics/statistics HTTP/1.1" 500 1477 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:91.0) Gecko/20100101 Firefox/91.0"
==> /var/log/foreman/production.log <==
2022-09-03T23:20:27 [I|app|816db815] Started GET "/foreman_statistics/statistics" for 10.0.0.10 at 2022-09-03 23:20:27 +0200
2022-09-03T23:20:27 [I|app|816db815] Processing by ForemanStatistics::ReactController#index as HTML
2022-09-03T23:20:27 [I|app|816db815] Rendered html template within foreman_statistics/layouts/application_react (Duration: 0.0ms | Allocations: 3)
2022-09-03T23:20:27 [I|app|816db815] Rendered layout /usr/share/gems/gems/foreman_statistics-2.0.1/app/views/foreman_statistics/layouts/application_react.html.erb (Duration: 14.5ms | Allocations: 7832)
2022-09-03T23:20:27 [W|app|816db815] undefined local variable or method `notifications' for #<ActionView::Base:0x00000000052cb0>
2022-09-03T23:20:27 [I|app|816db815] Backtrace for 'undefined local variable or method `notifications' for #<ActionView::Base:0x00000000052cb0>' error (ActionView::Template::Error): undefined local variable or method `notifications' for #<ActionView::Base:0x00000000052cb0>
816db815 | /usr/share/gems/gems/foreman_statistics-2.0.1/app/views/foreman_statistics/layouts/application_react.html.erb:10:in `block in _58ae75df3c372f629d91c721cc3c4ef1'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/helpers/capture_helper.rb:45:in `block in capture'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/helpers/capture_helper.rb:209:in `with_output_buffer'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/helpers/capture_helper.rb:45:in `capture'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/helpers/capture_helper.rb:159:in `content_for'
816db815 | /usr/share/gems/gems/foreman_statistics-2.0.1/app/views/foreman_statistics/layouts/application_react.html.erb:9:in `_58ae75df3c372f629d91c721cc3c4ef1'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/base.rb:247:in `public_send'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/base.rb:247:in `_run'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/template.rb:154:in `block in render'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications.rb:205:in `instrument'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/template.rb:345:in `instrument_render_template'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/template.rb:152:in `render'
816db815 | /usr/share/gems/gems/deface-1.5.3/lib/deface/action_view_extensions.rb:43:in `render'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:72:in `block in render_with_layout'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications.rb:203:in `block in instrument'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications.rb:203:in `instrument'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:70:in `render_with_layout'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:55:in `render_template'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:11:in `render'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/renderer.rb:61:in `render_template_to_object'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/renderer.rb:29:in `render_to_object'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/rendering.rb:117:in `block in _render_template'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/base.rb:273:in `in_rendering_context'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/rendering.rb:116:in `_render_template'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/streaming.rb:218:in `_render_template'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/rendering.rb:103:in `render_to_body'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/rendering.rb:25:in `render'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/rendering.rb:36:in `render'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:46:in `block (2 levels) in render'
816db815 | /usr/share/ruby/benchmark.rb:308:in `realtime'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/core_ext/benchmark.rb:14:in `ms'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:46:in `block in render'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:86:in `cleanup_view_runtime'
816db815 | /usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:45:in `render'
816db815 | /usr/share/gems/gems/foreman_statistics-2.0.1/app/controllers/foreman_statistics/react_controller.rb:6:in `index'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/base.rb:228:in `process_action'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
816db815 | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
816db815 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
816db815 | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
816db815 | /usr/share/gems/gems/audited-4.10.0/lib/audited/sweeper.rb:14:in `around'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:137:in `run_callbacks'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:33:in `process_action'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
816db815 | /usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/base.rb:165:in `process'
816db815 | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/rendering.rb:39:in `process'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal.rb:190:in `dispatch'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal.rb:254:in `dispatch'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/routing/route_set.rb:33:in `serve'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/journey/router.rb:50:in `block in serve'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/journey/router.rb:32:in `each'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/journey/router.rb:32:in `serve'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/routing/route_set.rb:842:in `call'
816db815 | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/engine.rb:539:in `call'
816db815 | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in `public_send'
816db815 | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in `method_missing'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/routing/mapper.rb:20:in `block in <class:Constraints>'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/routing/mapper.rb:49:in `serve'
816db815 | /usr/share/gems/gems/katello-4.6.0.rc2/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
816db815 | /usr/share/gems/gems/katello-4.6.0.rc2/lib/katello/middleware/event_daemon.rb:10:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/static.rb:24:in `call'
816db815 | /usr/share/gems/gems/apipie-dsl-2.5.0/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
816db815 | /usr/share/gems/gems/apipie-rails-0.5.20/lib/apipie/static_dispatcher.rb:66:in `call'
816db815 | /usr/share/gems/gems/apipie-rails-0.5.20/lib/apipie/extractor/recorder.rb:137:in `call'
816db815 | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
816db815 | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
816db815 | /usr/share/gems/gems/apipie-rails-0.5.20/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/tempfile_reaper.rb:15:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/etag.rb:27:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/conditional_get.rb:27:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/head.rb:12:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/http/permissions_policy.rb:22:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/http/content_security_policy.rb:19:in `call'
816db815 | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/session/abstract/id.rb:266:in `context'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/session/abstract/id.rb:260:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/cookies.rb:689:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
816db815 | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/rack/logger.rb:37:in `call_app'
816db815 | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/rack/logger.rb:28:in `call'
816db815 | /usr/share/gems/gems/sprockets-rails-3.4.2/lib/sprockets/rails/quiet_assets.rb:13:in `call'
816db815 | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/request_id.rb:26:in `call'
816db815 | /usr/share/gems/gems/katello-4.6.0.rc2/lib/katello/prevent_json_parsing.rb:12:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/method_override.rb:24:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/runtime.rb:22:in `call'
816db815 | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/sendfile.rb:110:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/ssl.rb:77:in `call'
816db815 | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/host_authorization.rb:142:in `call'
816db815 | /usr/share/gems/gems/secure_headers-6.3.4/lib/secure_headers/middleware.rb:11:in `call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:74:in `block in call'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:58:in `each'
816db815 | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:58:in `call'
816db815 | /usr/share/gems/gems/puma-5.6.4/lib/puma/configuration.rb:252:in `call'
816db815 | /usr/share/gems/gems/puma-5.6.4/lib/puma/request.rb:77:in `block in handle_request'
816db815 | /usr/share/gems/gems/puma-5.6.4/lib/puma/thread_pool.rb:340:in `with_force_shutdown'
816db815 | /usr/share/gems/gems/puma-5.6.4/lib/puma/request.rb:76:in `handle_request'
816db815 | /usr/share/gems/gems/puma-5.6.4/lib/puma/server.rb:441:in `process_client'
816db815 | /usr/share/gems/gems/puma-5.6.4/lib/puma/thread_pool.rb:147:in `block in spawn_thread'
816db815 | /usr/share/gems/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2022-09-03T23:20:27 [I|app|816db815] Rendered common/500.html.erb within foreman_statistics/layouts/application_react (Duration: 1.1ms | Allocations: 1698)
2022-09-03T23:20:27 [I|app|816db815] Rendered layout /usr/share/gems/gems/foreman_statistics-2.0.1/app/views/foreman_statistics/layouts/application_react.html.erb (Duration: 15.6ms | Allocations: 9518)
2022-09-03T23:20:27 [I|app|816db815] Completed 500 Internal Server Error in 38ms (ActiveRecord: 1.2ms | Allocations: 20491)
2022-09-03T23:20:27 [F|app|816db815]
816db815 | ActionView::Template::Error (undefined local variable or method `notifications' for #<ActionView::Base:0x00000000052d28>):
816db815 | 7: <% end %>
816db815 | 8:
816db815 | 9: <% content_for(:content) do %>
816db815 | 10: <%= notifications %>
816db815 | 11: <div id="organization-id" data-id="<%= Organization.current.id if Organization.current %>" ></div>
816db815 | 12: <div id="user-id" data-id="<%= User.current.id if User.current %>" ></div>
816db815 | 13: <%= react_component('ForemanStatistics') %>
816db815 |
816db815 | foreman_statistics (2.0.1) app/views/foreman_statistics/layouts/application_react.html.erb:10:in `block in _58ae75df3c372f629d91c721cc3c4ef1'
816db815 | foreman_statistics (2.0.1) app/views/foreman_statistics/layouts/application_react.html.erb:9:in `_58ae75df3c372f629d91c721cc3c4ef1'
816db815 | app/controllers/application_controller.rb:353:in `generic_exception'
816db815 | katello (4.6.0.rc2) lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
816db815 | katello (4.6.0.rc2) lib/katello/middleware/event_daemon.rb:10:in `call'
816db815 | lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
816db815 | lib/foreman/middleware/telemetry.rb:10:in `call'
816db815 | lib/foreman/middleware/logging_context_session.rb:22:in `call'
816db815 | lib/foreman/middleware/logging_context_request.rb:11:in `call'
816db815 | katello (4.6.0.rc2) lib/katello/prevent_json_parsing.rb:12:in `call'
lumarel
September 5, 2022, 11:13am
#2
Another thing I noticed now is, if I click on a job invocation (/job_invocations/<nmb>
) I get the error
Oops, we’re sorry but something went wrong undefined method `template_inputs’ for nil:NilClass
I’m just not sure if this is something new.
# foreman-rake errors:fetch_log request_id=a202c5fc
Rubocop not loaded.
2022-09-05T13:11:31 [I|app|a202c5fc] Started GET "/job_invocations/128" for 10.0.0.10 at 2022-09-05 13:11:31 +0200
2022-09-05T13:11:31 [I|app|a202c5fc] Processing by JobInvocationsController#show as HTML
2022-09-05T13:11:31 [I|app|a202c5fc] Parameters: {"id"=>"128"}
2022-09-05T13:11:31 [I|app|a202c5fc] Rendered /usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/show.html.erb within layouts/application (Duration: 31.3ms | Allocations: 9559)
2022-09-05T13:11:31 [I|app|a202c5fc] Rendered layout layouts/application.html.erb (Duration: 31.5ms | Allocations: 9612)
2022-09-05T13:11:31 [W|app|a202c5fc] undefined method `template_inputs' for nil:NilClass
2022-09-05T13:11:31 [I|app|a202c5fc] Backtrace for 'undefined method `template_inputs' for nil:NilClass' error (ActionView::Template::Error): undefined method `template_inputs' for nil:NilClass
a202c5fc | /usr/share/gems/gems/foreman_remote_execution-7.1.1/app/helpers/remote_execution_helper.rb:249:in `job_report_template'
a202c5fc | /usr/share/gems/gems/foreman_remote_execution-7.1.1/app/helpers/remote_execution_helper.rb:67:in `job_invocation_task_buttons'
a202c5fc | /usr/share/gems/gems/foreman_remote_execution-7.1.1/app/views/job_invocations/show.html.erb:12:in `_dab073de2fb972f71a736df527371264'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/base.rb:247:in `public_send'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/base.rb:247:in `_run'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/template.rb:154:in `block in render'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications.rb:205:in `instrument'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/template.rb:345:in `instrument_render_template'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/template.rb:152:in `render'
a202c5fc | /usr/share/gems/gems/deface-1.5.3/lib/deface/action_view_extensions.rb:43:in `render'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:61:in `block (2 levels) in render_template'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications.rb:203:in `block in instrument'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications.rb:203:in `instrument'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:56:in `block in render_template'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:71:in `block in render_with_layout'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:70:in `render_with_layout'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:55:in `render_template'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/template_renderer.rb:11:in `render'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/renderer.rb:61:in `render_template_to_object'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/renderer/renderer.rb:29:in `render_to_object'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/rendering.rb:117:in `block in _render_template'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/base.rb:273:in `in_rendering_context'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/rendering.rb:116:in `_render_template'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/streaming.rb:218:in `_render_template'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/rendering.rb:103:in `render_to_body'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/rendering.rb:25:in `render'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/rendering.rb:36:in `render'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:46:in `block (2 levels) in render'
a202c5fc | /usr/share/ruby/benchmark.rb:308:in `realtime'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/core_ext/benchmark.rb:14:in `ms'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:46:in `block in render'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:86:in `cleanup_view_runtime'
a202c5fc | /usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:45:in `render'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/implicit_render.rb:35:in `default_render'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `block in send_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `tap'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/base.rb:228:in `process_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
a202c5fc | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
a202c5fc | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
a202c5fc | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
a202c5fc | /usr/share/gems/gems/audited-4.10.0/lib/audited/sweeper.rb:14:in `around'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:137:in `run_callbacks'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/instrumentation.rb:33:in `process_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
a202c5fc | /usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/abstract_controller/base.rb:165:in `process'
a202c5fc | /usr/share/gems/gems/actionview-6.1.6.1/lib/action_view/rendering.rb:39:in `process'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal.rb:190:in `dispatch'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_controller/metal.rb:254:in `dispatch'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/routing/route_set.rb:33:in `serve'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/journey/router.rb:50:in `block in serve'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/journey/router.rb:32:in `each'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/journey/router.rb:32:in `serve'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/routing/route_set.rb:842:in `call'
a202c5fc | /usr/share/gems/gems/katello-4.6.0.rc2/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
a202c5fc | /usr/share/gems/gems/katello-4.6.0.rc2/lib/katello/middleware/event_daemon.rb:10:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/static.rb:24:in `call'
a202c5fc | /usr/share/gems/gems/apipie-dsl-2.5.0/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
a202c5fc | /usr/share/gems/gems/apipie-rails-0.5.20/lib/apipie/static_dispatcher.rb:66:in `call'
a202c5fc | /usr/share/gems/gems/apipie-rails-0.5.20/lib/apipie/extractor/recorder.rb:137:in `call'
a202c5fc | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
a202c5fc | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
a202c5fc | /usr/share/gems/gems/apipie-rails-0.5.20/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/tempfile_reaper.rb:15:in `call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/etag.rb:27:in `call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/conditional_get.rb:27:in `call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/head.rb:12:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/http/permissions_policy.rb:22:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/http/content_security_policy.rb:19:in `call'
a202c5fc | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/session/abstract/id.rb:266:in `context'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/session/abstract/id.rb:260:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/cookies.rb:689:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
a202c5fc | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/rack/logger.rb:37:in `call_app'
a202c5fc | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/rack/logger.rb:28:in `call'
a202c5fc | /usr/share/gems/gems/sprockets-rails-3.4.2/lib/sprockets/rails/quiet_assets.rb:13:in `call'
a202c5fc | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/request_id.rb:26:in `call'
a202c5fc | /usr/share/gems/gems/katello-4.6.0.rc2/lib/katello/prevent_json_parsing.rb:12:in `call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/method_override.rb:24:in `call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/runtime.rb:22:in `call'
a202c5fc | /usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/sendfile.rb:110:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/ssl.rb:77:in `call'
a202c5fc | /usr/share/gems/gems/actionpack-6.1.6.1/lib/action_dispatch/middleware/host_authorization.rb:142:in `call'
a202c5fc | /usr/share/gems/gems/secure_headers-6.3.4/lib/secure_headers/middleware.rb:11:in `call'
a202c5fc | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/engine.rb:539:in `call'
a202c5fc | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in `public_send'
a202c5fc | /usr/share/gems/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in `method_missing'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:74:in `block in call'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:58:in `each'
a202c5fc | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:58:in `call'
a202c5fc | /usr/share/gems/gems/puma-5.6.4/lib/puma/configuration.rb:252:in `call'
a202c5fc | /usr/share/gems/gems/puma-5.6.4/lib/puma/request.rb:77:in `block in handle_request'
a202c5fc | /usr/share/gems/gems/puma-5.6.4/lib/puma/thread_pool.rb:340:in `with_force_shutdown'
a202c5fc | /usr/share/gems/gems/puma-5.6.4/lib/puma/request.rb:76:in `handle_request'
a202c5fc | /usr/share/gems/gems/puma-5.6.4/lib/puma/server.rb:441:in `process_client'
a202c5fc | /usr/share/gems/gems/puma-5.6.4/lib/puma/thread_pool.rb:147:in `block in spawn_thread'
a202c5fc | /usr/share/gems/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2022-09-05T13:11:31 [I|app|a202c5fc] Rendered common/500.html.erb within layouts/application (Duration: 4.5ms | Allocations: 6164)
2022-09-05T13:11:31 [I|app|a202c5fc] Rendered layouts/base.html.erb (Duration: 6.2ms | Allocations: 8762)
2022-09-05T13:11:31 [I|app|a202c5fc] Rendered layout layouts/application.html.erb (Duration: 19.0ms | Allocations: 26403)
2022-09-05T13:11:31 [I|app|a202c5fc] Completed 500 Internal Server Error in 77ms (Views: 19.5ms | ActiveRecord: 6.8ms | Allocations: 44524)
Foreman version: 3.4.0-rc2
Plugins:
- foreman-tasks 7.0.0
- foreman_ansible 8.0.1
- foreman_bootdisk 19.0.5
- foreman_puppet 4.0.1
- foreman_remote_execution 7.1.1
- foreman_snapshot_management 2.0.1
- foreman_statistics 2.0.1
- foreman_templates 9.3.0
- katello 4.6.0.rc2
@cintrix84 didn’t we fix this? I can’t find a redmine.
This is from the dmi::memory::maximum_capacity
host fact. Do ubuntu machines have this?
Looks like a bug. @iballou is this a known issue or should we make a redmine?
Filed Bug #35498: In the packages view, if the upgradable filter is selected it shows items with 0 Upgradable systems - Katello - Foreman
This is probably a bug too but I’m not sure which plugin it would be…
lumarel:
) I get the error
I’ve seen this before and I’m pretty sure this is fixed in the foreman_remote_execution plugin… @aruzicka did the correct foreman_remote_execution version coincide with Foreman 3.4?
Oh, and @lumarel thanks for highlighting all these issues!
lumarel
September 7, 2022, 10:05pm
#6
Hey @jeremylenz !
thank you for taking a look
Doesn’t looks like
Maybe a package is missing from the dependencies, or it’s just not built with dmi readout.
All I can see are these (this is with subscription-manager from the atix repo):
# subscription-manager facts
cpu.core(s)_per_socket: 2
cpu.cpu(s): 2
cpu.cpu_socket(s): 1
cpu.thread(s)_per_core: 1
cpu.topology_source: kernel /sys cpu sibling lists
distribution.id: Focal Fossa
distribution.name: Ubuntu
distribution.version: 20.04
distribution.version.modifier: Unknown
last_boot: 2022-09-07 21:17:36
lscpu.address_sizes: 45 bits physical, 48 bits virtual
lscpu.architecture: x86_64
lscpu.bogomips: 4992.00
lscpu.byte_order: Little Endian
lscpu.core(s)_per_socket: 2
lscpu.cpu(s): 2
lscpu.cpu_family: 6
lscpu.cpu_mhz: 2496.000
lscpu.cpu_op-mode(s): 32-bit, 64-bit
lscpu.flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon nopl xtopology tsc_reliable nonstop_tsc cpuid pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch invpcid_single pti ssbd ibrs ibpb stibp fsgsbase tsc_adjust bmi1 avx2 smep bmi2 invpcid rdseed adx smap xsaveopt arat md_clear flush_l1d arch_capabilities
lscpu.hypervisor_vendor: VMware
lscpu.l1d_cache: 64 KiB
lscpu.l1i_cache: 64 KiB
lscpu.l2_cache: 512 KiB
lscpu.l3_cache: 6 MiB
lscpu.model: 79
lscpu.model_name: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
lscpu.numa_node(s): 1
lscpu.numa_node0_cpu(s): 0,1
lscpu.on-line_cpu(s)_list: 0,1
lscpu.socket(s): 1
lscpu.stepping: 0
lscpu.thread(s)_per_core: 1
lscpu.vendor_id: GenuineIntel
lscpu.virtualization_type: full
lscpu.vulnerability_l1tf: Mitigation; PTE Inversion
lscpu.vulnerability_mds: Mitigation; Clear CPU buffers; SMT Host state unknown
lscpu.vulnerability_meltdown: Mitigation; PTI
lscpu.vulnerability_spec_store_bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
lscpu.vulnerability_spectre_v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
lscpu.vulnerability_spectre_v2: Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP disabled, RSB filling
lscpu.vulnerability_srbds: Not affected
lscpu.vulnerability_tsx_async_abort: Not affected
memory.memtotal: 4025480
memory.swaptotal: 2475004
net.interface.ens160.ipv4_address: 10.27.30.160
net.interface.ens160.ipv4_address_list: 10.27.30.160
net.interface.ens160.ipv4_broadcast: 10.27.30.255
net.interface.ens160.ipv4_broadcast_list: 10.27.30.255
net.interface.ens160.ipv4_netmask: 24
net.interface.ens160.ipv4_netmask_list: 24
net.interface.ens160.ipv6_address.link: fe80::250:56ff:fe8f:fa30
net.interface.ens160.ipv6_address.link_list: fe80::250:56ff:fe8f:fa30
net.interface.ens160.ipv6_netmask.link: 64
net.interface.ens160.ipv6_netmask.link_list: 64
net.interface.ens160.mac_address: 00:50:56:8f:fa:30
net.interface.lo.ipv4_address: 127.0.0.1
net.interface.lo.ipv4_address_list: 127.0.0.1
net.interface.lo.ipv4_broadcast: Unknown
net.interface.lo.ipv4_broadcast_list: Unknown
net.interface.lo.ipv4_netmask: 8
net.interface.lo.ipv4_netmask_list: 8
net.interface.lo.ipv6_address.host: ::1
net.interface.lo.ipv6_address.host_list: ::1
net.interface.lo.ipv6_netmask.host: 128
net.interface.lo.ipv6_netmask.host_list: 128
network.fqdn: us20-rhsm-dev.30.fritz.box
network.hostname: us20-rhsm-dev.30.fritz.box
network.hostname-override: us20-rhsm-dev
network.ipv4_address: 10.27.30.160
network.ipv6_address: ::1
proc_cpuinfo.common.address_sizes: 45 bits physical, 48 bits virtual
proc_cpuinfo.common.bogomips: 4992.00
proc_cpuinfo.common.bugs: cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf mds swapgs itlb_multihit
proc_cpuinfo.common.cache_alignment: 64
proc_cpuinfo.common.cache_size: 6144 KB
proc_cpuinfo.common.clflush_size: 64
proc_cpuinfo.common.cpu_cores: 2
proc_cpuinfo.common.cpu_family: 6
proc_cpuinfo.common.cpu_mhz: 2496.000
proc_cpuinfo.common.cpuid_level: 13
proc_cpuinfo.common.flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon nopl xtopology tsc_reliable nonstop_tsc cpuid pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch invpcid_single pti ssbd ibrs ibpb stibp fsgsbase tsc_adjust bmi1 avx2 smep bmi2 invpcid rdseed adx smap xsaveopt arat md_clear flush_l1d arch_capabilities
proc_cpuinfo.common.fpu: yes
proc_cpuinfo.common.fpu_exception: yes
proc_cpuinfo.common.microcode: 0xf0
proc_cpuinfo.common.model: 79
proc_cpuinfo.common.model_name: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
proc_cpuinfo.common.physical_id: 0
proc_cpuinfo.common.power_management: Unknown
proc_cpuinfo.common.siblings: 2
proc_cpuinfo.common.stepping: 0
proc_cpuinfo.common.vendor_id: GenuineIntel
proc_cpuinfo.common.wp: yes
proc_stat.btime: 1662585456
supported_architectures: amd64
system.certificate_version: 3.2
system.default_locale: en_US.UTF-8
uname.machine: x86_64
uname.nodename: us20-rhsm-dev.30.fritz.box
uname.release: 5.4.0-109-generic
uname.sysname: Linux
uname.version: #123-Ubuntu SMP Fri Apr 8 09:10:54 UTC 2022
virt.host_type: vmware
virt.is_guest: True
Thank you for creating
Took me a bit to search around, but looks to be this referenced in this page .
lumarel
September 8, 2022, 9:41pm
#8
Looks like I found what is missing.
After installing python3-dmidecode
from universe
the dmi facts show up in subscription-manager facts
It did not upload these to Foreman though, do I have to manually trigger that, I still see the last facts upload date from back when I installed this machine.
lumarel
September 8, 2022, 9:50pm
#9
yep that’s it, currently subscription-manager
depends on python3-subscription-manager
, which then currently depends on python3 (<< 3.11), python3 (>= 3.10~), python3-dateutil, python3-ethtool, python3-iniparse, python3-six, python3:any (>= 3.3~), python3-dbus, python3-rpm, virt-what, python3-debian, python3-gi, python3-decorator, python3-requests, apt-transport-katello
Which does not include python3-dmidecode
Ah, sorry about this. The issue itself is fixed by [1] which went out with foreman_remote_execution-8.0.0. I didn’t realize the packaging automation put it only into nightlies, but not into 3.4. Opened [2] and [3] to fix it.
[1] - https://github.com/theforeman/foreman_remote_execution/pull/736
[2] - https://github.com/theforeman/foreman-packaging/pull/8477
[3] - https://github.com/theforeman/foreman-packaging/pull/8480
lumarel
September 13, 2022, 10:47pm
#11
Looks like the packages are available now!
Installed rubygem-foreman_remote_execution-8.0.0-2.fm3_4.el8
and rubygem-smart_proxy_remote_execution_ssh-0.8.0-1.fm3_4.el8
some minutes ago, and the views are working again, thank you
lumarel
September 13, 2022, 10:48pm
#12
Let’s see if the rest will also get attention
Best way to call attention is to file Redmine issues in the appropriate project, if they don’t exist already:
lumarel
September 14, 2022, 10:26pm
#14
Okay thanks will create one/some
Just stuck to here, because it was mentioned in the Ready for Testing
thread, that issues should go here in the forum
lumarel
September 14, 2022, 11:27pm
#15
from universe
@atix As this does not belong in Redmine, I hope it’s fine I ping all of you here,
maybe it’s intentional, I just want to make sure it gets mentioned
