Running on ubuntu 16.02, the latest Foreman version.
Here is the output:
root@linuxhub:~# puppet agent --test
Info: Using configured environment 'production'
Info: Retrieving pluginfacts
Info: Loading facts
Error: Could not retrieve catalog from remote server: Error 500 on SERVER:
Server Error: Evaluation Error: Error while evaluating a Resource
Statement, Class[Ntp]:
parameter 'broadcastclient' expects a Boolean value, got String
parameter 'config' expects a match for Variant[Stdlib::Windowspath =
Pattern[/^(([a-zA-Z]:[\/])|([\/][\/][^\/]+[\/][^\/]+)|([\/][\/]?[\/][^\/]+))/],
Stdlib::Unixpath = Pattern[/^/([^/\0]+(/)?)+$/]], got ''
parameter 'config_dir' expects a match for Variant[Stdlib::Windowspath =
parameter 'disable_auth' expects a Boolean value, got String
parameter 'disable_dhclient' expects a Boolean value, got String
parameter 'disable_kernel' expects a Boolean value, got String
parameter 'disable_monitor' expects a Boolean value, got String
parameter 'fudge' expects an Array value, got String
parameter 'driftfile' expects a match for Variant[Stdlib::Windowspath =
parameter 'leapfile' expects a match for Variant[Stdlib::Windowspath =
parameter 'logfile' expects a match for Variant[Stdlib::Windowspath =
parameter 'iburst_enable' expects a Boolean value, got String
parameter 'keys' expects an Array value, got String
parameter 'keys_enable' expects a Boolean value, got String
parameter 'keys_file' expects a match for Variant[Stdlib::Windowspath =
parameter 'keys_controlkey' expects a Ntp::Key_id = Integer[1, 65534]
value, got String
parameter 'keys_requestkey' expects a Ntp::Key_id = Integer[1, 65534]
value, got String
parameter 'keys_trusted' expects an Array value, got String
parameter 'minpoll' expects a Ntp::Poll_interval = Integer[4, 17] value,
got String
parameter 'maxpoll' expects a Ntp::Poll_interval = Integer[4, 17] value,
got String
parameter 'package_manage' expects a Boolean value, got String
parameter 'package_name' expects an Array value, got String
parameter 'panic' expects an Integer value, got String
parameter 'peers' expects an Array value, got String
parameter 'preferred_servers' expects an Array value, got String
parameter 'restrict' expects an Array value, got String
parameter 'interfaces' expects an Array value, got String
parameter 'interfaces_ignore' expects an Array value, got String
parameter 'servers' expects an Array value, got String
parameter 'service_enable' expects a Boolean value, got String
parameter 'service_manage' expects a Boolean value, got String
parameter 'stepout' expects an Integer value, got String
parameter 'step_tickers_file' expects a match for
parameter 'tinker' expects a Boolean value, got String
parameter 'tos' expects a Boolean value, got String
parameter 'tos_minclock' expects an Integer value, got String
parameter 'tos_minsane' expects an Integer value, got String
parameter 'tos_floor' expects an Integer value, got String
parameter 'tos_ceiling' expects an Integer value, got String
parameter 'tos_cohort' expects a value of type Boolean or Integer, got
String
parameter 'udlc' expects a Boolean value, got String
parameter 'udlc_stratum' expects an Integer value, got String
parameter 'ntpsigndsocket' expects a match for
Stdlib::Unixpath = Pattern[/^/([^/\0]+(/)?)+$/]], got '' on node
linuxhub.az.int
Thank you for any guidance on this issue!
