Oops, we're sorry but something went wrong ERF42-7329 [Foreman::Exception]: Not implemented for Docker
Hi everyone,
I get the following error immediately after adding docker in Compute Resources
Oops, we’re sorry but something went wrong ERF42-7329 [Foreman::Exception]: Not implemented for Docker
Which version are you using? Docker support has been dropped in recent versions but a shim remains to remove resources from older versions.
I meant the Foreman version. It’s also much easier to read text than screenshots.
Hi ekohl,
thank for your help, the foreman Version 1.23.1 © 2009-2019
Hi, you shouldn’t be adding docker compute resource, as suggested earlier, it’s no longer maintained. Running this should help with the cleanup foreman-rake foreman_docker:cleanup, see full remove instructions at https://github.com/theforeman/foreman_docker/blob/master/README.md
