Openscap module for smart-proxy is not uploading ARF reports to foreman. It looks like the client is uploading to the proxy successfully, but there is a failure in smart-proxy-arf-json. The extended error information back to the client says the certificate verify failed. There’s a stack from proxy.log below. Nothing interesting in the main foreman log.
I have a server cert issued by mycorp.net both for the foreman web UI and to get login information from LDAP. That part works fine.
I left the self-signed puppet cert in place for the proxy. The comments in the proxy settings file say that proxy clients have to use the same CA.
Both CA’s are in the openssl trust store. Trust list shows them as anchor/authority and not blacklisted.
I can see the puppet CA certs through the foreman UI.
ARF report uploaded to foreman and visible in the web UI
Foreman and proxy 1.16
rubygem-smart_proxy_openscap 0.6.8-1
From /var/log/foreman-proxy/proxy.log
D, [2018-07-06T09:36:17.505275 ] DEBUG -- : accept: 10.164.87.48:45330
D, [2018-07-06T09:36:17.506350 ] DEBUG -- : Rack::Handler::WEBrick is invoked.
D, [2018-07-06T09:36:17.522843 ] DEBUG -- : Executing: smart-proxy-arf-json /var/tmp/aa199cf4-9187-44f9-918c-497f27d2e822-testlnv1413.corp.intuit.net-1-1530894977-20180706-1282-1aaxs0g /var/tmp/aa199cf4-9187-44f9-918c-497f27d2e822-testlnv1413.corp.intuit.net-1-1530894977-json-20180706-1282-ote7tc
D, [2018-07-06T09:36:19.127348 ] DEBUG -- : /usr/share/ruby/net/http.rb:921:in `connect'
/usr/share/ruby/net/http.rb:921:in `block in connect'
/usr/share/ruby/timeout.rb:52:in `timeout'
/usr/share/ruby/net/http.rb:862:in `do_start'
/usr/share/ruby/net/http.rb:851:in `start'
/usr/share/ruby/net/http.rb:1373:in `request'
/usr/share/gems/gems/smart_proxy_openscap-0.6.8/lib/smart_proxy_openscap/foreman_forwarder.rb:35:in `send_request'
/usr/share/gems/gems/smart_proxy_openscap-0.6.8/lib/smart_proxy_openscap/foreman_forwarder.rb:9:in `post_arf_report'
/usr/share/gems/gems/smart_proxy_openscap-0.6.8/lib/smart_proxy_openscap/openscap_api.rb:39:in `block in <class:Api>'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1611:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1611:in `block in compile!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:975:in `[]'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:975:in `block (3 levels) in route!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:994:in `route_eval'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:975:in `block (2 levels) in route!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1015:in `block in process_route'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1013:in `catch'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1013:in `process_route'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:973:in `block in route!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:972:in `each'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:972:in `route!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1085:in `block in dispatch!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1067:in `block in invoke'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1067:in `catch'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1067:in `invoke'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1082:in `dispatch!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:907:in `block in call!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:907:in `call!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:895:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/commonlogger.rb:33:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:219:in `call'
/usr/share/foreman-proxy/lib/proxy/log.rb:109:in `call'
/usr/share/foreman-proxy/lib/proxy/request_id_middleware.rb:9:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/xss_header.rb:18:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/path_traversal.rb:16:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/json_csrf.rb:18:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/base.rb:49:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/nulllogger.rb:9:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/show_exceptions.rb:25:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:182:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:2013:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1487:in `block in call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1787:in `synchronize'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1487:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/builder.rb:153:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/handler/webrick.rb:88:in `service'
/usr/share/ruby/webrick/httpserver.rb:138:in `service'
/usr/share/ruby/webrick/httpserver.rb:94:in `run'
/usr/share/ruby/webrick/server.rb:295:in `block in start_thread'
D, [2018-07-06T09:36:19.179894 ] DEBUG -- : close: 10.164.87.48:45330
