Hi, I've setup Ovirt 3.3.1 and Foreman 1.3.1 successfully and I'm able to
create VMs from Foreman but once I hit the console button I just see an
empty box. I've tried everything I can think of and no results. I'm able to
see the HTML5 console from Ovirt gui without issues. Firewall is open for
both ends on all ports. See screenshot attached. Does this needs any
specific setup on Ovirt host?
Thanks.
These are the logs from /var/log/foreman/production.log
Started GET "/hosts/foo.bar/console" for 192.168.1.4 at 2013-11-13 16:32:54
+0000
Processing by HostsController#console as HTML
Parameters: {"id"=>"foo.bar"}
Rendered hosts/console/spice.html.erb within layouts/application (4.4ms)
Rendered home/_user_dropdown.html.erb (2.6ms)
Read fragment views/tabs_and_title_records-2 (0.3ms)
Rendered home/_topbar.html.erb (3.1ms)
Completed 200 OK in 720ms (Views: 16.5ms | ActiveRecord: 1.9ms)
> Thanks.
What browser/version? Ports open for SPICE on the ovirt host(s)?
> 16:32:54 +0000
> able to create VMs from Foreman but once I hit the console button I
> just see an empty box. I've tried everything I can think of and no
> results. I'm able to see the HTML5 console from Ovirt gui without
> issues. Firewall is open for both ends on all ports. See screenshot
> attached. Does this needs any specific setup on Ovirt host?
> Thanks.
Phil Gardner
PGP Key ID 0xFECC890C
OTR Fingerprint 6707E9B8 BD6062D3 5010FE8B 36D614E3 D2F80538
Sorry forgot to add browser. Tried with chrome and IE.
> > 16:32:54 +0000
> (4.4ms)
> > On Wednesday, November 13, 2013 11:15:28 AM UTC-5, Alejandro Falcon > wrote:
> > Thanks.
> _____________________
> Phil Gardner
