Packages not shown inside repository within product
Packages not shown inside repository within product.
Please see the pictures 1 and 2 below for reference.
[Picture 1](https://imgur.com/a/aSltdcb)
There clearly are 34 packages inside this product repository, however when you check the packages the page is empty. Please see the picture below:
[Picture 2](https://imgur.com/a/9gINBpS)
Sorry for the imgur uploads, since I’m a new user I can’t upload more than one picture inside the thread.
Foreman foreman-3.1.1-1.el7.noarch
Smart proxy: 3.1.1
Katello: katello-4.3.0-1.el7.noarch
CentOS 7 with latest stable installation
@lessfoobar hello! We’ve fixed this issue in the upcoming 4.3.1 release which I estimate will be available in 1-2 weeks at most. Your packages are there, it’s just an issue with that particular page displaying them. Sorry for the inconvenience.
As a workaround you can use Content > Packages and filter by repository using the dropdown.
@Jonathon_Turel Any idea on when 4.3.1 release will be out?
Thanks!
Raj
Probably next week.
