to me this makes sense. Don't shoot me if the logic isn't 100% correct…
in short, active hosts are counted as ok hosts, which makes the
counters get higher than the number of total hosts sometimes.
To bring the pie to the sum of the hosts, only the missing reports
should be added, which is included too.
Tim
Signed-off-by: Tim Speetjens <tim.speetjens@gmail.com>
app/controllers/dashboard_controller.rb | 2 ++
app/helpers/dashboard_helper.rb | 5 +++--
2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/app/controllers/dashboard_controller.rb
b/app/controllers/dashboard_controller.rb
index ea8f10f…7e915b4 100644
— a/app/controllers/dashboard_controller.rb
+++ b/app/controllers/dashboard_controller.rb
@@ -23,6 +23,8 @@ class DashboardController < ApplicationController
:disabled_hosts => hosts.alerts_disabled.count
@report[:percentage] = (@report[:good_hosts] == 0 or
@report[:total_hosts] == 0) ? 0 : @report[:good_hosts]*100 /
@report[:ok_hosts] = @report[:good_hosts] - @report[:active_hosts]
@report[:reports_missing] = @report[:total_hosts] -
@report[:good_hosts] - @report[:bad_hosts] -
@report[:out_of_sync_hosts]
end
end
diff --git a/app/helpers/dashboard_helper.rb b/app/helpers/dashboard_helper.rb
index af3e205…ed0d3e6 100644
— a/app/helpers/dashboard_helper.rb
+++ b/app/helpers/dashboard_helper.rb
@@ -60,8 +60,9 @@ module DashboardHelper
data: [
[‘Active’, #{report[:active_hosts]}],
[‘Error’, #{report[:bad_hosts]}],
['OK', #{report[:good_hosts]}],
['Out of sync', #{report[:out_of_sync_hosts]}]
['OK', #{report[:ok_hosts]}],
['Out of sync', #{report[:out_of_sync_hosts]}],
['No report', #{report[:reports_missing]}]
1.7.2.5
whats the diff between out of sync and no reports?
Thanks
Ohad
On Tue, Oct 25, 2011 at 9:35 PM, Tim Speetjens wrote:
> to me this makes sense. Don't shoot me if the logic isn't 100% correct...
> Tim
> index ea8f10f..7e915b4 100644
> --- a/app/controllers/dashboard_controller.rb
> + @report[:ok_hosts] = @report[:good_hosts] - @report[:active_hosts]
> + @report[:reports_missing] = @report[:total_hosts] -
> end
> end
> index af3e205..ed0d3e6 100644
> --- a/app/helpers/dashboard_helper.rb
> data: [
> ['Active', #{report[:active_hosts]}],
> ['Error', #{report[:bad_hosts]}],
> - ['OK', #{report[:good_hosts]}],
> - ['Out of sync', #{report[:out_of_sync_hosts]}]
> + ['OK', #{report[:ok_hosts]}],
> + ['Out of sync', #{report[:out_of_sync_hosts]}],
> + ['No report', #{report[:reports_missing]}]
> 1.7.2.5
The hosts that haven't reported at all, or technically where
last_reported is null would be.
I agree that in many cases this would become UI bloat. Maybe just show
it when it's applicable?
Tim
Op 26 oktober 2011 16:00 heeft Ohad Levy het volgende geschreven:
>> Tim
>> end
>> end
>> data: [
>> 1.7.2.5
> Thanks
> Ohad
I found out yesterday that the patch only corrects the values in the
pie. The real cause of the problem seems to be an invalid search
scope.
I have a patch ready, when I'm done testing, I'll submit it.
Tim
> scope.
thanks, I've already commited this one, so please make a new one.
ohad
On Fri, Oct 28, 2011 at 8:28 AM, Tim Speetjens wrote:
> Tim
>> scope.
I noticed. I'll take the latest git code to start from.
Tim
Op 28 oktober 2011 08:58 heeft Ohad Levy het volgende geschreven:
ohad
Tim
