Hi -dev,
The other day I spent some time writing a simple bash script to automate
foreman-docker releases so that the only input would be the version
number, name and email:
All it does is:
- Change version.rb and tag repo, submit to rubygems.org
- Modify RPM spec and submit pull-request
- Modify deb sources and submit pull-request
It has a lot of room for improvement, but I think it'd be possible for
other plugins (especially if they don't maintain 2 separate main
versions) to take it. Thoughts?
-- Daniel Lobato Garcia@eLobatoss
blog.daniellobato.me
daniellobato.me
Keybase: https://keybase.io/elobato
