Thanks, I've added you to the ABRT team so you've now got commit rights.
At a glance it looks like master might be compatible, but it probably
needs testing at least, and a release cut.
If you can let me know which e-mail address you use for rubygems.org
then I can add you to the two gems.
On 20/04/16 16:18, Lukas Zapletal wrote:
>> - foreman_abrt
> I wont let this one fall. Please count me in.
I've fixed the plugin for Rails 4.2:
and also fixed another incompatibility with recent changes in Smart
Proxy core:
It looks like the changes may be released, so please also update the
packages if you wish to keep them maintained.
> https://github.com/theforeman/foreman_abrt/pull/9
> Proxy core:
> https://github.com/theforeman/smart_proxy_abrt/pull/7
> Tested with develop branches.
