I’m trying to upgrade my Katello install on Oracle Linux 7.9 to Oracle Linux 8 using Leapp. The preupgrade fails at the dnf_transaction_check with many dependency resolution errors. Resolving them by removing packages as suggested in the documentation would effectively uninstall Katello and Foreman from my system. Is a Leapp upgrade doable?
Successful Leapp upgrade resulting in an Oracle Linux 8 system.
Foreman versions:
Foreman 3.3, Katello 4.5
Problem 1: package rubygem-deface-1.5.3-3.el8.noarch requires rubygem(nokogiri) >= 1.6, but none of the providers can be installed
- package rubygem-foreman_remote_execution-7.2.2-1.fm3_3.el8.noarch requires rubygem(deface), but none of the providers can be installed
- package rubygem-nokogiri-1.11.3-2.el8.x86_64 requires bundled(rubygem-racc) >= 1.4, but none of the providers can be installed
- package rubygem-nokogiri-1.11.3-2.el8.x86_64 requires bundled(rubygem-racc) < 2, but none of the providers can be installed
- cannot install the best candidate for the job
- package ruby-libs-2.7.1-133.module+el8.3.0+7760+537395ec.i686 is filtered out by modular filtering
- package ruby-libs-2.7.1-133.module+el8.3.0+7760+537395ec.x86_64 is filtered out by modular filtering
- package ruby-libs-2.7.3-136.module+el8.4.0+20239+cbf59dc8.i686 is filtered out by modular filtering
- package ruby-libs-2.7.3-136.module+el8.4.0+20239+cbf59dc8.x86_64 is filtered out by modular filtering
- package ruby-libs-2.7.4-137.module+el8.4.0+20269+fcbf533e.i686 is filtered out by modular filtering
- package ruby-libs-2.7.4-137.module+el8.4.0+20269+fcbf533e.x86_64 is filtered out by modular filtering
- package ruby-libs-2.7.6-138.module+el8.6.0+20740+358d9979.i686 is filtered out by modular filtering
- package ruby-libs-2.7.6-138.module+el8.6.0+20740+358d9979.x86_64 is filtered out by modular filtering
- package ruby-libs-3.0.2-140.module+el8.5.0+20407+0c654ebc.i686 is filtered out by modular filtering
- package ruby-libs-3.0.2-140.module+el8.5.0+20407+0c654ebc.x86_64 is filtered out by modular filtering
- package ruby-libs-3.0.4-141.module+el8.6.0+20741+4fdba061.i686 is filtered out by modular filtering
- package ruby-libs-3.0.4-141.module+el8.6.0+20741+4fdba061.x86_64 is filtered out by modular filtering
- package ruby-libs-3.1.2-141.module+el8.7.0+20780+b11ff321.i686 is filtered out by modular filtering
- package ruby-libs-3.1.2-141.module+el8.7.0+20780+b11ff321.x86_64 is filtered out by modular filtering
Problem 2: package rubygem-deface-1.5.3-3.el8.noarch requires rubygem(nokogiri) >= 1.6, but none of the providers can be installed
- package rubygem-katello-4.5.1-1.el8.noarch requires rubygem(deface) >= 1.0.2, but none of the providers can be installed
- package rubygem-katello-4.5.1-1.el8.noarch requires rubygem(deface) < 2.0.0, but none of the providers can be installed
Problem 3: package candlepin-4.1.11-1.el8.noarch requires tomcatjss >= 7.2.1-7.1, but none of the providers can be installed
- package katello-4.5.1-1.el8.noarch requires candlepin >= 2.0, but none of the providers can be installed
- package tomcatjss-7.2.5-1.el7.noarch requires tomcat >= 7.0.68, but none of the providers can be installed
- candlepin-4.1.11-1.el7.noarch does not belong to a distupgrade repository
- conflicting requests
- package tomcatjss-7.3.6-1.module+el8+5153+a528e508.noarch is filtered out by modular filtering
- package tomcatjss-7.4.1-1.module+el8.1.0+5401+ee4f2d9d.noarch is filtered out by modular filtering
- package tomcatjss-7.4.1-2.module+el8.2.0+5594+09d37207.noarch is filtered out by modular filtering
- package tomcatjss-7.4.1-2.module+el8.2.0+7620+3306ac3c.noarch is filtered out by modular filtering
- package tomcatjss-7.5.0-1.module+el8.3.0+7857+983338ee.noarch is filtered out by modular filtering
- package tomcatjss-7.6.1-1.module+el8.4.0+20053+7cddd5b6.noarch is filtered out by modular filtering
- package tomcatjss-7.7.0-1.module+el8.5.0+20349+9cc212a8.noarch is filtered out by modular filtering
- package tomcatjss-7.7.1-1.module+el8.6.0+20558+60d461b7.noarch is filtered out by modular filtering
Problem 4: package rubygem-sqlite3-1.4.2-1.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- package rh-ruby27-ruby-libs-2.7.4-130.el7.x86_64 requires libgdbm.so.4()(64bit), but none of the providers can be installed
- package rubygem-smart_proxy_dynflow-0.8.1-1.fm3_3.el8.noarch requires rubygem(sqlite3), but none of the providers can be installed
- gdbm-1.10-8.el7.x86_64 does not belong to a distupgrade repository
Problem 5: package rubygem-unicode-0.4.4.4-4.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- package rh-ruby27-ruby-libs-2.7.4-130.el7.x86_64 requires libreadline.so.6()(64bit), but none of the providers can be installed
- package rubygem-hammer_cli-3.3.0-1.el8.noarch requires rubygem(unicode), but none of the providers can be installed
- readline-6.2-11.el7.x86_64 does not belong to a distupgrade repository
Problem 6: package rubygem-foreman_puppet-4.0.4-1.fm3_3.el8.noarch requires foreman >= 3.0, but none of the providers can be installed
- package foreman-3.3.0-0.5.rc1.el8.noarch requires rubygem(facter), but none of the providers can be installed
- package foreman-3.3.0-0.5.rc2.el8.noarch requires rubygem(facter), but none of the providers can be installed
- package foreman-3.3.0-1.el8.noarch requires rubygem(facter), but none of the providers can be installed
- package foreman-3.3.1-1.el8.noarch requires rubygem(facter), but none of the providers can be installed
- package rubygem-facter-4.0.51-2.el8.x86_64 requires rubygem(thor) < 2.0, but none of the providers can be installed
- foreman-3.3.1-1.el7.noarch does not belong to a distupgrade repository
Problem 7: package rh-ruby27-ruby-libs-2.7.4-130.el7.x86_64 requires libreadline.so.6()(64bit), but none of the providers can be installed
- package rubygem-unicode-0.4.4.4-4.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- cannot install both readline-7.0-10.el8.x86_64 and readline-6.2-11.el7.x86_64
- package gdb-headless-8.2-19.0.1.el8.x86_64 requires libreadline.so.7()(64bit), but none of the providers can be installed
- package rubygem-hammer_cli_foreman-3.3.0-1.el8.noarch requires rubygem(hammer_cli) >= 2.1.0, but none of the providers can be installed
- package rubygem-hammer_cli_foreman-3.3.0-1.el8.noarch requires rubygem(hammer_cli) >= 3.3.0, but none of the providers can be installed
Problem 8: package rh-ruby27-ruby-libs-2.7.4-130.el7.x86_64 requires libreadline.so.6()(64bit), but none of the providers can be installed
- package rubygem-msgpack-1.3.3-2.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- package rubygem-dynflow-1.6.4-1.fm3_3.el8.noarch requires rubygem(msgpack) >= 1.3, but none of the providers can be installed
- package rubygem-dynflow-1.6.4-1.fm3_3.el8.noarch requires rubygem(msgpack) < 2, but none of the providers can be installed
- package rubygem-dynflow-1.6.4-1.fm3_3.el8.noarch requires rubygem(msgpack) >= 1.3.3, but none of the providers can be installed
- package rubygem-dynflow-1.6.4-1.fm3_3.el8.noarch requires (rubygem(msgpack) >= 1.3 with rubygem(msgpack) < 2 with rubygem(msgpack) >= 1.3.3), but none of the providers can be installed
- package postgresql-10.23-1.module+el8.7.0+20896+16771be9.x86_64 requires libreadline.so.7()(64bit), but none of the providers can be installed
- package rubygem-foreman-tasks-6.0.2-1.fm3_3.el8.noarch requires rubygem(dynflow) >= 1.6.0, but none of the providers can be installed
Problem 9: package rubygem-unicode-0.4.4.4-4.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- package python2-libs-2.7.18-11.0.1.module+el8.7.0+20809+34912fc4.x86_64 requires libreadline.so.7()(64bit), but none of the providers can be installed
- package rubygem-hammer_cli_foreman_remote_execution-0.2.2-1.fm3_0.el8.noarch requires rubygem(hammer_cli_foreman) < 4.0.0, but none of the providers can be installed
- package rubygem-hammer_cli_foreman_remote_execution-0.2.2-1.fm3_0.el8.noarch requires rubygem(hammer_cli_foreman) >= 0.1.3, but none of the providers can be installed
- package rubygem-hammer_cli_foreman_remote_execution-0.2.2-1.fm3_0.el8.noarch requires (rubygem(hammer_cli_foreman) >= 0.1.3 with rubygem(hammer_cli_foreman) < 4.0.0), but none of the providers can be installed
Problem 10: package rubygem-unicode-0.4.4.4-4.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- package ipmievd-1.8.18-18.el8.x86_64 requires libreadline.so.7()(64bit), but none of the providers can be installed
- package rubygem-hammer_cli_foreman_bootdisk-0.3.0-2.el8.noarch requires rubygem(hammer_cli_foreman) >= 0.1.2, but none of the providers can be installed
Problem 11: package rh-ruby27-ruby-libs-2.7.4-130.el7.x86_64 requires libreadline.so.6()(64bit), but none of the providers can be installed
- package postgresql-server-10.23-1.module+el8.7.0+20896+16771be9.x86_64 requires postgresql(x86-64) = 10.23-1.module+el8.7.0+20896+16771be9, but none of the providers can be installed
- package rubygem-hammer_cli_foreman_tasks-0.0.17-1.fm3_2.el8.noarch requires rubygem(hammer_cli_foreman) < 4.0.0, but none of the providers can be installed
- package rubygem-hammer_cli_foreman_tasks-0.0.17-1.fm3_2.el8.noarch requires rubygem(hammer_cli_foreman) > 0.1.1, but none of the providers can be installed
- package rubygem-hammer_cli_foreman_tasks-0.0.17-1.fm3_2.el8.noarch requires (rubygem(hammer_cli_foreman) > 0.1.1 with rubygem(hammer_cli_foreman) < 4.0.0), but none of the providers can be installed
Problem 12: package rh-ruby27-ruby-libs-2.7.4-130.el7.x86_64 requires libreadline.so.6()(64bit), but none of the providers can be installed
- package python3-libs-3.6.8-48.0.1.el8_7.x86_64 requires libreadline.so.7()(64bit), but none of the providers can be installed
- package platform-python-3.6.8-48.0.1.el8_7.x86_64 requires python3-libs(x86-64) = 3.6.8-48.0.1.el8_7, but none of the providers can be installed
- package rubygem-hammer_cli_katello-1.5.3-1.el8.noarch requires rubygem(hammer_cli_foreman), but none of the providers can be installed
Problem 13: package rubygem-unicode-0.4.4.4-4.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- package OpenIPMI-2.0.31-3.0.1.el8.x86_64 requires libreadline.so.7()(64bit), but none of the providers can be installed
- package rubygem-hammer_cli_foreman_puppet-0.0.6-1.fm3_3.el8.noarch requires rubygem(hammer_cli_foreman) < 4.0.0, but none of the providers can be installed
- package rubygem-hammer_cli_foreman_puppet-0.0.6-1.fm3_3.el8.noarch requires rubygem(hammer_cli_foreman) > 2.6.0, but none of the providers can be installed
- package rubygem-hammer_cli_foreman_puppet-0.0.6-1.fm3_3.el8.noarch requires (rubygem(hammer_cli_foreman) > 2.6.0 with rubygem(hammer_cli_foreman) < 4.0.0), but none of the providers can be installed
- package OpenIPMI-lanserv-2.0.31-3.0.1.el8.x86_64 requires OpenIPMI(x86-64) = 2.0.31-3.0.1.el8, but none of the providers can be installed
Problem 14: package rubygem-smart_proxy_remote_execution_ssh-0.7.2-1.fm3_3.el8.noarch requires rubygem(smart_proxy_dynflow) < 1, but none of the providers can be installed
- package rubygem-smart_proxy_remote_execution_ssh-0.7.2-1.fm3_3.el8.noarch requires rubygem(smart_proxy_dynflow) >= 0.8, but none of the providers can be installed
- package rubygem-smart_proxy_remote_execution_ssh-0.7.2-1.fm3_3.el8.noarch requires (rubygem(smart_proxy_dynflow) >= 0.8 with rubygem(smart_proxy_dynflow) < 1), but none of the providers can be installed
- package tfm-rubygem-smart_proxy_remote_execution_ssh-0.7.2-1.fm3_3.el7.noarch requires rh-ruby27-ruby(release), but none of the providers can be installed
- package rubygem-sqlite3-1.4.2-1.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- package postgresql-contrib-10.23-1.module+el8.7.0+20896+16771be9.x86_64 requires postgresql(x86-64) = 10.23-1.module+el8.7.0+20896+16771be9, but none of the providers can be installed
Problem 15: package rubygem-smart_proxy_pulp-3.2.0-3.fm3_3.el8.noarch requires foreman-proxy >= 2.3, but none of the providers can be installed
- package foreman-proxy-3.3.0-0.1.rc1.el8.noarch requires rubygem(ruby-libvirt) >= 0.6.0, but none of the providers can be installed
- package foreman-proxy-3.3.0-0.1.rc2.el8.noarch requires rubygem(ruby-libvirt) >= 0.6.0, but none of the providers can be installed
- package foreman-proxy-3.3.0-1.el8.noarch requires rubygem(ruby-libvirt) >= 0.6.0, but none of the providers can be installed
- package foreman-proxy-3.3.1-1.el8.noarch requires rubygem(ruby-libvirt) >= 0.6.0, but none of the providers can be installed
- package rubygem-ruby-libvirt-0.7.1-2.el8.x86_64 requires libruby.so.2.7()(64bit), but none of the providers can be installed
- package python2-2.7.18-11.0.1.module+el8.7.0+20809+34912fc4.x86_64 requires python2-libs(x86-64) = 2.7.18-11.0.1.module+el8.7.0+20809+34912fc4, but none of the providers can be installed
- package python2-devel-2.7.18-11.0.1.module+el8.7.0+20809+34912fc4.x86_64 requires python2(x86-64) = 2.7.18-11.0.1.module+el8.7.0+20809+34912fc4, but none of the providers can be installed
- foreman-proxy-3.3.1-1.el7.noarch does not belong to a distupgrade repository
