Trying to set host parameter (admittedly, this is Satellite 6.5.2…ducks), via Python, using requests.post(). verify=False, and I have to specify the Sat server as regular “http”.
Am providing a simple dict data structure for parameter, and passing it through json.dumps()
“parameter” : {
“name” : “puppet_role”,
“value” : “server”,
foreman production log shows:
2019-08-16T11:49:03 [I|app|] Started POST "/api/v2/hosts/testhost.foo.de/parameters" for 129.129.194.136 at 2019-08-16 11:49:03 +0200
2019-08-16T11:49:03 [I|app|425e8cfe] Processing by Api::V2::ParametersController#create as JSON
2019-08-16T11:49:03 [I|app|425e8cfe] Parameters: {"parameter"=>{"name"=>"puppet_role", "value"=>"[FILTERED]"}, "apiv"=>"v2", "host_id"=>"testhost.foo.de"}
2019-08-16T11:49:03 [I|app|425e8cfe] Redirected to https://sat.foo.de/api/v2/hosts/testhost.foo.de/parameters
2019-08-16T11:49:03 [I|app|425e8cfe] Filter chain halted as #<Proc:0x0000000009b40100@/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/force_ssl.rb:67> rendered or redirected
2019-08-16T11:49:03 [I|app|425e8cfe] Completed 301 Moved Permanently in 1ms (ActiveRecord: 0.0ms)
The script outputs:
DEBUG: http://sat.foo.de/api/v2/hosts/testhost.foo.de/parameters
POST -> POST'ing with: http://sat.foo.de/api/v2/hosts/testhost.foo.de/parameters
{u'sort': {u'by': None, u'order': None}, u'search': None, u'results': [], u'per_page': 20, u'total': 0, u'subtotal': 0, u'page': 1}
GET -> DEBUG HOST PARAMS: False
Any advice appreciated. My feeling is, SSL problems. I have the katello-server-ca.crt and have also tried requests.post() with the crt and https-version of Satellite, but things then the error slightly changes:
2019-08-16T12:01:40 [I|app|] Started POST "/api/v2/hosts/testhost.foo.de/parameters" for 129.129.194.136 at 2019-08-16 12:01:40 +0200
2019-08-16T12:01:40 [I|app|fb894a18] Processing by Api::V2::ParametersController#create as JSON
2019-08-16T12:01:40 [I|app|fb894a18] Parameters: {"parameter"=>{"name"=>"puppet_role", "value"=>"[FILTERED]"}, "apiv"=>"v2", "host_id"=>"testhost.foo.de"}
2019-08-16T12:01:40 [I|app|fb894a18] Authorized user foodbenc(foodbenc)
2019-08-16T12:01:40 [I|app|fb894a18] Current user set to foodbenc (regular)
2019-08-16T12:01:40 [I|app|fb894a18] Rendering api/v2/errors/not_found.json.rabl within api/v2/layouts/error_layout
2019-08-16T12:01:40 [I|app|fb894a18] Rendered api/v2/errors/not_found.json.rabl within api/v2/layouts/error_layout (2.5ms)
2019-08-16T12:01:40 [I|app|fb894a18] Filter chain halted as :find_required_nested_object rendered or redirected
2019-08-16T12:01:40 [I|app|fb894a18] Completed 404 Not Found in 111ms (Views: 14.4ms | ActiveRecord: 27.4ms)
That the parameter is set.
foreman-1.20.1.35-1.el7sat.noarch
foreman-proxy-1.20.0-1.el7sat.noarch
N/A
logs
