Executing bash code within finish scripts and snippets.
Foreman 3.7 Katello 4.9
As I am new to foreman and unfamiliar with the ERB template syntax I am wondering if it is possible to imbed bash scripting within the template. As an example I added the following within the default finish script and within a snippet with no results. The preview of the template/snippet showed no errors.
Yes, it’s totally possible, that’s the exact use case for the templates.
What are you trying to achieve with the template above?
For adding remote execution keys we have remote_execution_ssh_keys.erb snippet, maybe that’s what you are looking for.
Thank you for your response.
My ultimate goal here is to create a master finish script when provisioning clients.
For example to include authorized keys, register the host with CDN, configure zabbix clients and more. Can I assume that a snippet can be a bash script that you call within a finish template. My attempt at placing a bash script within a finish template did not work.
For example:
#!/usr/bin/bash
shell commands.
There were no errors in the log files.
Is this the correct way of doing this. Any information would be greatly appreciated.
Am also investigating how to configure virt-who for client registration.
Did you say which OS you’re installing and what installation method you’re using? For Kickstart several of the steps you listed are included in the default %post if you set the right host parameters.
