After upgrading from 2.4.x to 2.5.4, we started getting errors when attempting to build RHEL hosts which were configured with subscription manager settings. It was complaining about not being able to access the katello_agent_enabled
value due to Safe Mode.
It looks like this change was merged in for the 2.5 release: Fixes #32458 - Disable katello agent install by default when provisioning by jturel · Pull Request #8480 · theforeman/foreman · GitHub
I don’t see a reference to katello_agent_enabled
anywhere else in the Foreman codebase, and it looks like this may be a Katello specific function. We are not running Katello in our Foreman install.
Our simple fix was to unlock and revert the redhat_register
snippet to its previous value, removing the reference to katello_agent_enabled
value, and builds started working again. I imagine this change will be reverted upon our next upgrade, and since I don’t see any further changes or references in the latest Foreman codebase regarding this value, I suspect the error will return as well.
Has anyone else run into this problem, or has a suggestion for a better solution?
