We are deploying Physical servers with two h/w NICs to load balance and attach management network to both the NICs. Other two networks also passing through management network. So we create Master bond bond0 and sub bond interfaces like bond0.valn1 and bond0.vlan2 for other networks. Below is the sample setup.
eth0 -> Physical Nic (slave) | eth1 -> Physical Nic (slave) |
ifcfg.bond0 -> master
ifcfg.bond0.vlan1 -> IP - 1.1.1.1
ifcfg.bond0.vlan2 -> IP - 2.2.2.2
ifcfg.bond0.vlan3 -> IP - 3.3.3.3
Please let me know how to use foreman templates to deploy this configuration.
I am using foreman version 1.17
