**Problem:** Foreman-Installer - ruby spawn (Errno::ENOENT)
I tried to install Foreman on a test VM running with Ubuntu 20.04. I added the Foreman 3.7 repository.
Actually i get following error if i want to install the Foreman-Installer. As seen the Problem is Ruby related but i already installed a needed packages.
*/usr/lib/ruby/2.7.0/open3.rb:213:in `spawn’: No such file or directory - facter (Errno::ENOENT)
Do i miss something or something need to be changed ?
foreman-installer (3.7.0-1+ubuntu2004) wird eingerichtet …
20: from /usr/sbin/foreman-installer:8:in <main>' 19: from /usr/lib/ruby/vendor_ruby/kafo/kafo_configure.rb:50:in run’
18: from /usr/share/rubygems-integration/all/gems/clamp-1.3.2/lib/clamp/command.rb:140:in run' 17: from /usr/share/rubygems-integration/all/gems/clamp-1.3.2/lib/clamp/command.rb:140:in new’
16: from /usr/lib/ruby/vendor_ruby/kafo/kafo_configure.rb:115:in initialize' 15: from /usr/lib/ruby/vendor_ruby/kafo/configuration.rb:325:in run_migrations’
14: from /usr/lib/ruby/vendor_ruby/kafo/migrations.rb:35:in run' 13: from /usr/lib/ruby/vendor_ruby/kafo/migrations.rb:35:in each’
12: from /usr/lib/ruby/vendor_ruby/kafo/migrations.rb:38:in block in run' 11: from /usr/lib/ruby/vendor_ruby/kafo/migration_context.rb:10:in execute’
10: from /usr/lib/ruby/vendor_ruby/kafo/migration_context.rb:10:in instance_eval' 9: from /usr/lib/ruby/vendor_ruby/kafo/migrations.rb:25:in block (2 levels) in load_migrations’
8: from /usr/lib/ruby/vendor_ruby/kafo/migrations.rb:25:in instance_eval' 7: from /etc/foreman-installer/scenarios.d/foreman.migrations/20200909151007_manage_acls_on_debian.rb:1:in block (2 levels) in load_migrations’
6: from /usr/lib/ruby/vendor_ruby/kafo/base_context.rb:6:in facts' 5: from /usr/lib/ruby/vendor_ruby/kafo/base_context.rb:29:in facts’
4: from /usr/lib/ruby/vendor_ruby/kafo/base_context.rb:39:in run_command' 3: from /usr/lib/ruby/2.7.0/open3.rb:281:in capture3’
2: from /usr/lib/ruby/2.7.0/open3.rb:101:in popen3' 1: from /usr/lib/ruby/2.7.0/open3.rb:213:in popen_run’
dpkg: Fehler beim Bearbeiten des Paketes foreman-installer (–configure):
»installiertes foreman-installer-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
Trigger für man-db (2.9.1-1) werden verarbeitet …
Fehler traten auf beim Bearbeiten von:
foreman-installer
E: Sub-process /usr/bin/dpkg returned an error code (1)
Henrik
