I’m having a problem syncing a specific rpm-repo from Bacula Entreprise Edition.
These are the available product repo’s (folders):
Each product has following subfolders: version → {rhel7-64 | rhel8-64 | sles152-64 | sles153-64}.
Example:
rhel7-64 content:
For the products “bin” and “dedup” the sync goes perfect, but for bweb (only available in the enterprise version) it fails with the error:
404, message=‘Not Found’, url=URL(‘https://www.baculasystems.com/dl/< user >-< password >/rpms/bweb/12.8.1/rhel7-64/Dependencies/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/rhel7/perl-Net-SSH-Perl-1.34-1.el7.centos.noarch.rpm’)
The “bweb” contains an extra “Dependencies” folder which in turn contains also subfolders.
Each of these folder / sub-folders contain the required dependency packages.
Dependencies:
Dependencies/guestfish-1.32:
As you can see in the error, for some reason Katello or pulp got in some kind of a loop when processing the folder “Dependencies” by using “rhel7” as sub-folder several times which does not exist.
Below, when I create a separate repo for the subfolder “Dependencies” the sync of it works also well, containing all the packages from the folder “Dependencies” as well those from the sub-folders “guestfish-1.32” and “guestfish”. But no idea if this would work fine when using it on a client.
Anyone who can confirm if this is a restriction/bug within katello/pulp.
FYI, when I use this repo-config directly on a system it all works fine.
Correct processing of a repo with all of its sub-folders when applicable.
Foreman 2.4.0
Katello 4.0.0
python3-pulpcore-3.9.1
CentOS Linux release 8.3.2011
