We have a physical server running foreman 3.11.2 katello 4.13 on EL8 and and moved to a vm foreman 3.2.1 katello 4.14 EL9
Steps:
Shutdown physical server
Deploy EL9 vm and install Foreman 3.2.1 Katello 4.14
Restore pulp data from backup
Run dnf update from any of the hosts
After upgrading to new vm and restoring the pulp data, the host clients hang on subscription-manager
Hosts to be able to run dnf
3.11.2 → 3.12.1
3.12.1:
foreman-installer --scenario katello
foreman-plugin-remote-execution
foreman-proxy
foreman-proxy-plugin-remote-execution-script
The VM is turned off and won’t be able to capture more data until Saturday.
When I bring up the server on Saturday, any suggestions on what to look for in the logs?
foreman-maintain service status
Is Candlepin (tomcat) showing OK?
You can also try tailing /var/log/foreman/production.log while attempting to register.
Thanks for the quick response, I’ll definitely check candlepin and the production logs. Also these hosts are already registered from the backup.
foreman-maintain restore /location/of/the/backup
@jeremylenz thanks for your response, I went ahead and redeployed the VM and ran the restore. The previous restore finished sooner than expected so I suspect the issue may have been with the restore.
I rebuilt the vm and ran the playbook with the following foreman-installer settings:
foreman-installer --scenario katello -l ERROR \
--foreman-initial-organization "MY ORG" \
--foreman-initial-location "MY LOCATION" \
--foreman-initial-admin-username "MY USER" \
--enable-foreman-plugin-remote-execution \
--enable-foreman-proxy \
The foreman-installer worked as expected, after the installation I ran foreman-maintain restore -y /backup/katello-backup-(latest date)
took longer then the previous restore and completed as expected. The restore added all the settings from the physical server and the hosts connected to the server as expected
Thanks again, this is an awesome platform!
