installed a new foreman with 0, deployed repositories on it. rpm repositories sync normally, packages are visible, everything is fine, but the deb repository writes “success”, but there are 0 packages, and there are no errors. All that could be found is that the release file for some reason does not contain checksums, but they are on the site archive.ubuntu.com. A huge request tell me in which direction to look to solve the problem. Expected outcome:
syncing repositories with package downloads Foreman and Proxy versions:
2.4 Foreman and Proxy plugin versions:
2.4 Distribution and version:
Yes, it really works… Thank you very much! But earlier on version 2.1 of foreman and katello 3, you could specify the revision with “,” and it worked. At the moment, this has become impossible?
Sorry I did not see this earlier.
This is a UI bug. The UI asks for components and architectures as a comma separated list.
However Pulp 3 needs a space separated list.
Instead of:
Components: main,restricted,universe,multiverse
Use the following and your sync should work:
Components: main restricted universe multiverse
There is an open issue to fix the UI on the Katello side.
P.S.: I am on holiday for the next week so I won’t be here to answer any questions, you can ping @m-bucher instead.
