Problem: repomd.xml.asc is either not synced or generated in centos repo.
Problem started within the last week. No “apparent” changes have been made.
Not sure if this is a syncronized file or a generated file and not sure where to look to debug the issue. I suspect it is generated as I have not seen any attempt to sync in our log files.
Expected outcome: repomd.xml.asc should be created for yum gpgcheck to work
foreman-debug-1.23.1-1.el7.noarch
Foreman-Reference-Implementation-0.0.4-20180810.x86_64
foreman-1.23.1-1.el7.noarch
foreman-installer-1.23.1-1.el7.noarch
foreman-postgresql-1.23.1-1.el7.noarch
foreman-installer-katello-1.23.1-1.el7.noarch
foreman-proxy-1.23.1-1.el7.noarch
foreman-vmware-1.23.1-1.el7.noarch
foreman-selinux-1.23.1-1.el7.noarch
foreman-cli-1.23.1-1.el7.noarch
