After upgrade (CentOS 7.6) from 1.19 into 1.20, using method descibed and standard repositories I am getting:
[root@foreman ~]# foreman-rake db:migrate --trace
** Invoke db:migrate (first_time)
** Invoke db:load_config (first_time)
** Execute environment
API controllers newer than Apipie cache! Run apipie:cache rake task to regenerate cache.
rake aborted!
ArgumentError: Passing string to be evaluated in :if and :unless conditional options is not supported. Pass a symbol for an instance method, or a lambda, proc or block, instead.
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:355:in `check_conditionals'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:301:in `initialize'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:289:in `new'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:289:in `build'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:672:in `block in set_callback'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:671:in `map'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:671:in `set_callback'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/callbacks.rb:149:in `block in _define_after_model_callback'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_custom_parameters-0.0.2/app/models/foreman_custom_parameters/add_defaults.rb:7:in `block in <module:AddDefaults>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/concern.rb:122:in `class_eval'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/concern.rb:122:in `append_features'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_custom_parameters-0.0.2/lib/foreman_custom_parameters/engine.rb:5:in `include'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_custom_parameters-0.0.2/lib/foreman_custom_parameters/engine.rb:5:in `block in <class:Engine>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:426:in `instance_exec'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:426:in `block in make_lambda'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:198:in `block (2 levels) in halting'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:606:in `block (2 levels) in default_terminator'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:605:in `catch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:605:in `block in default_terminator'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:199:in `block in halting'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `block in invoke_before'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:513:in `invoke_before'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:131:in `run_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/reloader.rb:89:in `prepare!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application/finisher.rb:63:in `block in <module:Finisher>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:32:in `instance_exec'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:32:in `run'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:228:in `block in tsort_each'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:431:in `each_strongly_connected_component_from'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:349:in `block in each_strongly_connected_component'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `each'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `call'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:347:in `each_strongly_connected_component'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:226:in `tsort_each'
/opt/rh/rh-ruby25/root/usr/share/ruby/tsort.rb:205:in `tsort_each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:60:in `run_initializers'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:361:in `initialize!'
/usr/share/foreman/config/environment.rb:5:in `<top (required)>'
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:59:in `require'
/opt/theforeman/tfm/root/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:287:in `block in require'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:253:in `load_dependency'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:287:in `require'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:337:in `require_environment!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:520:in `block in run_tasks_blocks'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:251:in `block in execute'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:251:in `each'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:251:in `execute'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:195:in `block in invoke_with_call_chain'
/opt/rh/rh-ruby25/root/usr/share/ruby/monitor.rb:226:in `mon_synchronize'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:188:in `invoke_with_call_chain'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:217:in `block in invoke_prerequisites'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:215:in `each'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:215:in `invoke_prerequisites'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:194:in `block in invoke_with_call_chain'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/task.rb:181:in `invoke'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:160:in `invoke_task'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:116:in `each'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:116:in `block in top_level'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:125:in `run_with_threads'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:110:in `top_level'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:83:in `block in run'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/lib/rake/application.rb:80:in `run'
/opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/exe/rake:27:in `<top (required)>'
/opt/rh/rh-ruby25/root/usr/bin/rake:23:in `load'
/opt/rh/rh-ruby25/root/usr/bin/rake:23:in `<main>'
Tasks: TOP => db:migrate => db:load_config => environment
Working Foreman.
foreman.noarch 1.20.2-1.el7 @foreman
foreman-cli.noarch 1.20.2-1.el7 @foreman
foreman-compute.noarch 1.20.2-1.el7 @foreman
foreman-debug.noarch 1.20.2-1.el7 @foreman
foreman-ec2.noarch 1.20.2-1.el7 @foreman
foreman-installer.noarch 1:1.20.2-1.el7 @foreman
foreman-postgresql.noarch 1.20.2-1.el7 @foreman
foreman-proxy.noarch 1.20.2-1.el7 @foreman
foreman-release.noarch 1.20.2-1.el7 installed
logs
Can someone point me - where to look, what to check?
