I have the following
HOSTNAME: t2gw03.t2.ucsd.edu
OS: redhat
RELEASE: CentOS release 6.5 (Final)
FOREMAN: 1.4.2
RUBY: ruby 1.8.7 (2011-06-30 patchlevel 352) [x86_64-linux]
PUPPET: 3.5.1
I uploaded the debug run results via the tool.
I recently installed foreman 1.4.2 and it came with an older version of
puppet. I then upgrade to the latest puppet 3.5.1 that I could get.
Foreman is running, and reading the puppet stuff in the web interface, but
the agent and the server keep complaining with the following error.
May 7 15:31:52 t2gw03 puppet-master[16443]: no 'environments' in
{:current_environment=>#<Puppet::Node::Environment:0x7f0fba8a1990
@name=:"root", @manifest="/etc/puppet/rack", @modulepath=[]>,
:root_environment=>#<Puppet::Node::Environment:0x7f0fba8a1990
@name=:"root", @manifest="/etc/puppet/rack", @modulepath=[]>} at top of []
Now, if I shut down apache and run puppetmaster directly I get a different
result on the client node…
Warning: Unable to fetch my node definition, but the agent run will
continue:
Warning: Error 400 on SERVER: Failed to find cabinet-4-4-0.t2.ucsd.edu via
exec: Execution of '/etc/puppet/node.rb cabinet-4-4-0.t2.ucsd.edu' returned
1:
Info: Retrieving pluginfacts
Info: Loading facts in /var/lib/puppet/lib/facter/facter_dot_d.rb
Info: Loading facts in /var/lib/puppet/lib/facter/concat_basedir.rb
Info: Loading facts in /var/lib/puppet/lib/facter/root_home.rb
Info: Loading facts in /var/lib/puppet/lib/facter/pe_version.rb
Info: Loading facts in /var/lib/puppet/lib/facter/puppet_vardir.rb
Error: Could not retrieve catalog from remote server: Error 400 on SERVER:
Failed when searching for node cabinet-4-4-0.t2.ucsd.edu: Failed to find
cabinet-4-4-0.t2.ucsd.edu via exec: Execution of '/etc/puppet/node.rb
cabinet-4-4-0.t2.ucsd.edu' returned 1:
Different, not really working, but different.
I must have some configuration mess up somewhere, but I am just not sure
where.
Any suggestions?
Terrence
> Hi,
> OS: redhat
> FOREMAN: 1.4.2
> PUPPET: 3.5.1
Depending on what you upgraded from (maybe 2.7 from EPEL?) then there
might be some config changes to make.
See
http://projects.theforeman.org/projects/foreman/wiki/FAQ#Upgrade-puppet-from-v2-to-v3-gotchas
(and of course, the release notes. Or re-run the foreman-installer.)
> but the agent and the server keep complaining with the following error.
> different result on the client node…
> continue:
> via exec: Execution of '/etc/puppet/node.rb cabinet-4-4-0.t2.ucsd.edu'
> returned 1:
> SERVER: Failed when searching for node cabinet-4-4-0.t2.ucsd.edu: Failed
> to find cabinet-4-4-0.t2.ucsd.edu via exec: Execution of
> '/etc/puppet/node.rb cabinet-4-4-0.t2.ucsd.edu' returned 1:
> where.
> Any suggestions?
Try running that command manually, copy/paste the output and also any
changes in /var/log/foreman/production.log while running it:
On 07/05/14 23:53, twm139@gmail.com wrote:
Dominic Cleal
Red Hat Engineering
