Hello Community!
After installed and configured monitor smart proxy plugin in according with github documentation (GitHub - theforeman/smart_proxy_monitoring: Smart proxy plugin for monitoring system integration), i can’t be able to switch in “legacy ui” in all hosts.
Foreman is hosted by ubuntu 20.04 server
Applications Versions:
- Foreman 3.6.1
- Foreman-proxy
The error when i try to switch to legacy ui:
The log:
Foreman version: 3.6.1
Plugins:
- foreman-tasks 7.2.1
- foreman_monitoring 3.0.0
- foreman_puppet 5.1.2
- foreman_remote_execution 9.1.0
2023-08-02T15:33:35 [I|app|6991e797] Started GET "/hosts/node4.kvm.internal" for 192.168.122.1 at 2023-08-02 15:33:35 +0200
2023-08-02T15:33:35 [I|app|6991e797] Processing by HostsController#show as HTML
2023-08-02T15:33:35 [I|app|6991e797] Parameters: {"id"=>"node4.kvm.internal"}
2023-08-02T15:33:35 [I|app|6991e797] Rendered hosts/show.html.erb within layouts/application (Duration: 219.5ms | Allocations: 43483)
2023-08-02T15:33:35 [I|app|6991e797] Rendered layout layouts/application.html.erb (Duration: 219.8ms | Allocations: 43538)
2023-08-02T15:33:35 [W|app|6991e797] undefined method `host_monitoring_result_icon_class' for #<ActionView::Base:0x0000000007ae18>
6991e797 | Did you mean? host_config_reports_url
2023-08-02T15:33:35 [I|app|6991e797] Backtrace for 'undefined method `host_monitoring_result_icon_class' for #<ActionView::Base:0x0000000007ae18>
6991e797 | Did you mean? host_config_reports_url' error (ActionView::Template::Error): undefined method `host_monitoring_result_icon_class' for #<ActionView::Base:0x0000000007ae18>
6991e797 | /usr/share/foreman/app/views/hosts/show.html.erb:96:in `block in _app_views_hosts_show_html_erb__3136656823485447181_250160'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activerecord-6.1.7.3/lib/active_record/relation/delegation.rb:88:in `each'
6991e797 | /usr/share/foreman/app/views/hosts/show.html.erb:90:in `_app_views_hosts_show_html_erb__3136656823485447181_250160'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/base.rb:247:in `public_send'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/base.rb:247:in `_run'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/template.rb:154:in `block in render'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/notifications.rb:205:in `instrument'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/template.rb:345:in `instrument_render_template'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/template.rb:152:in `render'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/renderer/template_renderer.rb:61:in `block (2 levels) in render_template'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/notifications.rb:203:in `block in instrument'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/notifications.rb:203:in `instrument'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/renderer/template_renderer.rb:56:in `block in render_template'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/renderer/template_renderer.rb:71:in `block in render_with_layout'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/renderer/template_renderer.rb:70:in `render_with_layout'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/renderer/template_renderer.rb:55:in `render_template'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/renderer/template_renderer.rb:11:in `render'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/renderer/renderer.rb:61:in `render_template_to_object'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/renderer/renderer.rb:29:in `render_to_object'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/rendering.rb:117:in `block in _render_template'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/base.rb:273:in `in_rendering_context'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/rendering.rb:116:in `_render_template'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/streaming.rb:218:in `_render_template'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/rendering.rb:103:in `render_to_body'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/abstract_controller/rendering.rb:25:in `render'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/rendering.rb:36:in `render'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/instrumentation.rb:46:in `block (2 levels) in render'
6991e797 | /usr/lib/ruby/2.7.0/benchmark.rb:308:in `realtime'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/core_ext/benchmark.rb:14:in `ms'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/instrumentation.rb:46:in `block in render'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/instrumentation.rb:86:in `cleanup_view_runtime'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activerecord-6.1.7.3/lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/instrumentation.rb:45:in `render'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/implicit_render.rb:35:in `default_render'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/basic_implicit_render.rb:6:in `block in send_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/basic_implicit_render.rb:6:in `tap'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/abstract_controller/base.rb:228:in `process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/rendering.rb:30:in `process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
6991e797 | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
6991e797 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
6991e797 | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/audited-5.3.2/lib/audited/sweeper.rb:16:in `around'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/callbacks.rb:137:in `run_callbacks'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/abstract_controller/callbacks.rb:41:in `process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/rescue.rb:22:in `process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/instrumentation.rb:33:in `process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activerecord-6.1.7.3/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/abstract_controller/base.rb:165:in `process'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionview-6.1.7.3/lib/action_view/rendering.rb:39:in `process'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal.rb:190:in `dispatch'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_controller/metal.rb:254:in `dispatch'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/routing/route_set.rb:33:in `serve'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/journey/router.rb:50:in `block in serve'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/journey/router.rb:32:in `each'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/journey/router.rb:32:in `serve'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/routing/route_set.rb:842:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/apipie-dsl-2.5.0/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/apipie-rails-0.8.2/lib/apipie/static_dispatcher.rb:68:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/apipie-rails-0.8.2/lib/apipie/extractor/recorder.rb:137:in `call'
6991e797 | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
6991e797 | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/apipie-rails-0.8.2/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/tempfile_reaper.rb:15:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/etag.rb:27:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/conditional_get.rb:27:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/head.rb:12:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/http/permissions_policy.rb:22:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/http/content_security_policy.rb:19:in `call'
6991e797 | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/session/abstract/id.rb:266:in `context'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/session/abstract/id.rb:260:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/cookies.rb:697:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/callbacks.rb:98:in `run_callbacks'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/rack/logger.rb:37:in `call_app'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/rack/logger.rb:28:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/sprockets-rails-3.4.2/lib/sprockets/rails/quiet_assets.rb:13:in `call'
6991e797 | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/request_id.rb:26:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/method_override.rb:24:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/runtime.rb:22:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/executor.rb:14:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/sendfile.rb:110:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/ssl.rb:77:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/actionpack-6.1.7.3/lib/action_dispatch/middleware/host_authorization.rb:142:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/secure_headers-6.5.0/lib/secure_headers/middleware.rb:11:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/engine.rb:539:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/railtie.rb:207:in `public_send'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/railtie.rb:207:in `method_missing'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/urlmap.rb:74:in `block in call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/urlmap.rb:58:in `each'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/rack-2.2.6.4/lib/rack/urlmap.rb:58:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/puma-5.6.5/lib/puma/configuration.rb:252:in `call'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/puma-5.6.5/lib/puma/request.rb:77:in `block in handle_request'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/puma-5.6.5/lib/puma/thread_pool.rb:340:in `with_force_shutdown'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/puma-5.6.5/lib/puma/request.rb:76:in `handle_request'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/puma-5.6.5/lib/puma/server.rb:443:in `process_client'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/puma-5.6.5/lib/puma/thread_pool.rb:147:in `block in spawn_thread'
6991e797 | /usr/share/foreman/vendor/ruby/2.7.0/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2023-08-02T15:33:35 [I|app|6991e797] Rendered common/500.html.erb within layouts/application (Duration: 0.9ms | Allocations: 679)
2023-08-02T15:33:35 [I|app|6991e797] Rendered layouts/base.html.erb (Duration: 1.6ms | Allocations: 1643)
2023-08-02T15:33:35 [I|app|6991e797] Rendered layout layouts/application.html.erb (Duration: 3.1ms | Allocations: 2581)
2023-08-02T15:33:35 [I|app|6991e797] Completed 500 Internal Server Error in 240ms (Views: 3.6ms | ActiveRecord: 11.0ms | Allocations: 50593)
i’ve only this error, the integration with icinga works great.
