Problem with pulp-puppet-module-builder usage?
I'd like to figure out where I went wrong or if there is an issue…
$ sudo puppet agent -t
Warning: Local environment: "production" doesn't match server specified node environment "KT_megacorp_Baseline_Puppet_Modules_6", switching agent to "KT_megacorp_Baseline_Puppet_Modules_6".
Info: Retrieving pluginfacts
Warning: nmcli (1.0.6) and NetworkManager (1.0.0) versions don't match. Use --nocheck to suppress the warning.
Error: Could not retrieve catalog from remote server: Error 400 on SERVER: Could not find class motd for katello-katello.example.com on node katello-katello.example.com
First I ran this…
sudo mkdir /var/www/html/pub/puppet-modules
sudo chmod a+rw /var/www/html/pub/puppet-modules
git clone https://github.com/puppetlabs/puppetlabs-motd.git
cd puppetlabs-motd
…bumped version…
sudo pulp-puppet-module-builder --output-dir /var/www/html/pub/puppet-modules .
Then I created a product with a puppet repo sync'ed from that output plus a repo synced from puppetforge…
$ hammer product info --id 17 --organization "Mega Corporation"
Label: puppet-motd
Description: Example puppet product
Sync State: Syncing Complete.
Sync Plan ID:
GPG:
GPG Key ID:
GPG Key:
Organization: Mega Corporation
Readonly: false
Deletable:
Content:
  1. Repo Name: Puppet Forge
    URL: /custom/puppet-motd/puppet-forge
    Content Type: puppet
  2. Repo Name: Puppet MOTD
    URL: /custom/puppet-motd/puppet-motd
Then I created a content view and added the puppet module to it…
$ hammer content-view info --id 6 --organization "Mega Corporation"
Warning: Option --id is deprecated. This option will be removed in Katello 2.5, Use --uuid
Label: Puppet_Modules
Composite: false
Description:
Content Host Count: 0
Yum Repositories:
Docker Repositories:
Puppet Modules:
  1. ID: 1
    Author: puppetlabs
    Created: 2016/02/01 12:45:19
    Updated: 2016/02/01 12:45:19
    Lifecycle Environments:
  2. ID: 6
  3. ID: 2
    Versions:
  4. ID: 6
    Version: 1.0
    Published: 2016/02/01 12:45:31
    Components:
Activation Keys:
After publishing and promoting to Baseline lifecycle env here is what ended up on disk…
$ ls -l /etc/puppet/environments/KT_megacorp_Baseline_Puppet_Modules_6/modules
drwxr-xr-x. 6 apache apache 4096 Jan 31 08:50 puppetlabs-motd
After moving my host to that puppet environment and adding the motd class to it, I ran puppet agent -t and got the error at the start of this email…
If I make a symlink in the modules dir like this…
lrwxrwxrwx. 1 apache apache 15 Feb 1 08:32 motd -> puppetlabs-motd
Then puppet agent -t runs clean and I can see motd updated.
So… Where did I go wrong? Why was the module created on disk named puppetlabs-motd instead of motd? Or is there some other problem?
@thomasmckay
I just stumbled across the same problem. But only under windows. Linux
puppet agents seem to be able to handle this.
··· Am Montag, 1. Februar 2016 15:32:38 UTC+1 schrieb Tom McKay:
I’d like to figure out where I went wrong or if there is an issue…
Warning: Local environment: “production” doesn’t match server specified
node environment “KT_megacorp_Baseline_Puppet_Modules_6”, switching agent
to “KT_megacorp_Baseline_Puppet_Modules_6”.
Warning: nmcli (1.0.6) and NetworkManager (1.0.0) versions don’t match.
First I ran this…
git clone GitHub - puppetlabs/puppetlabs-motd: Simple motd module
cd puppetlabs-motd
…bumped version…
Then I created a product with a puppet repo sync’ed from that output plus
$ hammer product info --id 17 --organization “Mega Corporation”
Label: puppet-motd
Sync Plan ID:
GPG:
GPG Key ID:
GPG Key:
Readonly: false
Deletable:
Content:
$ hammer content-view info --id 6 --organization “Mega Corporation”
2.5, Use --uuid
Composite: false
Description:
Yum Repositories:
Puppet Modules:
  1. ID: 1
    Author: puppetlabs
  2. ID: 6
  3. ID: 2
    Versions:
  4. ID: 6
    Version: 1.0
    Components:
Activation Keys:
ended up on disk…
$ ls -l
email…
$ ls -l
lrwxrwxrwx. 1 apache apache 15 Feb 1 08:32 motd → puppetlabs-motd
@thomasmckay
The issue is known:
https://groups.google.com/forum/#!topic/foreman-users/sGjFQylvuuA
here is the bug report:
https://bugzilla.redhat.com/show_bug.cgi?id=1123446
they say it's fixed in pulp 2.4.1. I'm running 2.8.x and it doesn't work.
As a workaround you can use hammer cli:
e.g.
hammer -u admin repository upload-content --organization-id 1 --path
/modules --product "Puppet modules" --name "Puppet modules"
works perfect :slight_smile:
··· Am Mittwoch, 7. September 2016 16:19:04 UTC+2 schrieb Oliver Weinmann:
First I ran this…
cd puppetlabs-motd
…bumped version…
Label: puppet-motd
Sync Plan ID:
GPG:
GPG Key ID:
GPG Key:
Readonly: false
Deletable:
Content:
Composite: false
Description:
Yum Repositories:
Puppet Modules:
  1. ID: 1
    Author: puppetlabs
  2. ID: 6
  3. ID: 2
    Versions:
  4. ID: 6
    Version: 1.0
    Components:
Activation Keys:
ended up on disk…
$ ls -l
email…
$ ls -l
@thomasmckay
