I’m facing a problem with redhat repositories when i try to sync from client.
I have added my redhat manifest, a RedHat product was created and daily sync works well.
I have a Red Hat 7 host, i managed to enable the Red Hat specific repositories on it. When i go back on the host and try to “yum repolist” i got this error:
It’s not easy to test this method because my server is in an offline network and doesn’t have access to proxy.
That’s why i use foreman to give it update.
When i check the status with the bellow command I get the right repo available from Foreman:
subscription-manager list --match-installed --available
Available Subscriptions
Subscription Name: Red Hat Enterprise Linux Server with Satellite, Standard (Physical or Virtual Nodes)
Provides: Red Hat Beta
Red Hat Software Collections (for RHEL Server)
Red Hat Enterprise Linux for x86_64
Red Hat CodeReady Linux Builder for x86_64
Red Hat Ansible Engine
Oracle Java (for RHEL Server)
Red Hat Container Images Beta
Red Hat Developer Tools (for RHEL Server)
Red Hat Enterprise Linux Atomic Host
Red Hat Developer Tools Beta (for RHEL Server)
dotNET on RHEL (for RHEL Server)
Red Hat Software Collections Beta (for RHEL Server)
Red Hat Developer Toolset (for RHEL Server)
dotNET on RHEL Beta (for RHEL Server)
Red Hat Enterprise Linux Atomic Host Beta
SKU: XXXXX
Contract: XXXXX
Pool ID: XXXXXXXXXXXX
Provides Management: Yes
Available: 3
Suggested: 2
Service Type: L1-L3
Roles: Red Hat Enterprise Linux Server
Service Level: Standard
Usage: Production
Add-ons:
Subscription Type: Instance Based
Starts: 01/09/2024
Ends: 01/09/2028
Entitlement Type: Physical
