Could you please provide details regarding your upgrade, like the old foreman/katello versions, the basic upgrade steps, etc. to help us understand your case?
Did you run into any issue during the upgrade? Any errors in the log files?
[root@no1-psoapp-1 ~]# foreman-installer
2021-06-29 13:03:31 [NOTICE] [root] Loading installer configuration. This will take some time.
2021-06-29 13:03:36 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2021-06-29 13:03:36 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2021-06-29 13:03:48 [NOTICE] [configure] Starting system configuration.
2021-06-29 13:04:00 [NOTICE] [configure] 250 configuration steps out of 2095 steps complete.
2021-06-29 13:04:21 [NOTICE] [configure] 500 configuration steps out of 2095 steps complete.
2021-06-29 13:04:22 [NOTICE] [configure] 750 configuration steps out of 2098 steps complete.
2021-06-29 13:04:24 [NOTICE] [configure] 1000 configuration steps out of 2102 steps complete.
2021-06-29 13:04:25 [NOTICE] [configure] 1250 configuration steps out of 2106 steps complete.
2021-06-29 13:04:44 [NOTICE] [configure] 1500 configuration steps out of 2107 steps complete.
2021-06-29 13:04:45 [NOTICE] [configure] 1750 configuration steps out of 2107 steps complete.
2021-06-29 13:04:52 [NOTICE] [configure] 2000 configuration steps out of 2107 steps complete.
2021-06-29 13:04:57 [NOTICE] [configure] System configuration has finished.
Executing: foreman-rake upgrade:run
`/usr/share/foreman` is not writable.
Bundler will use `/tmp/bundler20210629-4901-hsbfj14901' as your home directory temporarily.
API controllers newer than Apipie cache! Run apipie:cache rake task to regenerate cache.
Upgrade Step 1/3: katello:correct_repositories. This may take a long while.
Processing Repository 1/1185: Red Hat Enterprise Linux 7 Server - Extras RPMs x86_64 (1)
Failed upgrade task: katello:correct_repositories, see logs for more information.
Upgrade Step 2/3: katello:correct_puppet_environments. This may take a long while.
Failed upgrade task: katello:correct_puppet_environments, see logs for more information.
Upgrade Step 3/3: katello:clean_backend_objects. This may take a long while.
0 orphaned consumer id(s) found in candlepin.
Candlepin orphaned consumers: []
Success!
* Foreman is running at https://fqdn
* To install an additional Foreman proxy on separate machine continue by running:
foreman-proxy-certs-generate --foreman-proxy-fqdn "$FOREMAN_PROXY" --certs-tar "/root/$FOREMAN_PROXY-certs.tar"
* Foreman Proxy is running at https://fqdn:9090
Services:
[root@no1-psoapp-1 ~]# hammer status
Version: 2.6.0-develop
API Version: v2
Database:
Status: ok
Server Response: Duration: 0ms
Plugins:
katello_agent:
Status: ok
message: 0 Processed, 0 Failed
candlepin:
Status: ok
Server Response: Duration: 14ms
candlepin_auth:
Status: ok
candlepin_events:
Status: FAIL
message: Not running
katello_events:
Status: ok
message: 5 Processed, 0 Failed
pulp3:
Status: ok
Server Response: Duration: 34ms
foreman_tasks:
Status: ok
Server Response: Duration: 2ms
You might have upgraded to unstable nightly release version by following the nightly documentation.
Please refer to this post for upgrade procedure. Thanks.
Sadly we don’t support downgrade.
Reinstall would be a better option if there is no data need to be preserved. Otherwise I hope there is a snapshot before your migration so you may revert back to.
