Can’t change url Parameter in Kickstart File
Changing Unattended URL in Administer->Settings->Parameter-Provisioning has no effect Expected outcome:
beeing able to change the url parameter in kickstart file from hostname to ip Foreman and Proxy versions:
1.20.2 Foreman and Proxy plugin versions:
katello 3.10.0 Other relevant data:
changing the Parameter in the Settings doesn’t have any effect anywhere.
i even created new hosts, which still have in their kickstart file the setting as original:
i need to replace the FQDN in this URL by an IP Address.
What is supposed to happen when the Parameter “unattended Url” in the Settings is changed ?
In the meantime the system has been updated to
Foreman 1.21.3
Katello 3.11.1
Yeah, I haven’t realized you have katello installed. When using katello plugin, unattended_url is actually not relevant and the hostname is actually Content Source smart proxy.
