Hi all,
I’m having an issue deploying a VM via hammer cli. I am able to deploy fine via the UI, but I am stuck on deploying via Hammer. We are trying to automate the deployment of VMs using variables so using Hammer is a necessity!
This is the command I’m using:
/usr/bin/hammer --debug -u admin -p host create \ --name "hammer-deploy.isea.ccop.local" \ --managed "true" \ --hostgroup "centos_7_default" \ --compute-resource-id=2 \ --compute-attributes "cpus=1,corespersocket=1,memory_mb=2048,cluster=192.168.40.11,guest_id=centos7_64Guest,start=1,scsi_controller_type=VirtualLsiLogicController" \ --interface "_destroy=0,primary=true,managed=true,provision=true,compute_type=VirtualVmxnet3,compute_network=network-30,type=interface,ip=192.168.40.222" \ --volume="datastore=DS1,thin=true,size_gb=100"
Here is the relevant info in production.log: (The successful UI deployment is also included below)
********2018-01-26 12:33:11 3f4fe7ec [app] [I] Processing by Api::V2::HostsController#create as JSON 2018-01-26 12:33:11 3f4fe7ec [app] [I] Parameters: {"host"=>{"name"=>"hammer-deploy.isea.ccop.local", "compute_resource_id"=>2, "hostgroup_id"=>2, "build"=>true, "enabled"=>true, "managed"=>true, "compute_attributes"=>{"cpus"=>"1", "corespersocket"=>"1", "memory_mb"=>"2048", "cluster"=>"192.168.40.11", "guest_id"=>"centos7_64Guest", "start"=>"1", "scsi_controller_type"=>"VirtualLsiLogicController", "volumes_attributes"=>{"0"=>{"datastore"=>"DS1", "thin"=>"true", "size_gb"=>"100"}}}, "overwrite"=>true, "host_parameters_attributes"=>[], "interfaces_attributes"=>[{"_destroy"=>"0", "primary"=>"true", "managed"=>"true", "provision"=>"true", "type"=>"interface", "ip"=>"192.168.40.222", "compute_attributes"=>{"type"=>"VirtualVmxnet3", "network"=>"network-30"}}]}, "apiv"=>"v2"} 2018-01-26 12:33:11 3f4fe7ec [app] [I] Current user: foreman_admin (administrator) 2018-01-26 12:33:11 3f4fe7ec [app] [I] Current user: foreman_admin (administrator) 2018-01-26 12:33:11 3f4fe7ec [app] [I] Current user: admin (administrator) 2018-01-26 12:33:11 3f4fe7ec [app] [I] Authorized user admin(Admin User) 2018-01-26 12:33:11 3f4fe7ec [app] [I] Current user: admin (administrator) 2018-01-26 12:33:12 3f4fe7ec [app] [I] Adding Compute instance for hammer-deploy.isea.ccop.local 2018-01-26 12:33:13 3f4fe7ec [app] [W] Failed to create a compute vCenter (VMware) instance hammer-deploy.isea.ccop.local: undefined method `sub' for nil:NilClass | | NoMethodError: undefined method `sub' for nil:NilClass | /opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere-1.9.2/lib/fog/vsphere/requests/compute/get_folder.rb:34:in `get_raw_vmfolder' | /opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere-1.9.2/lib/fog/vsphere/requests/compute/create_vm.rb:29:in `create_vm' | /opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere-1.9.2/lib/fog/vsphere/models/compute/server.rb:297:in `save' | /usr/share/foreman/app/models/compute_resources/foreman/model/vmware.rb:436:in `create_vm' | /usr/share/foreman/app/models/concerns/orchestration/compute.rb:77:in `setCompute' | /usr/share/foreman/app/models/concerns/orchestration.rb:220:in `execute' | /usr/share/foreman/app/models/concerns/orchestration.rb:145:in `block in process' | /usr/share/foreman/app/models/concerns/orchestration.rb:137:in `each' | /usr/share/foreman/app/models/concerns/orchestration.rb:137:in `process' | /usr/share/foreman/app/models/concerns/orchestration.rb:44:in `around_save_orchestration' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in `block in make_lambda' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `block in halting' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `block in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:92:in `__run_callbacks__' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in `_run_save_callbacks' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/callbacks.rb:302:in `create_or_update' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/persistence.rb:120:in `save' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/validations.rb:37:in `save' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/attribute_methods/dirty.rb:21:in `save' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:286:in `block (2 levels) in save' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:351:in `block in with_transaction_returning_status' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `block in transaction' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:184:in `within_new_transaction' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `transaction' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:220:in `transaction' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:348:in `with_transaction_returning_status' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:286:in `block in save' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:301:in `rollback_active_record_state!' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:285:in `save' | /usr/share/foreman/app/models/concerns/foreman/sti.rb:29:in `save_with_type' | /usr/share/foreman/app/controllers/api/v2/hosts_controller.rb:138:in `create' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/implicit_render.rb:4:in `send_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/base.rb:198:in `process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rendering.rb:10:in `process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/callbacks.rb:20:in `block in process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:117:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:117:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in `block (2 levels) in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `block (2 levels) in halting' | /usr/share/foreman/app/controllers/api/v2/base_controller.rb:152:in `disable_json_root' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in `block in make_lambda' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `block in halting' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `block in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in `block (2 levels) in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `block (2 levels) in halting' | /usr/share/foreman/app/controllers/concerns/application_shared.rb:15:in `set_timezone' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in `block in make_lambda' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `block in halting' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `block in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in `block (2 levels) in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `block (2 levels) in halting' | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in `block in make_lambda' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `block in halting' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `block in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in `block (2 levels) in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `block (2 levels) in halting' | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in `block in make_lambda' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `block in halting' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `block in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in `block (2 levels) in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `block (2 levels) in halting' | /opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.4.1/lib/audited/sweeper.rb:14:in `around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:455:in `public_send' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:455:in `block in make_lambda' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `block in halting' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `block in around' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:92:in `__run_callbacks__' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:81:in `run_callbacks' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/callbacks.rb:19:in `process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rescue.rb:29:in `process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:164:in `block in instrument' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications/instrumenter.rb:20:in `instrument' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:164:in `instrument' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:30:in `process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/params_wrapper.rb:250:in `process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/railties/controller_runtime.rb:18:in `process_action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/base.rb:137:in `process' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/rendering.rb:30:in `process' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal.rb:196:in `dispatch' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal.rb:237:in `block in action' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:74:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:74:in `dispatch' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:43:in `serve' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/mapper.rb:49:in `serve' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:43:in `block in serve' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:in `each' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:in `serve' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:815:in `call' | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.4/lib/apipie/static_dispatcher.rb:65:in `call' | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.4/lib/apipie/extractor/recorder.rb:136:in `call' | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.4/lib/apipie/middleware/checksum_in_headers.rb:27:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/etag.rb:24:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/conditionalget.rb:38:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/head.rb:13:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/params_parser.rb:27:in `call' | /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:8:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/flash.rb:260:in `call' | /usr/share/foreman/lib/middleware/session_safe_logging.rb:17:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/session/abstract/id.rb:225:in `context' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/session/abstract/id.rb:220:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/cookies.rb:560:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/query_cache.rb:36:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:88:in `__run_callbacks__' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in `_run_call_callbacks' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:81:in `run_callbacks' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:27:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/remote_ip.rb:78:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:38:in `call_app' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:22:in `call' | /opt/theforeman/tfm/root/usr/share/gems/gems/sprockets-rails-3.2.0/lib/sprockets/rails/quiet_assets.rb:13:in `call' | /usr/share/foreman/lib/middleware/tagged_logging.rb:18:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/request_id.rb:21:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/methodoverride.rb:22:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/runtime.rb:18:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/cache/strategy/local_cache_middleware.rb:28:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/sendfile.rb:113:in `call' | /opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-3.4.1/lib/secure_headers/middleware.rb:12:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:518:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/application.rb:165:in `call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in `public_send' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in `method_missing' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:66:in `block in call' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:50:in `each' | /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:50:in `call' | /usr/share/passenger/phusion_passenger/rack/thread_handler_extension.rb:74:in `process_request' | /usr/share/passenger/phusion_passenger/request_handler/thread_handler.rb:141:in `accept_and_process_next_request' | /usr/share/passenger/phusion_passenger/request_handler/thread_handler.rb:109:in `main_loop' | /usr/share/passenger/phusion_passenger/request_handler.rb:455:in `block (3 levels) in start_threads' | /opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in `call' | /opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in `block in create_with_logging_context' 2018-01-26 12:33:13 3f4fe7ec [app] [W] Rolling back due to a problem: [#<Orchestration::Task:0x007f1716c61f68 @name="Set up compute instance hammer-deploy.isea.ccop.local", @status="failed", @priority=2, @action=[#, :setCompute], @timestamp=2018-01-26 17:33:13 UTC>] 2018-01-26 12:33:13 3f4fe7ec [app] [I] Processed 1 tasks from queue 'Host::Managed Main', completed 0/10 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Set up compute instance hammer-deploy.isea.ccop.local' *failed* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Query instance details for hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'DHCP conflicts removal for hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Create DHCP Settings for hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Create Reverse IPv4 DNS record for hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Deploy TFTP PXEGrub2 config for hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Deploy TFTP PXELinux config for hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Deploy TFTP PXEGrub config for hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Fetch TFTP boot files for hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Task 'Power up compute instance hammer-deploy.isea.ccop.local' *canceled* 2018-01-26 12:33:13 3f4fe7ec [app] [E] Unprocessable entity Host::Managed (id: new): | Failed to create a compute vCenter (VMware) instance hammer-deploy.isea.ccop.local: undefined method `sub' for nil:NilClass | | 2018-01-26 12:33:13 3f4fe7ec [app] [I] Rendered api/v2/errors/unprocessable_entity.json.rabl within api/v2/layouts/error_layout (2.1ms) 2018-01-26 12:33:13 3f4fe7ec [app] [I] Completed 422 Unprocessable Entity in 1423ms (Views: 12.6ms | ActiveRecord: 48.5ms) 2018-01-26 12:33:15 48e60e6b [app] [I] Started GET "/notification_recipients" for 192.168.40.86 at 2018-01-26 12:33:15 -0500 2018-01-26 12:33:15 48e60e6b [app] [I] Processing by NotificationRecipientsController#index as JSON 2018-01-26 12:33:15 48e60e6b [app] [I] Current user: admin (administrator) 2018-01-26 12:33:15 48e60e6b [app] [I] Completed 200 OK in 7ms (Views: 0.3ms | ActiveRecord: 0.5ms) 2018-01-26 12:33:25 89c1f96e [app] [I] Started GET "/notification_recipients" for 192.168.40.86 at 2018-01-26 12:33:25 -0500 2018-01-26 12:33:25 89c1f96e [app] [I] Processing by NotificationRecipientsController#index as JSON 2018-01-26 12:33:25 89c1f96e [app] [I] Current user: admin (administrator) 2018-01-26 12:33:25 89c1f96e [app] [I] Completed 200 OK in 6ms (Views: 0.3ms | ActiveRecord: 0.5ms) 2018-01-26 12:33:35 742e0e3a [app] [I] Started GET "/notification_recipients" for 192.168.40.86 at 2018-01-26 12:33:35 -0500 2018-01-26 12:33:35 742e0e3a [app] [I] Processing by NotificationRecipientsController#index as JSON 2018-01-26 12:33:35 742e0e3a [app] [I] Current user: admin (administrator) 2018-01-26 12:33:35 742e0e3a [app] [I] Completed 200 OK in 6ms (Views: 0.3ms | ActiveRecord: 0.5ms) 2018-01-26 12:33:45 c3dd8fb0 [app] [I] Started GET "/notification_recipients" for 192.168.40.86 at 2018-01-26 12:33:45 -0500 2018-01-26 12:33:45 c3dd8fb0 [app] [I] Processing by NotificationRecipientsController#index as JSON 2018-01-26 12:33:45 c3dd8fb0 [app] [I] Current user: admin (administrator) 2018-01-26 12:33:45 c3dd8fb0 [app] [I] Completed 200 OK in 6ms (Views: 0.3ms | ActiveRecord: 0.4ms) 2018-01-26 12:33:55 51bc01ef [app] [I] Started GET "/notification_recipients" for 192.168.40.86 at 2018-01-26 12:33:55 -0500 2018-01-26 12:33:55 51bc01ef [app] [I] Processing by NotificationRecipientsController#index as JSON 2018-01-26 12:33:55 51bc01ef [app] [I] Current user: admin (administrator) AND here is the successful deploy via the UI: ************** 2018-01-26 12:29:42 6195f089 [app] [I] Started POST "/hosts" for 192.168.40.86 at 2018-01-26 12:29:42 -0500 2018-01-26 12:29:42 6195f089 [app] [I] Processing by HostsController#create as */* 2018-01-26 12:29:42 6195f089 [app] [I] Parameters: {"utf8"=>"✓", "authenticity_token"=>"EvXcftYFY/eGgpjaV8MO4HBvTIK8o3RN+lfU6seVo+QQLgYUaeynW1F6Tia3gqgvrJrv+s3oBHm0rgXQqI4GfA==", "host"=>{"name"=>"ui-deploy", "hostgroup_id"=>"2", "compute_resource_id"=>"2", "puppetclass_ids"=>[""], "managed"=>"true", "progress_report_id"=>"[FILTERED]", "type"=>"Host::Managed", "interfaces_attributes"=>{"0"=>{"_destroy"=>"0", "type"=>"Nic::Managed", "mac"=>"", "identifier"=>"", "name"=>"ui-deploy", "domain_id"=>"1", "subnet_id"=>"14", "ip"=>"192.168.40.221", "ip6"=>"", "managed"=>"1", "primary"=>"1", "provision"=>"1", "virtual"=>"0", "tag"=>"", "attached_to"=>"", "compute_attributes"=>{"type"=>"VirtualVmxnet3", "network"=>"network-30"}}}, "compute_attributes"=>{"cpus"=>"1", "corespersocket"=>"1", "memory_mb"=>"2048", "firmware"=>"automatic", "cluster"=>"192.168.40.11", "resource_pool"=>"Resources", "path"=>"/Datacenters/CCOP_DEV/vm", "guest_id"=>"centos7_64Guest", "hardware_version"=>"Default", "memoryHotAddEnabled"=>"0", "cpuHotAddEnabled"=>"0", "add_cdrom"=>"0", "start"=>"1", "annotation"=>"", "scsi_controllers"=>"{\"scsiControllers\":[{\"type\":\"VirtualLsiLogicController\",\"key\":1000}],\"volumes\":[{\"thin\":true,\"name\":\"Hard disk\",\"mode\":\"persistent\",\"controllerKey\":1000,\"size\":10485760,\"sizeGb\":100,\"datastore\":\"DS1\"}]}"}, "architecture_id"=>"1", "operatingsystem_id"=>"2", "provision_method"=>"build", "build"=>"1", "medium_id"=>"9", "ptable_id"=>"88", "pxe_loader"=>"PXELinux BIOS", "disk"=>"", "root_pass"=>"[FILTERED]", "is_owned_by"=>"4-Users", "enabled"=>"1", "model_id"=>"", "comment"=>"", "overwrite"=>"false"}, "capabilities"=>"build image", "provider"=>"Vmware", "bare_metal_capabilities"=>"build"} 2018-01-26 12:29:42 6195f089 [app] [I] Current user: admin (administrator) 2018-01-26 12:29:43 6195f089 [app] [I] Adding Compute instance for ui-deploy.isea.ccop.local 2018-01-26 12:29:44 9bb052ea [app] [I] Started GET "/tasks/703accd6-9953-467f-be10-3d5a9daf2852" for 192.168.40.86 at 2018-01-26 12:29:44 -0500 2018-01-26 12:29:44 9bb052ea [app] [I] Processing by TasksController#show as */* 2018-01-26 12:29:44 9bb052ea [app] [I] Parameters: {"id"=>"703accd6-9953-467f-be10-3d5a9daf2852"} 2018-01-26 12:29:44 9bb052ea [app] [I] Current user: admin (administrator) 2018-01-26 12:29:44 9bb052ea [app] [I] Rendered tasks/_list.html.erb (2.4ms) 2018-01-26 12:29:44 9bb052ea [app] [I] Completed 200 OK in 26ms (Views: 15.4ms | ActiveRecord: 1.1ms) 2018-01-26 12:29:45 683a14ff [app] [I] Started GET "/notification_recipients" for 192.168.40.86 at 2018-01-26 12:29:45 -0500
Thanks!
Alicia
