I'm just evaluating foreman, so far the installer worked properly in
debian7, everything is up and running.
The first thing I wanted to configure was puppet modules…and hit the
first problem.
Most of the modules seem to be properly imported but tried two different
ones for DHCP and both are having the same issue, dhcp::pool and dhcp::host
are not being imported, or not listed.
The two modules I tried are:
- theforeman-dhcp
- zleslie-dhcp
Anyone with same issue? am I doing anything wrong?
I'll be happy to provide further information if needed.
Thanks!
Check if the file "config/ignored_environments.yml" exists and is matching
some of these classes.
El sábado, 13 de julio de 2013 18:42:40 UTC+2, Sergio Jimenez escribió:
> Hi,
> The first thing I wanted to configure was puppet modules....and hit the
> first problem.
> * theforeman-dhcp
> * zleslie-dhcp
> Thanks!
Hi!
the file is there but with .sample extension, which I understand is not
used…isn't it?
Its contents is:
cat ignored_environments.yml.sample
#:ignored:
- test
:filters:
- !ruby/regexp '/params$/'
- !ruby/regexp '/base$/'
- !ruby/regexp '/install$/'
- !ruby/regexp '/service$/'
- !ruby/regexp '/config$/'
Thanks!
>> Hi,
>> first problem.
>> * theforeman-dhcp
>> * zleslie-dhcp
>> Thanks!
Hmmm my bad, they are not classes…they are puppet defined types, do they
work in foreman?
Sorry for the noise…
On Sunday, July 14, 2013 1:01:47 AM UTC+2, Sergio Jimenez wrote:
> Hi!
> used...isn't it?
> Its contents is:
> #:ignored:
> # - test
> :filters:
> Thanks!
>> matching some of these classes.
>>> Hi,
>>> first problem.
>>> * theforeman-dhcp
>>> * zleslie-dhcp
>>> Thanks!
OK, I found the answer here:
https://groups.google.com/forum/?fromgroups=#!topic/foreman-users/o-Sqjo-n21A
Thanks!
On Sunday, July 14, 2013 1:10:04 AM UTC+2, Sergio Jimenez wrote:
> Hmmm my bad, they are not classes...they are puppet defined types, do they
> work in foreman?
> Sorry for the noise...
>> Hi!
>> used...isn't it?
>> Its contents is:
>> #:ignored:
>> # - test
>> :filters:
>> Thanks!
>>>> Hi,
>>>> first problem.
>>>> different ones for DHCP and both are having the same issue, dhcp::pool and
>>>> dhcp::host are not being imported, or not listed.
>>>> * theforeman-dhcp
>>>> * zleslie-dhcp
>>>> Thanks!
