My VMWare image crapped out so I am setting up again.
downloaded with git
puppet 2.7.1
ruby-enterprise-1.8.7-3
problem is when I try to rake db:migrate, a mess piles out and errors…
root@ubuntu:/var/www/foreman# rake db:migrate RAILS_ENV=production
NOTE: Gem.source_index is deprecated, use Specification. It will be removed on or after 2011-11-01.
Gem.source_index called from /var/www/foreman/config/…/vendor/rails/railties/lib/rails/gem_dependency.rb:21.
NOTE: Gem::SourceIndex#refresh! is deprecated with no replacement. It will be removed on or after 2011-11-01.
Gem::SourceIndex#refresh! called from /var/www/foreman/config/…/vendor/rails/railties/lib/rails/vendor_gem_source_index.rb:34.
NOTE: Gem::SourceIndex#load_gems_in is deprecated with no replacement. It will be removed on or after 2011-11-01.
Gem::SourceIndex#load_gems_in called from /usr/local/lib/ruby/site_ruby/1.8/rubygems/source_index.rb:322.
<snip>
Gem::SourceIndex#add_spec called from /usr/local/lib/ruby/site_ruby/1.8/rubygems/source_index.rb:91.
NOTE: Gem::SourceIndex#add_spec is deprecated, use Specification.add_spec. It will be removed on or after 2011-11-01.
rake/rdoctask is deprecated. Use rdoc/task instead (in RDoc 2.4.2+)
rake aborted!
undefined method `name' for "abstract":String
Tasks: TOP => db:migrate => environment
Should I be going back to puppet 2.6.8?
-- Craig White ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ craig.white@ttiltd.com 1.800.869.6908 ~~~~~~~~~~~~~~~~~~~~~~~~~~~ www.ttiassessments.comNeed help communicating between generations at work to achieve your desired success? Let us help!
