undefined method `assets' for #<Rails::Application::Configuration:0x7f72a9975c98>
I have downloaded the script from the foreman web site and when I run the
script, if i look in the httpd logs I can see that its trying to post but
its getting redirected to the login page. I have tried adding the host name
into trusted_puppetmaster_hosts but this doesn't seem to have any affect.
what is your setup? Are you able to send me (personally) foreman-debug
output tarball?
What platform? How did you install? Isn't this a bundler setup?
LZ
On Thu, Aug 08, 2013 at 06:58:06AM -0700, Richie Rees wrote:
> Hi All,
> Having problems with facts. Running foreman 1.2 puppet and foreman are on
> the same system. When I run :-
> *rake puppet:import:hosts_and_facts RAILS_ENV=production*
> I get the error message :-
> *undefined method `assets' for #*
> Thanks,
> Richie.
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com.
> Visit this group at http://groups.google.com/group/foreman-users.
> For more options, visit https://groups.google.com/groups/opt_out.
Will happily send you the tar ball send me your address.
Richie.
PS Happy Friday Everyone
On Thursday, 8 August 2013 14:58:06 UTC+1, Richie Rees wrote:
> Hi All,
> Thanks,
> Richie.
Ok i think I may have found the cause (accidently) The domain that the
foreman sits in is the domain sample.com the systems being provisioned are
in testing.sample.com so we could delegate the DNS to the smart host while
testing. I accidently created a machine in the sample.com domain and I can
see the facts. So where do I tell foreman/puppet also trust testing.sample.com ?
> Hi All,
> Thanks,
> Richie.
I have added a line in auth and now getting this error message in
production.log
Started POST "/fact_values/create?format=yml" for 192.168.0.1 at
2013-08-12 12:46:16 +0100 Processing by FactValuesController#create as YML
Parameters: {"facts"=>"[FILTERED]"}* Failed to save system.testing.sample.com: ERF51-9911: Host is pending for
Build
Rendered text template (0.0ms)* Completed 200 OK in 14ms (Views: 0.6ms | ActiveRecord: 1.8ms)
> are in testing.sample.com so we could delegate the DNS to the smart host
> while testing. I accidently created a machine in the sample.com domain
> and I can see the facts. So where do I tell foreman/puppet also trust
>> Hi All,
>> Thanks,
>> Richie.
production.log
Started POST “/fact_values/create?format=yml” for 192.168.0.1 at
Parameters: {“facts”=>"[FILTERED]"}* Failed to save system.testing.sample.com: ERF51-9911: Host is pending
for Build
and I can see the facts. So where do I tell foreman/puppet also trust testing.sample.com ?
Hi All,
on the same system. When I run :-
the script, if i look in the httpd logs I can see that its trying to post
but its getting redirected to the login page. I have tried adding the host
name into trusted_puppetmaster_**hosts but this doesn’t seem to have
any affect.
Yes i can see the error. But what does it mean ? The host has been built
has all the puppet classes installed (bar the ones failing that depend on
facts) and is actually operational. So why is it still pending for build ?
The system where facts are being returned more from this status.
On Monday, 12 August 2013 12:59:39 UTC+1, ohad wrote:
> let me extract the error for you:
> *Failed to save system.testing.sample.com: ERF51-9911: Host is pending
> for Build*
> *Ohad*
> On Mon, Aug 12, 2013 at 2:48 PM, Richie Rees <richard...@gmail.com > > wrote:
>> production.log
>> *Started POST "/fact_values/create?format=yml" for 192.168.0.1 at
>> 2013-08-12 12:46:16 +0100*
>> *Processing by FactValuesController#create as YML*
>> * Parameters: {"facts"=>"[FILTERED]"}*
>> for Build*
>> * Rendered text template (0.0ms)*
>> *Completed 200 OK in 14ms (Views: 0.6ms | ActiveRecord: 1.8ms)*
>>> host while testing. I accidently created a machine in the sample.comdomain and I can see the facts. So where do I tell foreman/puppet also
>>>> Hi All,
>>>> name into trusted_puppetmaster_**hosts but this doesn't seem to have
>>>> any affect.
>>>> Thanks,
>>>> Richie.
At the end of a kickstart or preseed, there's a wget line in the
%post/finish script that calls Foreman to notify it that the build has
completed. It's possible that this didn't run, or failed for some
reason (it calls to the proxy to remove autosign.conf entries, which is
a common cause).
You can also flip the status manually from the host page in the Foreman
web interface ("Cancel Build").
Check for a GET "/unattended/built" logging block in
/var/log/foreman/production.log and see if there were errors.
Dominic Cleal
Red Hat Engineering
on facts) and is actually operational. So why is it still pending for
build ? The system where facts are being returned more from this status.
/Failed to save system.testing.sample.com
<http://system.testing.sample.com/>: ERF51-9911: Host is pending for
Build/
/Ohad/
On Mon, Aug 12, 2013 at 2:48 PM, Richie Rees <richard...@gmail.com > <javascript:>> wrote:
in production.log
/Started POST "/fact_values/create?format=yml" for 192.168.0.1
at 2013-08-12 12:46:16 +0100/
/Processing by FactValuesController#create as YML/
/ Parameters: {"facts"=>"[FILTERED]"}/
<http://system.testing.sample.com>: ERF51-9911: Host is pending
for Build/
/ Rendered text template (0.0ms)/
/Completed 200 OK in 14ms (Views: 0.6ms | ActiveRecord: 1.8ms)/
domain that the foreman sits in is the domain sample.com
<http://sample.com> the systems being provisioned are in
testing.sample.com <http://testing.sample.com> so we could
delegate the DNS to the smart host while testing. I
<http://sample.com> domain and I can see the facts. So where
<http://testing.sample.com> ?
Hi All,
and foreman are on the same system. When I run :-
/rake puppet:import:hosts_and_facts RAILS_ENV=production/
/undefined method `assets' for #<Rails::Application::__Configuration:0x7f72a9975c98>/
and when I run the script, if i look in the httpd logs I
can see that its trying to post but its getting
host name into trusted_puppetmaster___hosts but this
Richie.
it, send an email to foreman-user...@googlegroups.com <javascript:>.
<javascript:>.
<http://groups.google.com/group/foreman-users>.
<https://groups.google.com/groups/opt_out>.
Do you know how to get facts returned if they are in DNS sub domain ? I
have tried adding a line to auth.conf, but this has not working and I can
still see it in the logs getting a 403 error and redirected to the signin
page.
> a common cause).
> Dominic Cleal
> Red Hat Engineering
> for
> > Build/
> > /Ohad/
> > in production.log
> > for Build/
> where
> > On Thursday, 8 August 2013 14:58:06 UTC+1, Richie Rees > wrote:
> > Hi All,
> > Thanks,
> > Richie.
> > it, send an email to foreman-user...@googlegroups.com.
> > an email to foreman-user...@googlegroups.com .
> > To post to this group, send email to forema...@googlegroups.com.
Can you provide the log entry of the 403? Puppet's auth.conf and DNS
subdomains should be irrelevant.
Dominic Cleal
Red Hat Engineering
On 13/08/13 09:03, Richie Rees wrote:
Thanks Dominic
can still see it in the logs getting a 403 error and redirected to the
signin page.
a common cause).
Dominic Cleal
Red Hat Engineering
built
depend
status.
<http://system.testing.sample.com/>>: ERF51-9911: Host is pending for
> Build/
> /Ohad/
> On Mon, Aug 12, 2013 at 2:48 PM, Richie Rees > <richard...@gmail.com > > <javascript:>> wrote:
message
> in production.log
192.168.0.1
<http://system.testing.sample.com>>: ERF51-9911: Host is pending
> for Build/
1.8ms)/
sample.com <http://sample.com>
<http://sample.com>
where
> Hi All,
puppet
site
logs I
> Thanks,
> Richie.
<javascript:>.
> <javascript:>.
> Visit this group at
<http://groups.google.com/group/foreman-users>>.
<https://groups.google.com/groups/opt_out>>.
send
<javascript:>.
