csv export and csv import should both work but there seem to be a few
problems.
As a general feature it should be possible to apply an organization
and/or a location to be used when creating the objects in the csv files.
installation-medias: does not work and generates "Missing arguments for
'medium'".
compute-resources: generates "Error: undefined method Error: 500 Internal Server Error" along with the csv data. partition tables: kicks out "Error: invalid format character - %" content-views: looks to only process the first entry and then kicks out "Error: undefined method
each' for nil:NilClass"
activation-keys: has extra fields in the output csv.(field 2 in the data).
operating-systems: does not set the architectures.
sync-plans: does not add the products.
the compute resources should also include the extra information needed
to create the various resource types.
Things like user/pass or id/key for resource sources like EC2.
some csv files have quoted text some do not.
Alvin Starr || voice: (905)513-7688
Netvel Inc. || Cell: (416)806-0133
alvin@netvel.net ||
Please file redmine issues[1] for any problems or shortcomings you find. There are several PRs open[2] that I'd welcome your feedback on (ack/nack/comments).
For the most part the hammer-cli-csv module grows incrementally as I encounter needs. It is relatively straight forward to add both new export as well as import columns for resources and your own contributions, either as PRs or as redmine issues w/ requests, would be very welcome!
A currently open PR will hide any of the options that are not production worthy (in preparation for officially supporting it when Satellite-6.2 ships). All the functionality will remain and be revealed as I get tests, docs, etc. for each subcommand.
[1] Foreman Category:CLI w/ hammer-cli-csv in Subject, if you don't mind.
[2] https://github.com/katello/hammer-cli-csv/pulls
----- Original Message -----
> problems.
> 'medium'".
> compute-resources: generates "Error: undefined method `Error: 500
> "Error: undefined method `each' for nil:NilClass"
> alvin@netvel.net ||
> "Foreman users" group.
> email to foreman-users+unsubscribe@googlegroups.com.
P.S. If you find problems on importing, including the CSV file in the redmine issue would be great.
> > problems.
> > 'medium'".
> > alvin@netvel.net ||
> [1] http://projects.theforeman.org/projects/katello/issues/new Category:CLI
I will be holding off on filing a redmine issue just because my install
is so badly screwed up its hard to tell what is wrong.
Once I get things rebuilt I will give this another try.
Sadly this whole effort did not get rid of the problem that has been
plaguing me.
>> problems.
>> 'medium'".
>> alvin@netvel.net ||
> [1] http://projects.theforeman.org/projects/katello/issues/new Category:CLI w/ hammer-cli-csv in Subject, if you don't mind.
alvin@netvel.net ||
