I had the same experience with Foreman 1.12.3. I noticed it it failed to
find the command 'puppet'. After reboot, it was in path and foreman host
was successfully registered. Looks like environment setup is incomplete
without a reboot. It might be related.
Ustun
On Sunday, April 19, 2015 at 8:22:46 AM UTC-7, Osvaldas Šlapikas wrote:
> I don't know why I get this error but after reboot everything was fine.
> But thaks for answer
> On 18 April 2015 at 21:20, Lukas Zapletal <lz...@redhat.com > > wrote:
>> Was the installation successful (using our installer)?
>> Have you configured at least one proxy? Is it registered?
>> Is the host Foreman in installed on checked in via Puppet?
>> LZ
>> Later,
>> Lukas #lzap Zapletal
>> You received this message because you are subscribed to a topic in the
>> Google Groups "Foreman users" group.
>> To unsubscribe from this topic, visit
>> https://groups.google.com/d/topic/foreman-users/iV3r3qV1Lvw/unsubscribe.
>> To unsubscribe from this group and all its topics, send an email to
>> foreman-user...@googlegroups.com .
>> Visit this group at http://groups.google.com/group/foreman-users.
> From: "Üstün Kaya" <uskaya@gmail.com>
> To: "Foreman users" <foreman-users@googlegroups.com>
> Sent: Wednesday, September 21, 2016 3:25:39 PM
> Subject: Re: [foreman-users] Problems with provisioning setup
Are you using the latest provisioning templates? If you're using Puppet 4,
this is probably the case that it's not available in $PATH in the provisioning
environment.
The latest puppet_setup snippet[1] should cover that case though, as it calls the binary
explicitly with it's full path.
Add /opt/puppetlabs/bin to the path for sh compatible users
if ! echo $PATH | grep -q /opt/puppetlabs/bin ; then
export PATH=$PATH:/opt/puppetlabs/bin
fi
[ukaya@foreman1.devmlp ~]$
foreman-installer should source the profile script at the end or run a
setup script like the one you provided. For now manually sourcing the
file or simply logging out and logging back in will do the trick.
On Mon, Sep 26, 2016 at 9:24 AM, Stephen Benjamin wrote:
> ----- Original Message -----
>> From: "Üstün Kaya"
>> To: "Foreman users"
> environment.
> [1] https://github.com/theforeman/community-templates/blob/develop/snippets/puppet_setup.erb
>> Ustun
>> > On 18 April 2015 at 21:20, Lukas Zapletal <lz...@redhat.com > >> > wrote:
>> >> LZ
>> >> Later,
>> email to foreman-users+unsubscribe@googlegroups.com.
>> To post to this group, send email to foreman-users@googlegroups.com.
>> Visit this group at https://groups.google.com/group/foreman-users.
> You received this message because you are subscribed to a topic in the Google Groups "Foreman users" group.
> To unsubscribe from this topic, visit https://groups.google.com/d/topic/foreman-users/iV3r3qV1Lvw/unsubscribe.
> To unsubscribe from this group and all its topics, send an email to foreman-users+unsubscribe@googlegroups.com.
