Katello 4.1.2.1
For a change, not a critical issue but still worth noting:
In my “Products” display, the latest sync time is not being properly reflected. Here is a sample: I have 4 products, 2 of which show synced about 40 mins ago, the other 2 showing yesterday. BUT-- I have drilled down and verified that EVERYTHING (all repos) did indeed successfully sync about 40 minutes ago.
If I manually sync them, then it shows OK. It appears that the sync-times sometimes do not always get updated after a scheduled (daily in my case) sync.
